Question about Cub Cadet Lawn Mower Electric PTO Clutch Replaces CUB CADET 7173385A
Blades stay engaged on 2186 cub cadet; - Cub Cadet Lawn Mower Electric PTO Clutch Replaces CUB CADET 7173385A
  • 109 Answers
SOURCE: Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
Posted on Apr 16, 2009
SOURCE: My Cub Cadet 2135 PTO won't engage.
i had the same thing happen
found that the on/off switch had come unplugged from the wire harness just below the switch
had to attach the wires to something underneath so the weight did not pull the wires down and taped the two switches together to prevent it from pulling apart
it needs some kind of clip to hold them together
hope that this works for you
jo
Posted on May 24, 2009
panilling9
  • 284 Answers
SOURCE: cub cadet mower pto will not stay engaged while
be sure your battery is good and your system is chargingning the battery while run
Posted on May 26, 2009
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
  • 146 Answers
SOURCE: cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Posted on Jul 07, 2010
The lever to engage the blades on my Cub Cadet rider LTX 1042 KW has no resistance the the blades do not engage. Did a part possibly break off or come loose?
The blades are engaged electrically via the PTO on the engine shaft.
Check the connector and wiring to the PTO unit, or the electrical plug on the engage switch.
Oct 09, 2016 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
LT1046 cub cadet blown clutch..what caused this with new Pto switchpto switch froze..replaced it still will not engage blades.what could blow the new clutch
Are you sure it's blown? Run two jumper wires from the battery or power side of the starter solenoid and energize the clutch. If it energizes and clicks, that's eliminated. Did you blow any fuses?
Jun 16, 2016 | Cub Cadet Garden
I have a cub cadet 2186 need to get pto off i wont come off crank
you will have to use large pulley puller to get off it should slide off no problem
Oct 06, 2014 | Cub Cadet Lawn Mower Electric PTO Clutch...
Why does my cub cadet die when i engag the blades
Bad pto switch or child back up switch on trans. shorted
Jul 01, 2014 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
May 28, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Cub Cadet-Blades won't stay engaged
sounds like either a saftey switch problem or a bad drive clutch on the pto. usuallly the mower shuts down,not the blades, they may have changed this though. my best guess would be a safety sensor try calling your local cub dealer and talking to the repair person he can shed light on the problem.
Jul 24, 2009 | Mtd Garden
Cub Cadet Lawn Mower Electric PTO Clutch Replaces CUB CADET 7173385A Logo
26 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
