Question about BRAZILIAN PRO All Natural Diet Pil Lw/Raspberry Ketones & Green Coffee 20 Pills
Can I take GCBX, Coleanse and Cellan together and when?
I have bought theses three supplements on line and am not sure if I can take all three combined or should I just try GCBX and Coleanse could you help me than you
What is the best weight loss supplement for men?
Weight loss supplements are drugs, products and pills that help to fight obesity in both men and women. These help many people manage their weight effectively and efficiently. In an ideal situation, supplements are added on to an exercise routine. One problem men have with working out is that the results are not typically as fast as men want them to be. A benefit men can see with working out is increase in longevity. Inactivity is very likely to cause diseases that may prevent a man from getting into good overall health.
A weight loss supplement that has grown in popularity is the Acai berry. It has been studies and formulated with ingredients to aid and assist in weight loss for men. It contains necessary fatty acids, which help with muscle repair and cellular reproduction when a man wants to add muscle and lose fat at the same time.
Some of the best weight loss supplements for men today include whey protein, creatine, caffeine, daily vitamins and protein shakes. Many of these can be found in local supermarkets and health food stores. These supplements can also be bought online and shipped right to your home.
1. Whey protein. Provides a higher amount of protein and helps to build muscles.
2. Creatine. This has been known to provide an initial weight gain, but men have reported a decrease in stomach size as well.
3. Caffeine. Used to aid in burning extra body fat as well as curbing appetite.
4. Daily vitamins for men. These not only provide the body with what is needed each day but can also increase energy.
5. Protein shakes. These shakes often provide good nutrition and saves time.
Note: By researching and comparing the best Weight Loss Supplements (Manly Solutions) in the market, you will determine the one that is safe and right for you.
Feb 19, 2017 | The Health & Beauty
Tip
Certain Medication That May Affect Your Stomach and Why
It's a well-known fact that we all surely know, eating foods that are wrong will affect your gut and digestion health. Effects can vary from mild to being very bad. Usually, most people consider refined carbs, milk produce and sugar to be the culprits. However, there are a great variety of things which may affect your stomach and cause problems.
Furthermore, certain supplements and medications might also be the reason for stomach problems. Stomach problems you may experience can include constipation, nausea, and/or cramps.
Herewith, some of the culprits that are very common in causing issues. Plus, what to do for safeguarding your stomach when you use them.
Antibiotics
Generally, it is said that antibiotics are used to kill bacteria that is bad causing you to become ill, however, it is not the only thing that antibiotics can do. Additionally, it can kill millions of different bacteria's that exist inside the stomach. Many of these form a part of the caring bacteria ecosystem which assists us to digest food, process enzymes, and vitamins. These are also required to keep your body in excellent health. If these bacteria get eliminated, you may develop cramping, diarrhea, bloating, and excessive gas.
Thus, it's better to limit the intake of antibiotics as far as possible, though if it's absolutely necessary, you should try to boost the stomach by replenishing the good eliminated bacteria. Try supplementing with pro-biotic which contains some bacteria strains like Lactobacillus and Bifidobacterium. Otherwise, consume foods rich in pro-biotic, such as yogurt.
Supplements of iron
A very common supplement of iron is ferrous sulfate, yet, it is also famous for being a cause of constipation. The reason for this is due to changes of the bacteria in the stomach that can slow your intestinal muscles down, plus cause your gastrointestinal tract to dry out.
Frequently, this problem can decrease as time goes by, but it's possible to speed it up by slowly increase your intake of fiber. Along with this increase, it is suggested to include some activity each day, and drink extra water. Additionally, you may also try to spread the dosage of iron supplement throughout your day, rather than drink everything at the same time.
If you still experience problems after these changes, be sure to ask the doctor to provide you with an alternative, and though it might not be as effective, you won't be constipated anymore.
Pills for birth control
It is an unfortunate fact that estrogen may irritate your stomach's lining. Typically, this may cause cramping, nausea, or pain in the abdomen. It's also been proven that by using the pill, your risk might be 3 times higher for developing an inflammatory disease of the bowel. Although experts are not sure about the reason, they suggest it can be the estrogen that affects the immune system.
If taking the pill, it's wise to take it together with your food or rather switch to a contraceptive that is non-oral. These can include a patch that should also ease the discomfort of the stomach and general nausea.
To prevent inflammatory disease of the bowels, you should eat a diet that is healthy with sufficient vegetables, fruits, fermented foods, as well as stop smoking which may increase the risk. Supplements of collagen are believed to help with healing your stomach's lining because of their amino acid content.
Rx and OTC antacids
H-2 blockers, OTC antacids, as well as proton pump inhibitors, can all help for easing your acid reflux. These do so through lowering your stomach's acid amounts. However, this relief might cost you dearly. This is because acids in the stomach break the food you eat down into manageable substance for the body to use. Therefore, having a lesser amount of acid, the digestion along with the ability of the body to absorb the nutrients can suffer.
When you use OTC antacids only now and then, it won't be a problem, although, if you need to take it regularly over a long time period, you can pick up problems. Speak to the doctor about it and ask whether it's possible for him/her to recommend different ways for balancing meals when you use the medication in order to improve the absorption of nutrients or if they can suggest other supplements.
Antidepressants
Most of the time, antidepressants help to increase your mood so you can feel good. This is through increasing the hormone known as serotonin. The problem with this is that your stomach has an overload of serotonin receptors. Now due to this extra activity, it may cause stomach problems. It can include diarrhea, nausea, and constipation. Certain antidepressants, such as Tofranil and Elavil can also block your neurotransmitter receptors acetylcholine, and cause some constipation.
You should be active, stay hydrated, and eat sufficient fiber which should help you to keep things moving. Granting, due to underlying mechanisms of these side effects that are neuro-chemical based, no ordinary method is available to prevent or reduce them. It's possible that these issues may only last for some weeks after starting with the medication. Nonetheless, if it becomes constant, the doctor may prescribe some alternative antidepressant medication.
on Dec 13, 2017 | Miscellaneous
Who can benefit from supplementing with beta alanine?
Pretty much anybody who trains for endurance or strength can benefit from supplementing with beta alanine. This includes bodybuilders, runners, boxers, military personnel, and more.
Feb 04, 2013 | Health & Beauty
What are the benefits of supplementing with l-arginine?
  1. L-arginine and L-lysine. The combination of these two amino acids together before exercise and sleep has shown to increase growth hormone production by up to 700 percent. Take 3 to 5 grams for optimal results.
Are there different types of magnesium supplements?
Yes, there are many types of magnesium supplements that can taken either orally or applied directly to the skin.
Oral magnesium supplements:
Mineral salts
Magnesium acid complexes
Magnesium chelate
Transdermal magnesium supplements:
Magnesium oil
Magnesium gel
Magnesium bath flakes
Magnesium lotion
For more detailed information on these types of magnesium supplements, take a look at these websites: http://www.ancient-minerals.com/magnesium-supplements/, http://www.livestrong.com/article/251947-types-of-magnesium-supplements/, www.globalhealingcenter.com/natural-health/types-of-magnesium/, and www.ehow.com/about_5130706_types-magnesium-supplements.html.
Does the FDA check dietary supplements before they are sold?
The FDA does not check dietary supplements. It is up to the supplement's manufacturer to make sure their product is safe and that the list of ingredients on the label matches the ingredients found in the product.
According to the FDA's website: "Generally, manufacturers do not need to register their products with FDA nor get FDA approval before producing or selling dietary supplements.* Manufacturers must make sure that product label information is truthful and not misleading. Under the FDA Final Rule 21 CFR 111, all domestic and foreign companies that manufacture, package, label or hold dietary supplement, including those involved with testing, quality control, and dietary supplement distribution in the U.S., must comply with the Dietary Supplement Current Good Manufacturing Practices (cGMPS) for quality control."
Also, if you notice, supplements always contain the following sentence below the nutrition facts and other information after the nutrition facts: "These statements have not been evaluated by the Food and Drug Administration. This product is not intended to diagnose, treat, cure, or prevent any disease."
Are there different types of fat burning supplements?
The six different types of fat burning supplements are given below:
a. Blocking Cortisol Secretion
b. Curbing your appetite
c. Thermogenic fat burners
d. Blocking fat accumulation
e. Blocking carbohydrate accumulation
f. Regulating thyroid hormones.
To get full guidelines for buying a best fat burner supplement, you can visit Weighted clothing.
Who tests the content of the supplements?
The supplement companies are required to test their own products and make sure that the supplement facts and ingredient list are correct. The FDA does not evaluate supplements and it is under the sole responsibility of the supplement companies to make sure that their supplements are safe.
Is there a problem using supplements while I'm giving him medications?
In most cases there shouldn't be any problem using them together although there are some chemicals that are disastrous when they work together. My advice is to visit your veterinarian before you give it to your pet.
Aug 09, 2012 | Pets - Others
BRAZILIAN PRO All Natural Diet Pil Lw/Raspberry Ketones & Green Coffee 20 Pills Logo
69 people viewed this question
Top BRAZILIAN PRO Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a BRAZILIAN PRO Health and Beauty Expert? Answer questions, earn points and help others
