Question about Ace Hardware OAKBROOK COLLECTION DESIGNERS CHOICE TUB/SHOWER
I have hot water but no cold water . tub and shower faucet has anti - ccald tedhnotgy
4 Suggested Answers
  • 15 Answers
SOURCE: Installed a new oak brook collection tub and
Most all shower valve's these days have anti-scald protection. There are 2 ways that this protection is accomplished; temperature control device or a pressure balance device.
If your's has a pressure balance device, both cold and hot water lines that supply your shower valve must be fully opened. If you only turned on one, water will not flow from the shower valve.
If both hot and cold supplies are fully opened and you soldered copper pipe to the shower valve, it is possible that excess soldered is was sucked into the valve and could be obstructing the valve's outlet.
Posted on Jan 25, 2010
packrat1948
  • 528 Answers
SOURCE: what size screw goes in the tub and shower chrome
Well Ace has these faucet made for them buy numerous manufactures and knowing which company made this one it hard to say. I would go to Ace and have them investigate this for you. Sorry but there is just to many variables here to be able to give a defiant answer to this question.
Posted on Feb 06, 2011
  • 9 Answers
SOURCE: I put in a oakbrook tub and shower faucet and its backward is it possible. but the hot is on the left side and the cold is on the right. but the face plate says the opposite? is it possible that the f
Typically the Hot Should show on the left and the cold on the right when facing the faucet. If the plate reads the other way, I would try exchanging it first or utiize flexible connectors and cross them.
Posted on Jun 16, 2012
No hoy water coming out on Moen shower faucet?
If you have hot water elswhere in the bathroom but not the shower head then the diverter valve in the handle for the tub is most likely bad and needs replaced. The diverter is also called an anti scauld valve, it mixes the hot and cold water to prevent scaulding you in the shower
Oct 02, 2011 | Moen Home
When i move shower valve to hot, the water pressure drops. There is more cold water than hot. I have changed my moen valve before and this still happens. Good water any where else in the house including...
probably have a kink on how water line feeding valve..if possible to cut drywall bhind tub valve and inspect pipe at bottom plate...moen faucets are equipped w/ anti scald device, pressure balanced (newer models) and this could cause cold water to overwhelm hot water...
Nov 20, 2010 | Moen 3175 Legend One Handle Shower Faucet...
No hot water
need to adjust anti-scold when unit shipped is set for cold if u have install paperwork that has info on how to adjust if not remove handle and on valve stem will see blue and red plastic clips slid them forward and adjust till hot water is adjusted to liking
Jul 25, 2010 | Moen & One Handle Tub & Shower Faucet
Have the moen 82300 2300 series positemp tub and shower faucet. can i make this a nonpositemp by replacing the cartridge? We are unable to regulate cold or hot temp. no matter where the handle is the...
Temperature regulating faucet, aka anti-scald, are fast becomring a requirement under local building codes making it, technically speaking, a building code violation to alter the faucets function (assuming someone reported it the loccal buildings dept. That said the function of the anti-scald faucet cannot be altered. You should contact whomever installed the faucet to come back and adjust it so the temperature is more suited to your needs.
Jun 20, 2010 | Moen & One Handle Tub & Shower Faucet
& One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
May 16, 2010 | Moen & One Handle Tub & Shower Faucet
Just had a contractor give me an entire new bathroom. The Peerless Single Handle Tub And Shower Faucet will only go from 90 deg down on the cold side to straight up. it want go to the hot side. What is the...
if u have the paperwork for the unit--in it will explain how to adjust the anti scold settings single handle units are shipped in cold setting u have to adjust the hot -- remove handle and on shaft will see blue and red clips adjust the red till hot water is to ur liking replace handle
May 18, 2010 | Peerless Industries Peerless& Single...
When turning on the shower faucet there is no hot water.
adjust ur anti scold the setting is set to low when single handle shower units are shipped they are set in cold mode for safety ur install/instructional paperwork explains such and also advises on how to adjust---remove handle and on shaft will see a blue and red plastic clips that are adjustable slide towards u and move red for more hot water test water continue till comfort level is reached for hot water
Mar 24, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
No cold water
Behind the handle there is a dial to adjust water temp cold and hot you can remove it and replace it a 1/4 turn til you can get both cold and hot. It is a anti scald it may have been put in wrong.
Make sure the cold water line is not blocked coming to valve and is open .
Mar 15, 2010 | Danze & Single Handle Tub And Shower...
Installed a new oak brook collection tub and shower faucet and no water comes out.
You may have to disassymble the faucet to see if there is something that is stuck in there or that the assymbly internally is stuck in the closed position.
Mar 19, 2009 | Ace Hardware OAKBROOK COLLECTION DESIGNERS...
Ace Hardware OAKBROOK COLLECTION DESIGNERS CHOICE TUB/SHOWER Logo
54 people viewed this question
Top Ace Hardware Home Experts
Donni Steen
guitar zan
Are you an Ace Hardware Home Expert? Answer questions, earn points and help others
