Question about Compaq Presario 1275 Notebook
Power faulty The power on my compaq 1275 shuts off whenever i move the display/monitor or the labtop itself. Sometimes it shuts off without me moving it. Any help would be great.
  • reneemcp Jan 11, 2009
    I have the same problem, but I think my problem is internal. The part that the ac adapter plugs into seems to be loose and if moved it loses connection and shuts down. How do you get to the inside to tighten?
  • 1,006 Answers
First check the batery hdd and ram
then go start run msconfig and remove any programs from start up
and use win xp cd to repair it
Posted on Oct 21, 2007
SOURCE:
Recently tried to power computer on and computer tries to boot up but screen will only show colored lines. You can see faintly behind lines are icons like computer is trying to turn on. When shut down you...
Hello.
I'm not certain if a power issue or graphics / display issue.
If a power issue, the most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
If a display / graphics issue, connect an external monitor to your laptop. If an external monitor works, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation, the inverter would be indicated.
In either case, a technician in your area should be able to help. Evaluate to see if the repair is cost-effective.
It's also possible that your graphics card is faulty and needs to be replaced.
Hope this helps.
Feb 27, 2011 | Compaq Computers & Internet
I have a xerox xa7-19i monitor and it keeps tripping the power. i have had a look inside and nothing is shorted or blatently blown so i dont know whats wrong, anyone know what to do?
I assume you mean the monitor itself keeps shutting off and on? These LCD style monitors are infamous for failed power supplies, due to faulty capacitors inside the unit (which are very hard to detect). the capacitors buldge and sometimes leak when they are faulty. they work for a very short time, then fail. BE VERY CAREFUL inside any monitor as Capacitors Can give you a whopper of a shock, Even after being unplugged. if its your house power breaker, Id look to a frayed power wire, or the wall receptacle. Try a different outlet see if the problem moves with you, which would point to the monitor itself.
Aug 25, 2010 | Xerox XA7-192i 19" LCD Monitor
Can I run my 1275 w/o the battery and use just a/c power
Hello, the short answer is YES you can. I am not sure why are you trying to do this but just remember while running laptop just AC power your are running the rick where if you accidently move the laptop and power connector coming lose from laptop will cause instant power off. This can cause you lose data you might be working on. This can also cause OS corupption.
So my recommendation is to do this if absolutely nessasary and be sure thatpower cable doesn't get pulled or moved.
I hope this helps,
Kind regards,
Amar Sondhi
Jan 24, 2010 | Compaq Presario 1275 Notebook
Our one year old monitor comes on, but then goes black after just a few seconds. it is not the graphics card. I hooked it up to another computer and it did the same thing.
If the monitor power light on remains on, either the monitor itself or VGA cable is faulty. Move the cable to see if there is any change on the display. I'd suggest changing the cable - less expensive than a monitor. If not the cable, the monitor is faulty.
Jul 13, 2009 | HP w19 19" LCD Monitor
LCD Monitor
Hi rhymers3,
First, check that monitor power save is disabled. Right click on desktop, properties, Screen Save tab, power button. Select "Never" for the "Turn Off Monitor" drop-down box.
Also, check that the monitor itself doesn't have any power save/ sleep options enabled.
Another possibility is a faulty graphics card or faulty cable to the monitor - try moving the cable/card and see if the image comes and goes.
Try using a different (lower) display resolution. It could be that the one you currently have is just on the limits of not working with that monitor.
Good luck.
Jul 06, 2009 | Computers & Internet
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
My monitor displays yellowish color instead of original color
yes please take the power on self test means disconnect signal cable and monitor will give
display without cpu if display appears then monitor ok fault is in cpu if not then fault is in monitor move signal cable and look display changes or not if changes then cable faulty replace it
Nov 11, 2008 | SAMTRON 55V 15" CRT Monitor
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Garbled screen on Monitor
Have you tried a different monitor? It sounds like your have a faulty Video card.
Dec 31, 2007 | Neovo F-17C 17" LCD Monitor
Compaq 1275
possibly this could be a lid switch issue, check you lid switch settings in power manager.
Oct 07, 2007 | Compaq Presario 1275 Notebook
Open Questions:
SBCglobal MAil CuStOMeR $%{1^855^536^5666}#[email protected] SuPPoRt NuMbER HELP DESK This SbCgLoBaL MaiLUSA phone number is ranked #2 out of 2 because 7,728 SbCgLoBaL MaiLUSA customers tried our tools and information and gave us feedback after they called. The reason customers call # I855%^536%^5666is to reach the SbCgLoBaL MaiLUSA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbCgLoBaL MaiLUSA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbCgLoBaL MaiLUSA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I855%536%5666 and ways to call or contact SbCgLoBaL MaiLUSA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL MaiLUSA Calling SbCgLoBaL MaiLUSA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL MaiLUSA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL MaiLUSA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL MaiLUSA's phone numbers against each other. Contacting SbCgLoBaL MaiLUSA in General While I855%536%5666 is SbCgLoBaL MaiLUSA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I855%536%5666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL MaiLUSA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL MaiL USA.
Oct 16, 2019 | Best Computers & Internet
SBCglobal MAil CuStOMeR Care {1-/855/*536/*5666/}#[email protected] PHoNe NuMbER SUPPORT NUMBER This SbCgLoBaL MaiLUSA phone number is ranked #2 out of 2 because 7,728 SbCgLoBaL MaiLUSA customers tried our tools and information and gave us feedback after they called. The reason customers call # I855%^536%^5666is to reach the SbCgLoBaL MaiLUSA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbCgLoBaL MaiLUSA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbCgLoBaL MaiLUSA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I855%536%5666 and ways to call or contact SbCgLoBaL MaiLUSA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL MaiLUSA Calling SbCgLoBaL MaiLUSA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL MaiLUSA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL MaiLUSA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL MaiLUSA's phone numbers against each other. Contacting SbCgLoBaL MaiLUSA in General While I855%536%5666 is SbCgLoBaL MaiLUSA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I855%536%5666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL MaiLUSA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL MaiL USA.
See all Compaq Presario 1275 Notebook Questions
Compaq Presario 1275 Notebook Logo
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
