Question about Intertherm P3RC-030K Air Conditioner
FEH-017HA wiring diagram
3 Suggested Answers
  • 14 Answers
SOURCE: I NEED THE WIRING DIAGRAM
contact nordyne local dealer and they should be able to get on for you. otherwise go to google and search for factor and e-mail them for 1.
Posted on Jan 10, 2009
  • 674 Answers
SOURCE: I have an intertherm feh-017ha
First, check your air filters and change if necessary. Next, if the motor doesn't seem to be running at full speed, the capacitor may be weak. This will cause it to run slower than normal. If you have a multimeter with the capacitor test function you can check it with that. If not, you can take it to a heating and air supply and they can check it.
Posted on Dec 15, 2010
How do you hook up the thermostat to a Central Electric feh-017ha-04 furnace? Also, where do the A/C wires hook up to the furnace?
The standard color code for the HVAC is as follows....
Red=Hot or 24v
White=Heat
Green=Fan
Yellow=A/C
White 1=secondary heat.
Blue=Spare
Orange=Heat Pump
C=Common
The thermostat has the terminals marked R,Rh,W,G,Y.
The furnace should have a terminal strip with similar markings.
If you only have 1 control transformer this will be easy.
Hook the wires up using the colors I have listed. If you don't have the same color wires go with whats close to them....such as use Orange for Red etc. It really doesn't matter as long as they are landed on the same terminals on the thermostat and furnace. Two wires running to A.C unit outside put one on Y the other on C. If you need any more help let me know!
Jun 02, 2014 | Intertherm Heating & Cooling
Nordyne model FEH-017HA-04 furnace...the fan comes on full force with ac but not when furnace comes on
On newer furnaces the fan starts in a period of time factory set and is initiated by the control board. The air conditioning fan is started by the thermostat and starts right away when the stat calls for cooling. You will need a tech. familiar with this model and carrying the right parts to look it over. Does the furnace fire and then shut off in a few minutes? If so, it is most likely to be the board. Sorry. It may be pricy.
Oct 24, 2013 | Electric Circuit Breaker Kit for Furnace
Nordyne FEH-017HA-04 furnace fan is running full speed on ac but not on furnace
Multiple speed fans are always wired to run on "HI" for A/C and a lower speed for heat. If there are more than 3 wires on the fan motor, its probably a multiple speed.
Oct 24, 2013 | Electrical Supplies
I NEED A WIRING DIAGRAM FOR INTERTHERM FEH-015HA WITH ONLY 2 WIRES AVAILABLE FOR HEAT ONLY. THE WIRE ARE CONNECTED TO "W" AND "A" POST BUT THE FURNACE WILL NOT SHUT DOWN AT SET-POINT.
If it's only a two wire system, it should be on the R/RC and W. Fan should kick on automatically.
Not too familar with that unit
A is usally for a heat pump pick-up coil or heating element
Pay attention once you've rewired the t'stat. Make sure the blower goes on automatically. The most it should take is apx five min, even if house is really cold
Also, check the heater. It may have way more options for control. You will just have to run new t'stat wire to take advantage
Mar 05, 2013 | Heating & Cooling
I need a wiring diagram for air handler model FEH-012HA-04
Here is the wiring diagram. I have one and am working on it as well. Good Luck.
Jim
May 15, 2012 | Heating & Cooling
I have an intertherm feh-017ha electric furnace and it's blowing warm air, but the force behind the air coming out seems weak and motor doesn't sound like it's running to it's full potential as it did last...
Dec 15, 2010 | Intertherm P3RA-048K Air Conditioner
Thermostat wiring diagram for heat and cool unit
out door unit staying on disconnect the yellow wire for compressor if still on contactor bad points whare main line voltage is connected if unit goes off stat bad also check for weedeater damage to stat line at unit hope this helps most systems green fan yellow compressor blue common orange reversing valve white aux heat strip remove stat cover to see how unit is wired up
Jul 03, 2009 | Heating & Cooling
I NEED THE WIRING DIAGRAM FOR A NORDYNE MODEL #E2EB-017HA
Dec 11, 2008 | Intertherm P3RA-048K Air Conditioner
Intertherm P3RC-030K Air Conditioner Logo
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
