Question about Haier HVTS18DABB Wine Cooler
My haier completely stop working - Haier HVTS18DABB Wine Cooler
Haier dishwasher did not pump out
I had problem like this...one day the washer stopped, still half-full of water. Then, we tried to run again and we could hear the little engine working but it wouldn't let water in OR out, just error beaps.
Then my boyfriend took off the back and gently tapped the water inlet valve solenoid with his screwdriver, and now it works! Starting FILLING actually, not draining, but completed a full cycle finally!
Must have shaken loose a blockage in the mechanics in that solenoid, probably have to replace before long. But for now, success!
Here is a website that helps: http://www.searspartsdirect.com/Haier/dishwasher/model-Esd301-repair/categories/dishwasher-repair/symptom/dish004.html
(See "REPLACE WATER INLET VALVE", half-way down page)
Aug 19, 2013 | Haier 17 in. HDT18PA Built-In Dishwasher
Our Haier HDC1804TW counter-top dishwasher does not complete the washing cycle. It stops after 90 minutes which should be 115 minutes for heavy washing according to the manual. The washing light is...
Since mine does the very same thing, it's my guess that is the sterilising cycle as by this point it has already washed, done a short fill to remove any remaining detergent, and two rinses. I'm also assuming the second short fill is just to cover the heating element and/or to to generate an amount of steam having being heated by the element (I'm basing that assumption on the heat of the dishes at the end of end of the cycle and the heat of the water when it drains)
Mar 05, 2011 | Haier HDC1804TW Dishwasher
I close turn on and no water
if you can hear pump kick in then stop..... then you need to change valve inlet...
Feb 26, 2011 | Haier HDB24EA Built-in Dishwasher
Haier HVTB18DaBB Wine Cooler has stopped working. It was working yesterday and today it isn't.
check if it still has power, if it does check the back of the cooler to see if the fans have stopped running, you might need new fans.
Oct 03, 2010 | Haier HVTS18DABB Wine Cooler
Haier 26; TV Tuner
contact the Haier Service center in NY. www.asnyonline.com
May 25, 2008 | Haier HL32BG 32 in. LCD Television
THE DEHUMIDIFIER JUST QUIT WORKING AND IS COMPLETELY DEAD AND IT WILL NOT MAKE A SOUND
the dehumidifier just quit woking. But light comes on, saying tank is full.
May 20, 2008 | Haier HDN455 Dehumidifier
Haier HNSE05 shuts off on it's own.
Sounds like the thermostat is bad which is temp. dial.
Sep 19, 2007 | Haier HNSE05 Refrigerator With Ice Box
Haier HVTS18DABB Wine Cooler Logo
44 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
