Question about Garden
To reload wire spool on flymo met25-2 strimmer
MNfisherman
  • 11896 Answers
SOURCE: flymo mini trim how to reload spool, many thanks
just pry off th bottom cover and remove the spool. Rewind the new string and replace.
Posted on Jul 06, 2009
SOURCE: how do you put the plastic line into the flymo
how do i replace nylon line in my flymo
Posted on Jul 10, 2009
woobie dog
  • 1273 Answers
SOURCE: Reloaded string empties and shreds continuously in seconds
It sounds like you may need to replace the head. It is designed to advance and stop, but your's isn't stopping. Try this: Clean the inside of the head and connection to the machine well. Put some graphite inside the spool and where it connects to the machine; be generous with the graphite. Put the head back on with some line properly wound onto the spoo (note arrows on back of spool). With the machine off tap the head on the ground enough to disperse the graphite thoroughly in the head. Now, push the head as though to advance the line, and pull on the line. If it advances a little and stops, it is working. Do this several times to be sure. If you can get it working like this, you're good to go. If not, replace the spool. Even with the new spool, occasionally put some graphite in it to keep the line advance smooth!
Best regards, --W/D--.....Please feel free to rate this solution. Thanx!
Posted on Jul 25, 2009
  • 50 Answers
SOURCE: i have a flymo ct250 strimmer. when charged the
could be battery or just needs grease inside the shaft
Posted on Oct 16, 2009
  • 81 Answers
SOURCE: Rethreading a garden strimmer
Hi Deborah,
You need to start from the beginning of the trimmer string. Remove the entire spool. Insert the start of the line through and wedge it into the little groove to keep it from coming loose. Now wind the line tightly and neatly in the direction shown on the spool. (it should provide an arrow stating to "wind this way". As you near the end of the line, keep it snug and push the end through the hole where it leads out to the cutting zone. As you re-insert the spool into the housing, make sure it stays tightly wound as you lock it into place. This should help. Usually when your string is too short, you tap the **** of the spool on the ground to advance the line. It should feed a bit at a time, and when you hear it getting cut off, you should stop advancing the line.
Hope this helps.
Posted on Apr 13, 2010
Strimmer instructions
some strimmers have two tabs on either side of the spool which yousqueeze while pulling up.
Sep 07, 2014 | Garden
Spool cover required for hg500b grass trimmer
Hi, mine broke yesterday (Sovereign HG500B Grass Trimmer). I took the grass trimmer to Homebase but they've told me that this model has been discontinued and they don't sell spare parts for it. I believe it's still within the guarantee period so if I can find the reciept they'll organise some sort of replacement, but if I can find somewhere that sells a replacement spool cover I'd rather just buy that and replace it...so far no luck.
Aug 04, 2010 | Garden
How much line do I reload a strimmer spool with from a bulk reel?
It depends on the brand of trimmer and the type of head on the trimmer. On my Echo trimmers, I install 18'.
Oct 08, 2009 | Ryobi Garden
I have a flymo ct250 strimmer. when charged the
Sep 19, 2009 | Garden
Where can i buy a replacement spool
do you mean the spool or the trimmer 'wire'? the wire itself can be bought at most DIY shops and then fitted to your spool, which is removable. if you need the spool, contact the maufacturer, or do a web search.
Sep 12, 2009 | Garden
Strimmer cord keeps breaking
the eyelets on the trimmer head may be worn and cutting the line ..look for groves in the eyeleys may need to replace the spool
Sep 01, 2009 | Garden
Flymo mini trim how to reload spool, many thanks
Jul 06, 2009 | Garden
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
