I would loike to remove my bottom nailinf fin on my pella replacment window
I am installing into masonary walls bottom nail fin is in the way
  • 739 Answers
Should not be a huge issue to trim off the bottom nailer... trim off with a razor knife being careful not to penetrate the frame. the primary concern is providing support to the frame. Using mortar and wood shims, layer mortar where the window will sit and level it using the wood shims, leaving space to remove the shims after the mortar sets... I'd recommend using screws to afix the remaining fins to the studs to lessen the loss of mortar from shifting the window during install
~~~~] shim [~~~~mortar~~~~] shim [~~~
Posted on Nov 20, 2013
How do you remove single pane windows and replace with double pane insulated windows on a existing brick home?
Read manufacturer directions thoroughly. Measure smallest height and width dimensions of existing aluminum window frame for rough opening at several locations. Order retrofit window 1/2 inch smaller on each side. Remove old glass and center aluminum stave. Trim fin of new window as little as possible so it fits against outside face of confined edges of outside facing part of existing frame. Drill holes in frame as manufacturer instructions dictate. Test fit window and mark where outside trimmed fin ends on wall. Measure for shims at gaps between new and old inside frames. Install shims with Lock time PL caulking. Caulk existing window frame corners, holes from removing center stave, and a 1/2 inch bead within the area marked on exterior wall. Place window and push into caulk. Make sure there is full contact with caulk. Drill pilot holes at screw locations drilled earlier, Place silicone caulking on screw heads and screw window in place. Square up window while screwing. Trim inside of window and plug holes from screws. Good luck.
Jan 01, 2015 | Insulation
How to build a dirt floor 20 by 20 shed
Put posts in ground.
Middle posts taller so roof will have slope
Nail 2x4s across from post to post to hold siding.
One row of 2x4s around bottom, 2 rows 2x4s around middle,
1 row 2x6s or 2x8 around top.
2x6s 2x8 will hold rafters
Nail 4x8 sheets treated plywood onto the 2x4s to make walls.
Install joists across top of structure from one wall to the other wall
Install rafters at correct angle to match slope of roof, be careful to each rafter exactly the same.
Rafters sit on outside wall
http://waterheatertimer.org/images/Pole-barn.jpg
Gene
Sep 01, 2014 | Hardware & Accessories
How to change rollers on Pella sliding doors
Remove the door from the rack. St it on its side, a few screws hold them in, Unscrew the assembly and replace it.
Aug 10, 2014 | Pella Sliding Glass Door Roller
I have ceramic (terra cotta) block walls in my basement (house was built around 1920. The blocks are ridgid and were not laid very evenly, although the walls are sound. Plastering is an option, but with...
My house is of similar age and construction. I built a nice TV room in the basement several years ago. My method was the same as the way interior walls are built in new construction. I nailed a 2x4 to the ceiling near the wall. I nailed another 2x4 (pressure treated) to the concrete floor directly below the 2x4 on the ceiling. Then I toe-nailed vertical studs in place. For the studs I used 2x3's since this allowed me to get a nice flat plane on the front surface while allowing an inch of space on the back for irregularities of the block wall. I then covered the studs with water resistant drywall. The results were excellent and have held up very well. I also use a dehumidifier, since my basement was somewhat damp. I built the dehumidifier into a cabinet so that it draws air from the space between the block wall and the 2x3 wall. I don't need to run the dehumidifier in the winter. For the interior walls separating the TV room from the rest of the basement (furnace and workshop area) I used 2x4s for the studs, but the 2x4 along the top and bottom were just like the first wall I described. And by the way, in order to nail the pressure treated 2x4 to the floor, I used a power-nailer that uses charges that look like 22 caliber gun blanks. This seems spooky, and is wicked loud (use earplugs and safety glasses!), but it is inexpensive and very effective. The nails don't have to resist pulling out, they only have to resist being slid around, since the wall stud holds the pressure treated 2x4 against the floor. Good luck!
Apr 07, 2011 | Drills
We have a NELCO baseboard electrical heater, circa 1970s. We wish to remove it temporarily from the wall to permit new flooring installation under the heater. How are they attached to the wall?
It is attached with 2-screws or 2-nails. Depending on who installed it. I970's, I'm betting on 2-nails.
If you remove the cover, you will see where the nails are located on the inside back wall of the heater compartment and are attached to the baseboard. Be sure to turn the circuit breaker for the heater to the OFF position, be for attempting to unwire and move the heater. The circuit breaker should remain OFF until the heater is reinstalled.
Feb 28, 2011 | Fahrenheat FBE15002 Baseboard Heater
My aquastar 125b ng froze in cold weather and spewed water everywhere. when installes I was told it was ok to have this unit on outside wall. ... any suggestions
Generally speaking, tankless water heaters should not be installed on an outside wall, especially if they are masonary (which lose more heat to the outside) - regardless of what the installer told you. If the wall reaches & goes below the freezing point, so will the water pipes supplying the heater. However I am somewhat surprised that the heating element did not compensate, if indeed it was the heater that froze. I would recommend moving the heater to an interior wall if possible. You may also want to check the thermostat setting as well.
Dec 09, 2010 | Bosch Water Heaters AquaStar 125 series...
How to remove a casement window from cinder block wall and replace it with a slide window
Depends on the window, how it went in, will tell you how to get it out. They usually have a flange that nails to the wall and the siding will but up against it, some have a fin that nails up against a buck and plaster will **** up against it. Either way, you will have to remove the siding, plaster, trim, or whatever is on the side of the window and pull out the 1400 nails, take out the window, and get the new slider right back in the old hole, it should fit, most windows were standard, now days they are all custom fit to any size hole. But the bucks should still be in place and the drywall on the inside will not even be touched.
Nov 09, 2010 | Garden
I need to replace my power stering pump on my 1995 surburban
Removal/Installation Notes
  1. Disconnect hoses at power steering pump, then plug pump ports and hoses to prevent dirt entry.
  2. Loosen pump adjusting bolt and remove pump drive belt.
  3. Remove pump to support bracket retaining bolts, then the pump.
  4. Reverse procedure to install.
May 20, 2009 | 1995 Chevrolet Suburban
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
