Question about Sony PlayStation 2 (PS2) Console
Disc tray is not turning
I hve the 2nd edition of playsttion2 the thin model I have not used it in 2 years and for some reason when I insert a cd in the disc tray is does not turn
  • 709 Answers
Hi boxingbutch Several solutions could solve this problem. 1. you disc drive motor is obstructed by having something like hair wrapped around the spindle. Clean it out to recover. 2. The Spindle motor is burned up from having something like hair wrapped around it, and needs replacing. See www.richspsxparts.com. 3. A fuse is blown. Send your PS2 to www.playstationclinic.com for repair.They will repair it for a resonable price. Hopefully one of these will get you back in business.
Posted on Oct 07, 2007
My PS2 wont spin the disk or play it and when ever I turn it on it comes up with Browser or System Configuration
Hello
The problem seems to be your laser, It sounds like it is not reading the disc.
You need to do 1 of 2 things.
1st if you cam give a quick strong blow into the disc tray when it is open, to remove any dirt and dust from the laser area.
2nd If you can get hold of a laser cleaning disc and use this to clean your CD/DVD drive. Just insert the disc and let it play for 5 mins. You can get these discs from almost anywhere, try your local supermarket.
Hope this helps
Mar 06, 2011 | Sony PlayStation 2 (PS2) Console
CD deck
That means that there is a mechanical error concerning the tray gears
Oct 11, 2008 | JVC UX-S57 CD Shelf System
COPT CD
I think you just answered your own question... Did you say that when i you put in a blank disc, it says blank disc? Thats correct. And whats is a B-Deck?
Oct 06, 2008 | Sony RCD-W500C 5-Disc CD Recorder
CD-R drawer won't open. CD is in drawer.
there are different reasons for stuck up disk tray
1. load belt is worn out already
2. driving gear for mechanical loading disc tray has broken teeth.
3. cd got stuck up between the loading disc tray and the plate holder.
You will need unplug your device first and then unscrew the cover of your unit and find it yourself to know what causes it not to open.
once the cover is out, the mechanical loading disc tray will be exposed.
1. remove the stuck cd
2. plug the unit and turn on, to get access the belt, wait for the disc tray to move to the pull out position, then unplug your device.
3. plug the unit and turn on, if the disc tray do not move, use your finger to move the tray and see which gear is broken.
belts are available from this site. just have to measure the correct diameter of the belt in your unit
http://electronics.mcmelectronics.com/search.php/ui.php?lastSearch=belt+cdr201&lastDims=4294967285&Ntt=belt&ctl00%24ct1%24RefineButton=Refine
Feb 16, 2011 | Classic Electronics CDR201 CD Recorder
Cd drawer will not open
Please try these.. hope any one might open the tray..
1. use a thin needle to insert in the pin hole near the CD tray.
2. my computer--> cd drive--> right click&press eject
Feb 28, 2010 | Dell Dimension 3100 PC Desktop
Dvd drive wont eject the dvd.
find a thin stick but must be verry thin.  you will see a small hole in DVD uniit.  put the stick in it your dvd will eject.
May 29, 2009 | Dell Studio XPS 16 Notebook
My cd rom tray does not open
hit it on top of it or the casing and it will open. but this is not the good way but i have the same problem i use this
May 20, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Sony DVP-NC600, CD/DVD Player
Hey llacy2,
There may actually be a number of reasons that this may be occuring, and there are a couple of things that you can try in order to resolve this type of problem.
You may wish to first clean the discs being placed in the DVD tray with a soft cloth. Any kind of dirt, scratches or cracks on the disc may cause the unit to immediately reject it. Once the disc has been cleaned, try to insert it again. If the disc is rejected a second time, you may need to try a different title.
If the problem still persists with more than one disc, the manufacturer has suggested both turning the DVD player off and fully unplugging the player (power cord, other connections and all). You may wish to allow at least 1 full minute before reconnecting the player and AC adaptor, but if the problem isn't resolved after doing so you may need to contact a repair facilty for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
May 20, 2008 | Sony DVP-NC600 Multi-disc DVD Player
My Sony PlaySatation2 console wont read any games on PS2 discs.
Check this web site out, this will help you, this problem happens alot so dont worry you should be able to do it yourself. http://arstechnica.com/articles/paedia/hardware/ps2.ars/1
Mar 12, 2008 | Sony PlayStation 2 (PS2) Console
Sony PS2
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. Remove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the CD tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the CD area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. Remove the little white disc from the CD tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and you’re in business.
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact Repairtech@playstationclinic.com
Nov 07, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
60 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
