Question about Medion Computers & Internet
Medion s5612 ? wireless switch
Wireless capability is switched off how do i switch it back on, also keyboard is not working but have connected a polaroid wireless keyboard model HK8028 but has no Fn key ?
SOURCE: Where is the wireless switch on the Evesham Voyager Xii?
Try looking on the physical part of the laptop on the front or around the sides you should see either a small swith that slides or a small button with the typical wireless picture on it try pushing the button in. Also you should check in your network adapters to make sure its on. You can check this by going to Start>Control Panel>Network Connections. If you have anymore questions or need some in detail answers email me back.
Posted on May 14, 2009
kchilder
  • 72 Answers
SOURCE: make sure wireless switch in on
For many of the staelites there is a switch on the right side
Posted on Nov 22, 2009
etaf
  • 779 Answers
SOURCE: I have a Medion notebook S5612 I cannot turn the wireless on
I would check and see if the wireless adapter is seen in the device manager 1st - do this Press the Windows key (bottom left of the keyboard} and at the same time press the R key, now in the search box that appears - type devmgmt.msc Then look at the network adapters - click on the + sign - see if you have a wireless adapter maybe labelled 802.11 or say wireless - Nowhere in the device manager screen should you see any yellow ? or ! if you have then you could download the drivers again from the support site here - http://www.medion.co.uk/ click on "service and support" enter you model and serial number should get all the drivers OTHERWISE if still under warranty - take it back / and or call support
Posted on Apr 13, 2010
SOURCE: I am unable to manually
First make sure that your keyboard is working.. If is not working then fix that issue.. If it works then get into control panel and find windows firewall.. Turn off the windows firewall.. If you have any other firewall also turn it off.. After that try connecting.. If the issue is still not fixed then unistall the wireless drivers from the device manager.. Install a fresh copy from the dell website(www.support.dell.com)... The problem should be fixed...
Posted on Sep 17, 2010
  • 811 Answers
SOURCE: hi I spilled coffe over msi cr360 it boots and
I will try to describe to you in simple terms here. There are a series of screws you will see on the bottom of the lap top. There screws have to be removed all of them before proceeding to clean the computer further. You will also see approx: 3 small screws under the battery when you remove the battery these screws are for the plate that goes across that has the power button etc. Remove those as well then remove the plate and the keyboard be sure to remember where all the screws go back to.
Now the keyboard may need to be replaced it sounds like it was a device that did not make it through the coffee spill and the drying process. There will also be one or two small screws that hold the keyboard down you will see those once you remove the power button plate. Remove those screws carefully take a small screw driver and push the holder for the keyboard cable clip to unlock the clip to remove the cable be very gentle when doing this removal. Observe how it came apart and this will be how to re-install a new keyboard.
You can get new keyboards at Amazon.com this is where I get them at. The process once you get into it and be extremely careful is not that difficult to do as you begin to expose the case pieces once apart. Do not use any wet fluids to clean the parts with. Dry clean only using a soft cloth and take your time.
Enjoy and have fun with it I find it rather interesting more so than a desktop PC repair. Thanks for using FixYa! Do not forget to vote for me John
Posted on Mar 13, 2011
How to activate wifi on medion notebook
Check BIOS, you find Wireless settings.
May 29, 2014 | Medion md40298 Notebook
No fn key on external USB keyboard on MEDION S5612
Right click on the wifi icon on the taskbar by the time, then click Open Network and Sharing Center. On the left side of the window that pops up, click on "Change Adapter Settings". You should see your wireless adapter listed here, and can enable or disable it from here.
Jan 29, 2014 | Computers & Internet
I have spilled water on my laptot and the keyboard doesn't work anymore. I have connected an external keyboard now however, I cant switch on the wireless capability. Does anyone know a way to do t
There may be a switch on the side of the laptop that turns the wireless on and off. Also try pressing and holding the fn key and pressing and releasing f1 or f2. The water spill may have killed the wireless card also. If you still can't get it working, then purchase an inexpensive usb wireless adapter. This will plug into an available usb port and will give you wireles capabilities. You will need to replace the keyboard as well as it was obviously damaged by the spill. Check on ebay, or contact the manufacturer for a replacement.
Hope this helps!
Joe
Mar 25, 2012 | Fujitsu Siemens (AYU0N1090ED00103) PC...
I have a median notebook but cant get wireless capability. what do I do? there is no switch to turn wireless on at the front or back of the computer
i have a median notebook to the wireless switch is above keyboard and is a sensor touch key it's marked with a an icon and is also the f7 key on my keyboard check your manual for a description or take a closer look at the keys
Nov 10, 2010 | Medion md40298 Notebook
Can't find switch to turn on wireless capability on medion akoya netbook.
some times it at the front some time its on the F buttons just press the fn + F? buttons together to switch on not sure which F button it is but it should have a logo of some discription on it.
hope this helps.
Apr 28, 2010 | Medion md40298 Notebook
I have a Medion notebook S5612 I cannot turn the wireless on. My brother in law has the same model and has no problem he just uses the Fn and F8 keys. Is there a fix or should I take it back.
Apr 03, 2010 | Computers & Internet
Medion Akoya Multimedia notebook - wireless capability
I believe on the medion you have there may be a switch on the front or side to turn on the wireless. That or FN key and F1.
Mar 19, 2008 | Computers & Internet
Medion MIM2120 laptop
press the blue button botton left of the keyboard that says Fn (function)
at the same time press F1 this will enable the laptops wireless connection, this should be shown by the light 2nd from the right
Dec 04, 2007 | Medion md40298 Notebook
press the fn key then i think its the f5 key but which ever f# it is it has kinda like wavy lines on it read the instruction manual too it does tellyou
Nov 18, 2007 | Medion md40298 Notebook
Computers & Internet Logo
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
