Question about Electric Garden
Fitting spool on strimmer met25-2 - Electric Garden
4 Suggested Answers
thydzik
  • 86 Answers
SOURCE: How do you fit a new spool?
refer to here for generic instructions of replacing the wire/string on a trimmer.
http://wiki.answers.com/Q/How_do_you_replace_a_weed_eater_trimmer_line
have a read through, it may help assist you.
Posted on Jul 21, 2009
budgie140
  • 502 Answers
SOURCE: How do i fit the spool on my black and decker
guide the two strings thru the holes in the outer ring,then push it down into place,and screw knob on
Posted on Jul 04, 2010
robin_hackne
SOURCE: purchased a gardentec petrol strimmer a while back from netto store...where can i get a spool replacment to fit my strimmer.
It's a ryobi strimmer re-badged- check ebay...
Posted on Oct 09, 2012
Restring a pgt300 performance power strimmer, it has a white casing which does not come off preventing me from adding more line
There should be 2 plastic tabs which you have to push in, this removes the wider outer base cover of the strimmer spool, giving you access to the bump cap and line spool.
Depending on the style you have, one looks to be a whole replaceable spool unit, one looks like a re-threadable spool.
If you find this useful, please click the 'helpful' tab. Thank you
May 14, 2016 | Garden
Strimmer instructions
some strimmers have two tabs on either side of the spool which yousqueeze while pulling up.
Sep 07, 2014 | Garden
Purchased a gardentec petrol strimmer a while back from netto store...where can i get a spool replacment to fit my strimmer.
try Lowes or any Agway, and if that dowsn't work, try checking on line with your type of trimmer.
Apr 22, 2012 | Garden
How do i fit the spool on my black and decker strimmer model no GL535
Jun 21, 2010 | Black & Decker String Trimmer Cordless 12"...
Where can i buy a replacement spool
do you mean the spool or the trimmer 'wire'? the wire itself can be bought at most DIY shops and then fitted to your spool, which is removable. if you need the spool, contact the maufacturer, or do a web search.
Sep 12, 2009 | Garden
Strimmer cord keeps breaking
the eyelets on the trimmer head may be worn and cutting the line ..look for groves in the eyeleys may need to replace the spool
Sep 01, 2009 | Garden
How do you change the cord on a b and d strimmer
Hi, W/D here.
Pull the spool straight off, out of the head. Look at the bottom of the spool, you'll see arrows indicating the direction that the line should be wound. Now, look at the spool. You'll see that there are actually two spools, made together. In the middle part of each spool, you'll see a small hole. There should also be a notch in between the two spools.
OK. Starting with the inner spool, insert your line into the hole about 1/8", and wind in the direction of the arrows. When you have wound the line to the diameter of the divider between the spools, stop. There is a very small notch on the bottom of the spools that is 180 degrees from the notch in between the spools, and at the bottom edge of the spool that you are winding. Click your line into that notch. Leave about 6" of line out past the notch, and cut it off from the pack of line that you are winding from. Now, wind the outer spool the same way. When full, you'll guide your line thru the notch between the spools and into the small notch at the bottom of the inner spool. Leave another 6" tail, and cut it off.
Take the two tails of line while holding the spool,and insert one into each grommet on the machine head. Align the line notches with the grommets, and press the spool into place. You should feel it click into place. Now, you want to tug on the line tails to pull them out of the notches. You're done!
I have one final bit of advice, and you don't have to do it this time...just keep it in mind... The head will sometimes be stubborn in dispensing the line. I find that occasionally putting a little graphite into the hole where tha spool fits onto the machine helps the line advance part work much smoother, and it keeps the head from sticking.
Best regards, --W/D--
Aug 14, 2009 | Black & Decker Garden
Jul 21, 2009 | Black & Decker Garden
Got a Black & Decker GL301 strimmer but have lost instruction manual. dont know how to fit new cutting wire
Go to Homebase, B&Q, Ebay or your local hardware shop and buy a new spool, ALM part number BD032.
Jun 01, 2009 | Black & Decker Garden
How do you fit the nylon line to the strimmer part.is there a diagram or a video somewhere.my line keeps coming out everytime i turn it on.thanks
try taking off the spool at the end of the trimmer and wineing the line around the spool and putting the spool back on the end of the trimmer
Apr 06, 2009 | Garden
Garden Logo
14 people viewed this question
Top Electric Garden Experts
dannydoesita
JohnPaul Robertson
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
