Question about Canon PIXMA iP1500 InkJet Photo Printer
Canon PIXMA iP 1500
I am assuming that the printer ran dry since I had it stored away not using it. I recently bought new cartridges and it still wont work. It just makes the noise like it is printing but it really isn't. Please help. Chris
  • quinela Feb 07, 2008
    My printer doesn't print anything containing red and the other colors are very light even though i just bought new ink, since i had it away in storage i misplaced the power cord and i'm now using one for my boom box, could this be the problem? i performed the print head test, deep cleaning & alingment. Please help me as soon as possible.
    Habit-Forming:
  • 59 Answers
Your print head is most probably blocked.
First try and run the deep cleaning program a few times, it make penetrate deep enough to get through.
If that doesn't work you can either replace the print head or try and clean it.
To clean it you could soak it in a mixture of window cleaner and water (filtered best), but don't let the electronics get wet by this and try to avoid wetting the rubber seals where the ink tanks go get wet by this too, it should only soak the very bottom part of the head.
Let it dry off and wipe any residue with a soft cloth especially on the bottom where the print heads actually are. You may need to soak it a few times to get all the gunk out.
Posted on Jan 25, 2008
SOURCE:
Two days back i bought canon inkjet printer while i printing iam not getting a print
Hello. If this printer is brand new, return it to the store. If you bought it used, chances are that the ink cartridges have dried out in the nozzle area. The only fix is to buy new ink cartridges. Joe
4 thumbs up please. ty
Oct 21, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Is MP210 and MP240 the same? can i use the same cartridge?
no both are different
Here are the list of cartridges u can use
MP210
PG-30 Pigment Black
PG-30 Pigment Black Ink Cartridge
PG-40 BLACK
CL-31 Color FINE Ink Cartridge
CL-41 Color
MP240
PG-210 Black Cartridge
CL-211XL Color Cartridge
CL-211 Color Cartridge
PG-210 XL Black Cartridge
Nov 28, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Coloured ink not registering
You can only refill those cartridges if you do it before the ink is empty. After that you need a new cartridge or a chip resetter to reset the chip on the cartridge so it will work again.
Oct 12, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon iP1800
Make sure you removed the protective film on the cartridges.I've seen this alot on new installs.Next clean the print catridge contacts with a clean moist (very little) cloth ,then dry cloth.It may work, Good Luck.
Sep 08, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
My Canon IP 1800 cannot recognized the Black ink
It sounds like the electrics on the back of the cartridge have failed, replace with a new cartridge, and away you go.
Jun 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
New Ink cartridge doesnt work on IP4300.
You have actually bought a dead cartridge as the ink there has dried up.
Either u kept it for long without use or the shopkeeper.
Now what u can do is take a syringe and fill it with luke, warm water and leave it in that stage for half an hour .
Then syringe out the water and allow it to dry in sun for 10 min.
Now fill the ink and u will be going
May 29, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon Pixma IP5000 wont print cyan or magenta
Think you need to clean the sponge that the ink cartridges sit on in the head tray they are probably blocked with dry ink. You can remove the print head and tray by lifting the lever and gently lifting it out..... go here http://www.inkjethelper.com/
to see how to carefully clean it with compressed air. I had to do this too.
Apr 09, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Canon pixma ip4500
u should carry the printer to Canon Care Centre, they will check the case and if found that the Cartridge u r using is Genuine your Cartridge will be replaced.
Regards,
manoj joseph
+91 9352008418
Jun 15, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Lost installation disk for canon pixma iP 1500 inkjet printer
http://driverscollection.com/?file_id=26383 heres the driver
goto to printer setup in control panel add your printer by name or software this will get you back to what you want
May 14, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Canon MP510 wont recognise cartridges
Using replacement cartridges that come without a chip seems to be the problem I had with the Canon Pixma 510 printer they are cheaper
but if they do not show the ink levels then its inconvienent so I have but Canon products with a chip and they work perfectly.
Nov 11, 2007 | Canon PIXMA MP510 All-In-One InkJet...
Canon PIXMA iP1500 InkJet Photo Printer Logo
219 people viewed this question
Clive
Clive
old marine
old marine
Ekse
