Question about Bernina 1008
1008 hand wheel release jammed - Bernina 1008
2 Suggested Answers
  • 1564 Answers
SOURCE: adjust hand wheel bernina 1008 sewing mmaachine
Barbara. When you removed the handwheel did you find a bit weird looking washer with ears around the outside and to fingers pointing to the center of the washer? If so you probably put that in backwards. The center fingers are slightly bent... they would be bent toward the outside.
Posted on Nov 06, 2012
Why won't the needle go up and down on my Bernina
Your bobbin wind is on. The hand wheel needs to be tightened in order for the needle to sew.
Feb 22, 2015 | Bernina 1008
The wheel release to wind my bobbin on a 1008 will not move. What can I do?
It may be freed up with brute force and awkwardness. If you don't have a gorilla living with you try using a rubber glove to get a better grip on the knurled knob. If that does not work you can escalate to a pair of large pliers and protect the knob by using the glove. If you still can;t get it become angry so you have some adrenaline flowing then attack it with a pipe wrench.
Nov 17, 2013 | Bernina Artista 180
Adjust hand wheel bernina 1008 sewing mmaachine
Nov 04, 2012 | Bernina 1008
Thread caught inside Bernina 1004
Take off the foot, take out the needle. Remove or open the needle plate and the bobbin access plate.
Get out the tweezers and get out all that tangled thread. When you think it's all out... move the hand wheel and see if there is more. Look for thread peeking out from between two pieces of metal, etc. Use a magnifying glass if you need to.
Aug 27, 2012 | Bernina 1008
Bernina 1008 troubleshooting
the best thing to do is have the machine serviced at a sewing machine
shop
May 05, 2012 | Bernina 1008
The thread hangs up inside the bobbin holder
A jammed machine is caused by thread being caught in the hook. Remove the upper thread and the bobbin case, turn the hand wheel towards you (counterclockwise) by hand and remove any thread in the bobbin case area. *Always turn the hand wheel towards you. Turning the hand wheel away from you (clockwise) can cause the machines timing to become unaligned and jam your machine. Also, always make sure the presser foot is in the down position before you start sewing. Sewing with the presser foot in the up position will jam your machine in the bobbin case.
Sep 26, 2010 | Singer 2517 Mechanical Sewing Machine
How do you oil a bernina 1008??
Probably the most important is the inside of the hook ring. Remove the bobbin case and open the hook retainer by pressing the catch on the left-hand-side. The hook can then be removed by just gripping the shaft on which the bobbin was mounted and removing the complete hook. NEVER OIL BEFORE CLEANING. This is the single biggest problem I come across - continually oiling any kind of machine without first removing the old, contaminated lubricant will attract grime. So ... get yourself a few cotton buds and carefully clean around the inside of the hook ring (the circular aperture where the hook was), paying particular attention to the small groove running round the outside. Rotate the handwheel to bring the hook driver round halfway to allow the whole hook ring to be cleaned. Use the opportunity to remove any clogged lint and grime that may have built-up on the underside of the stitch table. WHen you're satisfied it's all clean, then run a very light bead of oil around the groove in the hook ring, turn the hand-wheel fully to bringthe hook driver back to the left-hand-side and oil the other side of the hook ring. Before replacing the hook, take a good look at the groove that runs around the back side of the hook near the edge and thoroughly clean that too, before smearing a drop of oil around that edge with a finger. Replace the hook, making sure its properly seated in the hook ring and click the black plastic cover back into place before replacing the bobbin case. Your machine should now sound a great deal quieter, if you haven't done this for a while !! Good Luck !
Nov 01, 2009 | Bernina 1008
Sewing Machines Logo
22 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
