Question about Fisher and Paykel 24 in. DS603H SS Free-standing Dishwasher
Our Fisher and Paykel Nautilus dishwasher cycle stalls and continues to beep during the wash cycle with U1 on the display panel
4 Suggested Answers
  • 713 Answers
SOURCE: Fisher and paykel nautilus. Cycle stalls with 15
OK, when you say it sounds like a record skipping does that mean its washing then not washing? what cycle are you using ? sorry to ask these questions but sounds like an unusual fault.is the water hot? could be control module or pressure switch fault. please reply and we can hopefully track down this fault.
Posted on May 23, 2010
  • 842 Answers
SOURCE: i have fisher&paykel.dishwasher.nautilus, half
U1 fault if caused by several things: water supply not turned on (I doubt that), unit is syphoning causing not water in tub to be detected during cycle (this is possible if the drain system in incorrectly installed), spray arm in the drawer is not in place or get moved somehow, excessive foaming (wrong soap or too much), inlet valve failed, controller failed, or rotor not fitted correctly.
I would inspect this issues and locate the reason the unit will not complete the cycle, you may end up replacing the controller in that drawer to fix the problem (as a last resort).
Good Luck
Posted on Oct 11, 2011
badfish6686
  • 563 Answers
SOURCE: fisher and paykel nautilus dishwasher
Does it fill with water? I would guess a fill/ drain/ heating problem. See if you can eliminate any of those.
Posted on Apr 12, 2013
Fisher and paykel nautilus dishwasher
Apr 12, 2013 | Fisher and Paykel Dishwashers
DCS bottom dishwasher drawer u1 code: begins cycle, runs a couple minutes then stops and beeps
Hi there Ypowers, U1 fault code relates to the fill system. Is the tap turned on, is the spray arm position correctly and free to rotate, nothing blocking it?. I hope this helps regards Gary.
Nov 08, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have fisher&paykel.dishwasher.nautilus, half way through the washing,it beeps non stop and shows me U1 . AND IT DOESNT WORK SO I HAVE TO START ALL OVER AGAIN
Good Luck
Oct 11, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel nautilus. Cycle stalls with 15 mins to go. On any setting.
May 22, 2010 | Fisher and Paykel 24 in. DS603H SS...
Fill Fault appears during wash cycle.
Is the filter in the hose where it screws onto the tap clean?, if this is okay then most likely the valve.
Apr 19, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F & P DD603 starts to wash then beeps & flashes U1 - Fill Fault. I have cleaned both drawers & replaced all parts correctly, still comes up with U1.
Have you checked whether you are getting the water supply to the dishwasher. Check if there is no kink in the water hose.
If no problem with water supply then check the water pressure rating is OK for the dishwasher.
Dec 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
We are now getting a U1 error code on a Fisher and Paykel Nautilus dishwasher which was in the house we purchased 3 years ago and has functioned perfectly until now. There was no manual left when we took...
U1 means the unit has failed to prime with water within 3-4 minutes.
Its taking longer than expected to fill with water.
Check the fill valve, water supply problem, excessive sudzing.,reduce your detergent.
Jul 27, 2008 | Fisher and Paykel Dishwashers
Top drawer not working
sometimes if the heater is faulty only one drawer will work and the other drawer will flash f1
Nov 02, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 24 in. DS603H SS Free-standing Dishwasher Logo
26 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
