Question about Xerox DocuColor 3535 Copier
Fault codes 003-349
Switch the machine off and then on.if the problem persists,call for service
3 Suggested Answers
  • 2072 Answers
SOURCE: Xerox Workcentre 24. 20 months
That is a software processing error.
Do you have it set up as a printer? If so, try removing the print cable and power it on that way.
If that doesn't work, you need to have the firmware reloaded. That can only be done from a laptop with Xerox software on it.
Posted on Oct 03, 2008
SOURCE: fault/error a fault has occured switch off
Solution : Perform an Automatic Gradation Adjustment (Color Calibration) Automatic Gradation Adjustment compensates for tones when the color tones shift in color copies / prints. Compensating for color tones maintains the quality of color copies / prints made by the machine at a fixed level.
NOTE: Output of the Automatic Gradation Adjustment chart is added to the metered copy count.
NOTE: When Gradation Adjustment is selected, the following changes will be made to default copy settings set in System Settings mode:
  • Copy Density = Normal or Auto
  • Color Shift =Normal
  • Saturation = Normal
  • Color Balance = 0
  • Sharpness = 0
  1. Press the [Access] button (key symbol) on the Control Panel. The Access button is located above the number "3" on the numeric keypad.
  2. Using the numeric keypad, enter your administrator password and select [Confirm] on the Touch Screen. The System Administration Menu screen will be displayed.
    NOTE: If you do not know the password, contact your administrator. The initial password at machine install is 11111. If the administrator encounters a problem with changing the password, or forgets the password, a service call must be placed.
  3. Select [System Settings]. The System Settings screen will be displayed.
  4. Select [System Settings] again.
  5. Select [Common Settings].
  6. Select [Image Quality]. The Image Quality Adjustment screen displays.
  7. Select [Automatic Gradation Adjustment].
  8. Load 8.5 x 11 inch (216 mm x 279 mm) or A4 (210 mm x 297 mm / 8.3 x 11.7 inch) paper in Tray 5 (Bypass Tray). Adjust the paper tray edge guide so that the guide gently touches the edge of the paper stack.
  9. Select the desired gradation adjustment screen.
  10. Press [Start]. The Adjustment Chart is output.
    NOTE: When printing the color chart for Auto Gradation and you get the message,'Auto Graduation Procedure has completed with an error' make sure that 8.5 x 11 inch (216 mm x 279 mm) paper is loaded into Tray 5 Long Edge Feed (LEF).
  11. Place the Adjustment Chart face-down on the Document Glass with both the Magenta color patches against the left side of the glass.
  12. Place 5 sheets of white paper on top of the Adjustment Chart and close the Document Glass Cover.
  13. Press [Start].
  14. To continue Automatic Gradation Adjustment with other screens, repeat steps 6 to 10. When you are finished, select [Close] until the System Settings screen is displayed.
  15. Select [Exit] to exit the System Settings mode.
Hope it helps!
Posted on May 29, 2011
My whirlpool awo/d 5556 washer displays error code f:26 can you help please?
F26 Drain pump triac failure This error code is displayed when the main electronic controller fails to detect the triac that controls the outlet drain pump during the wash cycle.
  • Check pressure switch contacts and connectors
  • Failure of the pressure switch or level sensor can also give rise to this fault code
  • Run test program
  • If failure persists after test and verification of pressure switch, replace main controller
The above information was take from UKWhitegoods web site
http://www.ukwhitegoods.co.uk/help/fault-codes/220-laundry-fault-codes?type=rss&limitstart=0
Feb 09, 2017 | Whirlpool Washing Machines
I have a samsung washing machine, a error message came up on the screen. 3e. we were advised to contact our after sales. we did, we were told by a service eng; the mother board was dud can you please...
Switch off the power/reconnect and try again, try unplugging power cord for two minutes, if problem persist follow instructions at the end of user manual to call service
Jul 24, 2008 | Samsung Washing Machines
Xerox Printer not starting, A fault has occurred. Fault Error 116-201
The problem description is: Fault Code 116-201: HDD Was Not Booted Due to an HDD Error Detected on Booting. Try this link first: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=387,E=0000000005750000208,K=9799,Sxi=3,Solution=obj(542)
If this does not work. Unplug the machine from the wall while still on
do not power down first. treat it like the power just went off in your building. While the machine is still off not plugged to the wall. Press the power button several times. This will erase any saved info on memory.
Plug machine back on an try again. If it does it again you will need to replace your hard drive and that will take a service call.
Dec 10, 2015 | Xerox DocuColor 3535 Copier
I have a hotpoint WT940 error code f-08 has appeared, what does this mean
First, try turning off the mains power to the machine for 30 minutes and switching it back on to see if the error persists. This indicates a problem with the heater relay or heater. This usually means that the relay cannot be operated due to a heater fault and that the heater will need replacing. A service call to replace it will be the quickest option.
Oct 14, 2012 | Washing Machines
We have a Siemens Surpresso S40, giving 'error 8'
Error 8 indicates a technical fault. Try switching off the main switch for about 1 minute and then start it up again. If the error message persists, you will have to have the machine serviced. The most common fault would be that the machine is blocked.
Jun 06, 2011 | Coffee Makers & Espresso Machines
Our xerox workcenter 7235 fault code 024-360 and copy service is disabled
024 360 An error has been detected by the Controller during communications with the Printer. User intervention is required to Power Off/Power On the machine, Field Service is required if the problem persists. Printing is disabled.
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WC7228_WC7235_WC7245&Xlang=en_IN&Xcntry=IND
You will have to either get this printer repaired or replace it.
Aug 05, 2010 | Xerox Office Equipment & Supplies
What is E3 code
Hello there:
E3 fault code
Touchpad or Software mismatch Flashes when there is a touchpad or software mismatch. NOTE: This error code is displayed only in diagnostics mode.
Unplug the machine for 30 min and then plug machine back in to clear this fault code
If the code persists the control panel is faulty and will need to be replaced or serviced by a qualified technician
Dec 16, 2009 | Maytag Washing Machines
Error code E60 Zanuusi Washing machine
Error code E60 Fix... Press the reset button in for 5 seconds. The computer board needs resetting. You can also try to reset it by switching the machine off and unplugging it to allow any residual charge to clear from the memory chip. The next step is to clean out the filter at the front - remember to empty the water out first. After a couple of hours, switch the machine on, press reset and then spin to empty any remaining water. If the problem still persists then it is due to Fault in washing NTC sensor, wiring or main PCB.
Nov 29, 2009 | Washing Machines
Hotpoint WT940 has fault code F-03 on the display and will not empty fully, please can you advise
Switch the machine off at the mains power for 30 minutes and switch on again. If the error persists then you will need to look at the Wash thermistor (NTC) as this is faulty and may need replacing although there is a small chance that it is a wiring fault between to the thermistor. This is a reasonably common problem and is easy and relatively cheap to repair.
Oct 25, 2009 | Washing Machines
23 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
