Question about Ovens
Sarena sk400x built under double oven
The oven has broken and we want to replace it but cannot seem to find another oven that fits in the space, please can anyone help?
3 Suggested Answers
SOURCE: how do i remove a built in oven?
i need audio driver intel D945gcnl
Posted on Feb 16, 2009
  • 109 Answers
SOURCE: SARENA SK400X BOTTOM OVEN WONT WORK BEACAUSE LED TIMER HAS BURNT
Look for the relay on the timer and the 2 wires that goto it.
Basically short the 2 wires that goto the relay and job done.
If there are more than 2 wires be careful as you may blow a fuse if it's connected incorrectly.
Posted on Jun 18, 2009
Defy slimline eyelevel oven installed in cupboard.
Assuming it is an electric built in or built under oven, these are commonly fitted into a dedicated cupboard (oven housing) that matches the other kitchen units and typically little or no facility for ventilation is provided.
Electric ovens are usually so well insulated and covered with reflective foil the need for ventilation is minimal, especially when a standard size oven is fitted into the correct standard sized housing as it will provide an air-space of an inch or more all around.
It can be expected the housing near the top of the oven will become warm after a while and the shelf above likely to become warm enough to soften a candle but if it gets hot enough to actually melt a candle I think that is rather too hot. The addition of additional insulation and reflective material should improve matters greatly.
I suggest you approach the guy who fitted the oven if it was professionally fitted. It would have been his responsibility to only fit a suitable appliance and if additional ventilation was required he should have advised you.
I believe I have seen some oven housings with a slim grille over the oven and it is probable there would have also been a slot cut at the rear and perhaps a short piece of trunking to carry warm air away from the space directly above the oven.
Mar 30, 2016 | Ovens
Will a GE built in oven JT3000DF fit in the space that has a Kenmoore build oven in that space at this time 9114105559 part number
Simple. Measurements. Unless i'm missing something here.
Take present oven detailed measurement, compare it to the newer oven's detailed measurement.
Feb 03, 2015 | GE 30" Built-In Single Electric Wall Oven...
Heating element broken
What is the model number?
Jan 19, 2013 | Ovens
Have a Kenmore Elite Built-In oven 790.4812. It's a double oven. Was working fine. 1 year old. Wife self-cleaned upper oven for first time. Oven does not work now. Sears Repair guessing that the oven...
It has nothing to do with the tight fit.
It has everything to do with self-cleaning on ovens.
The thermal fuse blows due to extreme temperatures.
Replace the fuse to use the oven.
Use an oven cleaner to clean the oven OR replace more fuses in the future.
Jul 25, 2011 | Ovens
Jun 18, 2009 | GE Built-In 24" Double Electric Wall Oven
Replacement for built in oven/microwave
Hello tippett_631
Welcome to fixya,
You said, ,
22 years ago you built the house you are currently living in. The above oven/microwave oven was built in. You are interested in replacing this unit with a new unit but it must be the same size. ? by the way i You would be happy with a double oven versus the microwave/oven duo. You have measured across the front of the unit and it only measures 26" across. Any assistance you could give us would be greatly appreciated.
I can help you!
The front is 26 inches.
And how high is it from the top to bottom?
Also when I sell a wall oven I always send out the installer to check the hole or cutout size.
Most of the time no wall oven fits with out at least one cut!
Do you have any room to cut a little on all sides?
What is your model number now. And what color do you want now??
I will send you some GE wall oven models and sizes so you can check your self if it will fit. usually they have to cut at least one side to fit it in the old hole!
Sep 25, 2008 | GE Ovens
Ovens Logo
27 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
