Question about Whirlpool Home
Reset moen iodigital controller - Whirlpool Home
Moen drain adjustment
there is a rod under your sink which controls the travel of the stopper it needs to be adjusted for shorter travel.
Aug 26, 2017 | Moen Plumbing
My Moen kitchen faucet seems to have a flow control in the spigot that fell out. Can I reinstall it myself and how?
Moen has great customer support. Yes, you should be able too. Call 1-800-buy-moen and they will talk you thru it on the phone.
Jan 22, 2017 | Moen Plumbing
Power outage how do i reset a moen digital thermostatic shower valve
If you're talking about the ioDigital Vertical Spa controller, mine never comes back up after a power failure (status LED off) until after I've unplugged and re-plugged the DATA cable. To do this you have to take the cover off the controller in the wall cavity by removing the four phillips #2 screws to expose the DATA connector inside. Then it's just like unplugging and replugging a telephone or ethernet cable.
Jul 04, 2012 | Home
I need a piping diagram for a Moen s3371 and a s3600 valve
http://www.moen.com/shared/docs/product-specifications/s3600sp.pdf
http://www.moen.com/shared/docs/instruction-sheets/ins1281c.pdf
http://www.moen.com/shared/docs/exploded-parts-views/s3600pt.pdf
http://www.moen.com/shared/docs/exploded-parts-views/s3371pt.pdf
If you did your rough in for the hot water coming up from the left of the valve as you face the control and the cold on the right, that is traditionally correct.
Jan 15, 2012 | Moen Plumbing
I am having a leak with the hydrolock going to the sprayer hose on a new Moen faucet. I have taken it apart a few times to make sure it's together right, but I can't get it to stop leaking.
Three years ago, I installed a Moen kitchen faucet with sprayer
in one of my rental units. Moen twice sent replacement
Hydrolock kits, as I couldn't get them to seal. While waiting for the Moen parts to arrive, I used a short length of heater hose purchased at AutoZone, held on by two small hose clamps. After all three Hydrolocks had failed to seal, I just left the heater hose in place. Three years and no problems. ..and no more Moens, either.
Sep 16, 2011 | Moen 87530 Touch Control Single Handle...
I have a MOEN 4600. The cartridges are plactic. Cold water runs fine but hot water when faucet is put together, only runs for a second then I hear a bit of a clunk then the water only comes out a bit. What...
From Moen's trouble shooting discussion:
Typical Cause
Debris or an obstruction in the balancing spool is causing it not to move freely within its housing. In some models, a lack of pressure feeding the hot and cold will be the cause. The valve also may need to be calibrated.
Solution
First, verify the hot water system in the home is operational.
Second, it is essential to identify the model of your faucet. Please view our Find Your Product section to determine your model.
For Posi-Temp models:
The 1222 cartridge would need to be replaced and the valve body would need to be flushed and cleaned.
For Moentrol models:
Inspect the 1423 balancing spool. This will appear on the front of the valve body, either to the right or above the cartridge. It will look similar to a large flat head screw, and it will be brass in color. A large flat-bladed screwdriver can be used to unscrew the balancing spool from the valve. There will be a spool inside this piece, and it needs to move freely inside of its shell. If the spool does not move freely, then the 1423 balancing spool will need to be replaced.
For ¾" ExactTemp models:
Note: For ½" ExactTemp valves refer to original service manual
  1. Verify the shut off valves (check stop kit) are in the open position. This will be a screw in the center of the check stop kit. These should be unscrewed counter-clockwise.
  2. Check to see if the hot and cold lines are reversed. If the supply lines are accessible, feel the temperature of the pipes. The cold supply must be connected to the cold (right) side of the valve, and the hot supply must be connected to the hot (left) side of the valve. If this is the case, the valve will need to be reinstalled. Note: The cartridge cannot be reversed to correct this issue.
  3. The cartridge would need to be calibrated. Instructions on calibration can be obtained via the ExactTemp Service Manual in our Literature Center.
Note: When calibrated properly, the ExactTemp valve should provide a range of temperature of 80 to 120 degrees Fahrenheit.
For ioDigital models:
  1. Verify the shut off valves are in the open position. These will vary depending on your ioDigital model.
  2. Remove the valve inlet screens and inspect for any debris. The water supply will need to be shut off, and then the black nut on the inlets can be unscrewed to remove the inlet screens. Rinse off any debris that may be on these screens and reinstall.
For standard valve models:
  1. Check to see if there are shut off valves installed with the unit. Verify these valves are opened all the way.
  2. The cartridge (for one-handle faucets) or cartridges (for two-handle faucets) would need to be removed (or replaced) and the valve body would need to be flushed and cleaned.
https://www.moen.com/customer-support/faq#/cat-troubleshooting
Sep 17, 2017 | Moen 7437 Chateau Single Hole Kitchen...
Getting mostly hot from Exacttemp control 4 yrs. old
Moen's website has PDF's available for download on their site. These have pictures and show you how to adjust the temperature control for your model.
http://www.moen.com/shared/pdf/instruction_sheets/ins1282b.pdf
Jun 16, 2010 | Moen & One Handle Tub & Shower Faucet
Moen monticello shower control, remove handle
If your Posi-Temp has no water coming through the valve my first step would to replace the cartridge (Moen pn 1222). The valve as a simple one. Get the part first so you can ues the plastic tool that comes with it if you need to. Beneath the actual lever insert on the handle hub you will notice a small hole. this is to gain access to the allen head screw which holds the handle in place
Feb 07, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Moen one control shower faucet is leaking hot water
Try replacing the cartridge first.That's your best bit . Next would be the whole valve. Hopefully, it's just the cartridge.
Jul 04, 2009 | Moen & One Handle Tub & Shower Faucet
Moen 7065 leaking at base of lever control in kitchen faucet
Yes, a cartridge will probably solve it. There are two different Moen cartridges so be sure to take the old one with you so you get the correct one.
Apr 05, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Home Logo
35 people viewed this question
Top Whirlpool Home Experts
Donni Steen
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
