Question about Panasonic Televison & Video
Panasonic NV - SD530AM VCR user manual - Panasonic Televison & Video
  • Panasonic Master
  • 1,511 Answers
None available in the year 2015
Posted on Jan 22, 2015
SOURCE: Set the clock on my Panasonic NV-J11 HQ VCR
Hey there - I've got the exact same model VCR; although I've lost the manual as well, I've been using it for so long that I
can usually remember it all from heart:
To set the clock
1. Open the flip-down lid, push [CLOCK] button.
For each of the steps below, use the white-labeled [+] and [-] tracking buttons to increase/decrease each number.
2. Two digits should be blinking - this is the year (last two digits only) - adjust and push [NEXT] when done.
3. Two digits, with a "D" next to them should now be flashing - this is the month (1=January thru 12=December), adjust and push [NEXT] when done.
4. Two digits, with a "M" next to them should now be flashing - this is the day-of-month (1..31), adjust and push [NEXT] when done.
5. The time should now be displayed, with hours flashing - adjust and push [NEXT] when done.
6. The minutes of the time should now be flashing - adjust. When you push [NEXT], this will complete the date-setting and start the seconds-of-the-minute off at zero - handy for synchronising to an external time source (I recommend using the
Teletext broadcast clock if available - you'll usually find your recordings will start right-on time when you do this, depending on your TV station).
7. If you make an error at any step above, push [CLOCK] to exit clock-setting mode and start again.
Depending on your model of VCR - the clock may either persist through power failures (backup battery) or may have to be reset next time power is lost. Mine doesn't seem to have a backup battery.
To program the VCR for timer-recording: There are two modes, Timer Record (start and finish recording at arbitrary times in the future), and OTR ("One Touch Recording", start recording right now and finish at a set time in the future).
*** Timer recording ***
There are eight programme slots (numbered 1-8 on the display), each programme slot has an individual channel and start/finish time associated with it. Programmes can be scheduled up to 1 month in the future.
Push [PROG/CHECK] to cycle through each slot (after the eighth slot, it will return back to normal operating mode).
When you want to set a programme, push [PROG/CHECK] until you find an empty slot (date/time will be all dashes). Then do the following:
1. Channel should be flashing - set this using white-labeled [+]/[-] tracking buttons and push [NEXT] when done.
2. Date should be flashing (defaults to today), use [+]/[-] to adjust starting date and push [NEXT] when done.
3. Set the starting time ("ON" should be lit next to time) (defaults to now), use [+]/[-] to adjust starting time and push [NEXT] when done.
4. Set the finishing time ("OFF" should be lit next to time) (defaults to starting time), use [+]/[-] to adjust and push [NEXT] to complete the setting of this programme. After this, you'll be returned to the start of setting the next programme (the unit will also beep five times to confirm you have a valid programme set).
If you make an error (or you need to clear a programme slot that already has a programme set), hold down the [-] and [+] buttons for three seconds until the starting time/date becomes all dashes.
When you're done with setting your programme(s), keep pressing [PROG/CHECK] until you exit into normal operating mode, then push the [TIMER REC] button to activate the timer; this will put the VCR into timer standby mode, and the orange clock icon should be lit solidly on the display. There should also be a number (1..8) lit for each programme that has been set, but is still yet to run. Make sure you have the tape inserted and positioned in the right place when you do this.
After timer standby mode is activated, you can then push [PROG/CHECK] to review the individual programme slots; each push of [PROG/CHECK] will cycle through each slot (the display will time out in 10-15 secs).
To get out of timer standby mode (either when after the programmes have run or if you've made an error), push [TIMER REC] again - this will return you to normal operating mode (where you can fix errors if need be). Programmes that have run to completion should be automatically be cleared.
*** OTR (One Touch Recording) ***
This will start the tape recording immediately (good for when you have an unexpected distraction or sudden change of plans) and have it stop at a later preset time. The OTR mode only has one programme slot, unlike timer record.
1. Insert tape, have it positioned where you want to record from. Set the channel to the one you want to record from.
2. Open the flip-down lid, look at the bottom-right corner of the array of buttons inside.
3. Push the green-labeled [OTR +] button; this will start the tape recording instantly (the red "OTR" indicator should be lit on the display).
4. The stop time should also be displayed - use the [OTR -] and [OTR +] to adjust the stop time. When you're done, that's all you need to do (you can adjust it any time later).
To abort OTR mode (ie. if you start it by mistake, or want to stop the recording early), push the main [VTR] button to stop the recording. Yes, that's right - turn the whole thing off, it'll leave you in standby mode.
Hope this helps!
-- Bryan R.
Posted on Jan 12, 2009
techcrazy
  • 72 Answers
SOURCE: Operating manual Panasonic NV-HD610 VCR
Hi this is tech crazy
May i help you on this issue .I have given gist of the manual.so that you save enough time by just having glance at it
The Panasonic VCR/VHS has an RF in and RF out sockets, it also has one red and one white audio out socket. It also has AV1 and AV2 sockets which are rectangular with many pin sockets which i believe are for scart cables. The video also has a switch for RF On, Off and Off(test Signal).
The sharp LCD has one an antenna in socket, AV1 (Red, Yellow and White sockets), S-Video, AV2 (Red, Yellow and White) and Component Y, Pb, Pr and Audio (Red and White)
To connect these two together in order to watch old video tapes on the television
take the out rf socket from the vcr and screw it on the sharp antenna and make sure that you have the tv on channel 3 or 4 which is normally the channels vcrs send the signal 2 and the rf should be on
Hope this solution helps you
Please do rate me Sir/madam
Posted on Feb 04, 2009
  • 259 Answers
SOURCE: Need copy of operator's manual for Panasonic VCR
hi, try http//tv.manualsonline.com/mfg/panasonic/nvsj400html
Posted on Mar 04, 2009
Grubhead
  • 5056 Answers
SOURCE: What does Jet navigator mean?
I believe it is a way of finding recordings the machine has made. Say you have recorded 5 TV shows on a tape. By pressing the search button or the onscreen message box, it will go and find each recording start and it plays it back at high speed (hence jet) for around 20 seconds then jumps to the next one and so on... This is so you can work out if you want to watch the various recordings.
Posted on Jun 16, 2009
Grubhead
  • 5056 Answers
SOURCE: Where can I get an Instruction Manual for a
Have you tried the Panasonic website they have PDF's free of many models.
Posted on Aug 01, 2010
I want a users manual for Panasonic NV-FJ800
Try the Panasonic website they have free PDF's of them.
Sep 26, 2011 | Panasonic NV-MV20 VHS VCR
Panasonic =iv NV-MV40 , how to set the clock please
You can download the user manual for free from the Panasonic website.
Apr 03, 2011 | Televison & Video
I have acquired a Panasonic NV-FJ620B-S Video Cassette Recorder which has 2 x scart sockets on the back. 1 marked AV2 DECODER/DECODEUR(EX) the other AV1 (TV). The AV1 scart connector works fine on the TV...
Have just visited the Panasonic UK website and the User Manual for the Panasonic NV-FJ620B-S is available free. It lists on page 11 all the details. I'll e-mail it you Tom to see if it helps.
Jan 25, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Manual for VCR MODEL NV.SJ216B.S SERIAL NOF2A01396 MANUAL REQUIRED
You should be able to download the user manual for free from the Panasonic website.
Dec 10, 2009 | Panasonic PV-V4022 VHS VCR
How do i plug this in
Try the Panasonic website for the user manual. A universal remote not a cheap one, should do the job.
Apr 04, 2009 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Televison & Video Logo
44 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
