Question about Kitchen Ranges
Tappan 554s034p01 dose not stop igniting on top
Cannot get oven to work
I need more info, dose the top buners work ? dose the broiler work ? Did you take a flashlight ad look over the lower cal-rod or element ? for damage get back to me on and off here all day and some nights till 9 pm
Dec 13, 2011 | Ovens
Hi, I own a Tappan oven..model #TGF364ASF..the
Hi an welcome to FixYa. I am Kelly.
If nothing lights... i.e burner or oven there are only 2 things that can cause this problem. A failed ignition module or a wiring problem. The wiring problem can be a simple short or a broken power lead. All of the stove top ignitors are in a series parallel connection and if one of the burmer control shorts you loose the stove top. With nothing is lighting oven and burners it sure points toward the ignition module or power to the module.
Thanks for using FixYa.
Kelly
Note... The ignition module itself is not cheap.
Apr 09, 2010 | Tappan TGF364AS Gas Kitchen Range
The igniters on the left side on my Tappan gas range.
may need to disconnect voltage to machine,and check for a loose wire to burner knob.may need to lift top.to access this area.
Oct 09, 2009 | Kitchen Ranges
Oven not coming on
I have a tappan gas stove the top comes on but the oven wont come on.
Sep 07, 2009 | Tappan TGF363 Gas Kitchen Range
You have to light burners on stovetop with a match all the time.
The pilots for the range top are beneath the top of the range top. YOu will see them if they are there. YOu stove may use electronic ignition and you can hear the sparking when you turn the knob to the "light" position.
If it is electronic ignition, make sure the stove is plugged into an operating outlet
Apr 15, 2009 | Tappan MGF500PBW Gas Kitchen Range
Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Feb 13, 2009 | Tappan TGF303BW Gas Range
Tappan oven does not heat
hi thanks for the question all these oven gas not igniting mostly hase to do with igniter thanks the appliance doc
Aug 18, 2008 | Tappan TGF320 Gas Kitchen Range
Oven won't light
Well, the igniter needs to be replaced. They go bad after a lot of use, if you replace it and it's still not sparking, let me know but 99% of the time replacing the igniter will fix the problem.
If you have any further questions, just ask, I would be glad to help
Jun 03, 2008 | Tappan TGFS_63 Gas Kitchen Range
Tappan TGF657
Chek wiring on your right side switch....if the wiring is Ok, replace the switch....
Aug 30, 2007 | Tappan TGF657 Gas Kitchen Range
Kitchen Ranges Logo
18 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
