Question about Candy CDC266 Dryer
Candy all lights flashing goc 590c - Candy CDC266 Dryer
Candy dryer goc 590c
There may be a loose belt or the drum may be stuck with sticky stuff and needs cleaning.
Sep 05, 2014 | Dryers
Candy GOC 590C condenser tumble dryer I've just taken the condenser out to give it a wash and it won't fit back into the hole . I have looked inside and there is a groove in there but the condenser won't...
The condenser unit will only fit in one way there are normally arrows on the front telling you what way or some you just have to align the 3 locks some are difficult to push back into position you have to lift the back end when pushing back patience is the virtue on these sometimes
May 24, 2014 | Dryers
Candy GOC 590C flashes 'clean filter' . I have cleaned filter but after a few minutes it starts flasing again. Where do I need to look?
on these dryers there should be a thermostat where the lint filter goes, you should be able to feel a metal circle when you put your hand down, ensure its not covered in fluff or scaled up with debris etc, if all ok, will need to check continuity on the thermostat which requires stripping the appliance down
Apr 09, 2014 | Dryers
Candy Grande o, stain vanish and 90 min light flashing
Try to find error codes on the Candy website.
Dec 20, 2013 | Washing Machines
Could you tell me why my candy go 482 washing machine doesnt always spin and the stain vanish and 90 minute lights flash together
could you tell me why my candy go 482 washing machine doesnt always spin and the stain vanish and 90 minute lights flash together
Dec 10, 2009 | Candy Washing Machines
Flashing lights on my candy washing machine
Hello Mikana, i have a brand new one and it also flashes the 90 and stain removel had the Candy eng out and it needs a new heater...all the electric goes throught this heater and if it detects a problem then it shuts down...the ones they fit at the company are not vrey good so the replacement is going to be better....ring Candy ........also if it has a large load capacity like 8kg don't under fill it it may send the drum of centre and this will stop the machine....self protection built in...hope this helps...cheers Dave
May 25, 2009 | Candy CNW156 Front Load Washer / Dryer
Stop light flashing
i have a candy activa cm1 146. no matter what i do the stop light is always flashing. Ive emptied the machine, turned it off at the mains, checked the waste pipe and currently trying to empty the filter, whilst the light is flashing it will not work on any programs???
Dec 16, 2007 | Candy CN146 Front Load Washer
Candy CDC266 Dryer Logo
288 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Eddie Dalton
Eddie Dalton
Are you a Candy Dryer Expert? Answer questions, earn points and help others
