Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Openers 102 1379
Program
Whenever I try to download and open a new program, the computer asks me to choose a program to open it with.
Hi golfnutz
Usually a file is opened by a program that specifically handles that kind of file, for example MS word opens (amongst others) .doc files and .rtf files MS Excel opens .xls and .xlsx files.
A downloaded program would normally need to be installed before you can use it, if the program files are in a compressed format then they will need to be extracted before they can be installed.
Try right clicking on the files and if the menu that opens includes the option to extract all then select that.
You should be able to tell what sort of file you are trying to open by looking at the file extension, program files usually end with the extension .exe.
Sep 15, 2014 | HP Pavilion Computers & Internet
Tip
How to Change the Default Open With Program in Windows 7. 1. Right click on a...
<span> How to Change the Default Open With Program in Windows 7.<br /> <br /> 1. Right click on a file with the same file extention you want to change the default launching program for and then select Properties.<br /> <br /> </span><img src="issken_12.png" /> <br /><span> 2. Next click on the change button.<br /> <br /> </span><img src="issken_13.png" /> <br /><span> 3. Next you will want to click on the program you want to open the file. Note if there is more than one program installed that Windows knows supports the program the name will show up in this list.<br /> <br /> Note if there is more than one supported program and/or you are trying to find a program that will open a certain format I would recomment that you ucheck the "Always use the selected program..." until you are certain because this will tell Windows to now use that program to open that format.<br /> <br /> </span><img src="issken_14.png" /> <br /><span> Also note some times the program that you want to use is not on this list. If it is not you will need to click on the Browse button and file the EXE file to the program that you what to use. After you find the Executable file for the program it will show up on the list.<br /> <br /> 4. After you have selected the program that you want to open the file with then click on the OK button.<br /> <br /> 5. At this point the properties should show the program you selected in the Opens with section. Next click on the the Apply and the OK buttons to save the changes. You are now ready to open your file.<br /> <br /></span><img src="issken_15.png" />
on Jan 29, 2011 | Computers & Internet
How to program the open misc button
to program an open misc key in the first 10 columns of the keyboard turn key to program and hit 100 subtotal, then press the key to be programmed. enter o and hit time , cash for a non taxable open key or press 400000000 time , cash for open taxable key
Phil
Jun 30, 2014 | Samsung Sam4s ER-5200M Cash Register WITH...
My desktop programs changed picture to one
You change your default doc file opener to MS word.
Dec 26, 2012 | Computers & Internet
COMPUTER CRASHED I NEED TO RELOAD CD BUT I DONT HAVE ACCESS CODE
There are now several versions of the basic Futura software and AutoPunch available on the market. The most current is version 1.0.0.2. To determine what version of either software you have, you will find this information around the inside rim of the CD at approximately 4 o'clock. Before loading any of the Options into your computer, check the version and then follow the steps below. The following steps will update your software so that you will now have the latest 1.0.0.2 version of the basic program and all options.
To load base software 1.0.0.0 with AutoPunch 1.0.0.0 or base software 1.0.0.1 with Autopunch 1.0.0.1
  • You must use bobbin part number 085128. This bobbin is specifically designed for the Futura CE-100 and CE-200.
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Turn on Futura machine and double left click on Futura icon to open program
  • Close program and turn off the machine
  • Install Autopunch and leave the CD in the tray
  • Download appropriate update for Windows Version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop download icon to install update
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program
To load base software 1.0.0.0 with AutoPunch 1.0.0.1 or base software 1.0.0.1 with Autopunch 1.0.0.0
To load base software 1.0.0.0 or 1.0.0.1 with Autopunch 1.0.0.2
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer- machine turned OFF)
  • Close software and turn off machine
  • Install Autopunch using Installation Wizard - leave CD in tray
  • Turn on Futura machine and double left click to open program
  • Type in Access Code from Autopunch jewel case and then left click on check mark to open program
To load base software 1.0.0.2 with Autopunch 1.0.0.0 or 1.0.0.1
  • Close program and turn off machine
  • Place Autopunch CD in tray but CANCEL Installation Wizard
  • Turn on Futura Machine and double left click to open the program
To load base software 1.0.0.1 with Autopunch 1.0.0.1 with Hyperfont 1.0.0.2 or Photo Stitch 1.0.0.2
  • Load Base software (have the machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Close program and then turn off the machine
  • Install the Autopunch program and leave the CD in the tray
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program*
  • Download appropriate update for Windows version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop icon to install update
  • Install HyperFont program - leave CD in tray
  • Type in Access Code from HyperFont jewel case and then left click on check mark to open program*
  • Install PhotoStitch program - leave CD in tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark to open program*
* Must open the program after installing each Option with CD in tray and type in Access Code before installing next Option.
To load base software 1.0.0.2 and adding all Options - Hyperfont 1.0.0.2, PhotoStitch 1.0.0.2, Autopunch 1.0.0.2 and Cross Stitch 1.0.0.1
  • Install Base software (have machine set-up for embroidery with USB connected to both the machine and computer- machine turned OFF)
  • Close program and then turn off machine
  • Install Autopunch program and leave the CD in the tray
  • Type in Access Code from AutoPunch jewel case and then left click on check mark*
  • Install Hyperfont program and leave the CD in the tray
  • Type in Access Code from HyperFont jewel case and then click on check mark*
  • Close Program and turn off machine
  • Install Photo Stitch program and leave the CD in the tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark*
  • Close program and turn off machine.
  • Install Auto Cross Stitch program and leave CD in tray
  • Download appropriate update for Windows version from the Futura-Support.com updates (Fut_sp2_Options.exe) and save to desktop
  • Type in Access Code from Auto Cross Stitch jewel case and then left click on check mark*
Dec 11, 2010 | Singer CE-200 Quantum Futura Computerized...
If i try to download something,like a video,it says connect media to save destination
You do not have a default program for your video viewing or that particular video requires a specific program to be used. Ensure that your computer has a video player such as Windows Media Player if you are using a Windows OS or that you have Quick Time if you are using a Mac OS. If these programs are already installed, then you may want to ensure that they are set to be the default program for that particular video.
Download the video, then right click the video and click the option that says "Properties". When the box appears, click open with and select either Quick Time or Windows Media Player. To avoid doing this for every video, follow the instructions below:
WINDOWS OPERATION SYSTEM
  • Open Windows Explorer by right-clicking the Start button, and then click Explore.
  • Click a folder that contains a file of the type that you want Windows to open in a program that you select.
  • Right-click the file and, depending on the programs installed on your computer, complete one of the following steps:
    • Click Open With to choose the program that you want.
    • Point to Open With, and then click Choose Program to choose the program that you want.
  • The Open With dialog box is displayed. Use one of the following methods to select the program that you want to use for this file type:
    • In the Programs list, click the program that you want to use.
    • Click Browse, locate and then click the program that you want to use, and then click Open.
    • Click Look for the appropriate program on the Web to browse the Internet for the program that you want to use.
  • Click to select the Always use the selected program to open this kind of file check box if it is not selected.
  • Click OK.
  • MAC OS
    1. 1quick-change-files-default-application-1.1-120x120.jpg Select the File to Make the Default Application Change
      In an open Finder window, select the file you wish to make the default application change to.
    2. 2quick-change-files-default-application-1.2-120x120.jpg The Contextual Menu for the File
      Right-click your mouse or use a "Ctrl-Click" with the keyboard to bring up the contextual menu for the file.
    3. 3quick-change-files-default-application-1.3-120x120.jpg Clicking the "Option" Key Changes the Menu Item to "Always Open WIth."
      Press the "option" key on your keyboard and you will notice that the "Open With" menu item in the contextual menu will change to "Always Open With." Select the "Always Open With" option in the contextual menu.
    4. 4quick-change-files-default-application-1.4-120x120.jpg Select the Application from the "Always Open With" Menu
      Select the Application from the "Always Open With" menu to make your changes to the file, and the newly selected application will become
    Nov 29, 2010 | Computers & Internet
    I cannot open tif files with adobe error code coming 5.796.03.2.2312 tks
    You need to tell your computer what program you select to open your image files. click on the image you want to open and choose 'open with' as your defaul6 program to open these files 4' then to find your adobe program . Go to Programs ;Adobe and then photoshop (or whateve) program you want to be the default program and select the icon to choose this as the default program to open your jpeg or tiff files or whatever you are having a problem opening. I hope this answers your question.
    Dec 21, 2009 | Adobe Computers & Internet
    Compaq pc programs
    Try right clicking on the item you wish to open. This should give you an option to "Open with" in the open with menu you will see a list of programs that can open the file you right clicked on. If your using Vista at the bottom of this on your open with menu with be a "Choose Default Program" option where you can set which program you want to use to open that type of file. If your using XP you will get a box with a list of programs and a check box if you want to make the program you select the default one.
    I hope this helps,
    Eric
    Jan 19, 2009 | Computers & Internet
    Program will not open
    If a program will not open
    1. uninstall the program from the add/remove
    2. attempt to reinstall the program
    3. attempt to run the program
    4. if the program will still not open go to step 5
    5. Some programs may be incompatable with your operating system and fail to open, if you have windows XP or vista you can right click on the executable
    an executable (file) causes a computer to perform indicated tasks according to encoded instructions.
    and click the compatability mode tab , then change what operating system is reported to the program, then hit apply and attempt to run the program again.
    6. if after changing compatability setting of the to windows 95 the program still does not open
    change the compatability to windows 98/windows me , hit apply and attempt to run the program again.
    7. if after changing the compatability mode to windows 98/windows me , and your program still does not open , change the compatability setting to windows NT 4.0 (service pack 5), hit apply and attempt to run the program again.
    8. if after changing the compatability mode to windows NT 4.0 ( service pack 5 ) and your program fails to rurn , change the compatability mode to windows 2000 , hit apply and attempt to run the program again.
    9. if after changing the compatability mode to all of the available settings your program still fails to run , you may have a corrupt executable or an executable that is not compatable with your operating system.
    Thank you for choosing FixYa!
    Az.
    Sep 19, 2008 | Computers & Internet
    When opening a program adobe reader opens with a blank sceen and tells me that it could not open (the program) because it is not a supported file or it has been damaged
    what file are you trying to open? adobe reader only opens documents in pdf and adobe format. when opening a program, right click then choose "open with" option, and select the appropriate program to open the file with. most of them open with internet explorer or ms word.
    May 20, 2008 | Computers & Internet
    Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
    132 people viewed this question
    Top Sears Building Materials Experts
    Glenn Mayer
    Glenn Mayer
    Mike
    Are you a Sears Building Material Expert? Answer questions, earn points and help others
