Question about Black & Decker 16GA Finish Nailer Kit
Electric nail gun will not fire
With a hot battery the gun will not fire just a click sound when the trigger is depressed. the gun is free of jams and has the proper nails. It did sit for a period of time without being used.
  • 2,005 Answers
Replace the battery; they can drain and refuse to recharge after time in storage
Posted on Nov 18, 2013
  • aubrey fox
    aubrey fox Dec 10, 2013
    battery runs well in drill
  • 40 Answers
SOURCE: nails jammed in stapler so I took it apart splitting the halves.
Without knowing the brand and model number, the best I can offer is this: Since your question is listed under "all Black and Decker nail guns", have you tried going to www.blackanddecker.com and searching for your tool, or contacting their support section on the website? Or try typing your make & model # into a search engine, pick a place that sells parts and ask them to fax or e-mail a copy of the diagram (I have done this before to get diagrams).
Posted on Mar 13, 2009
  • 384 Answers
SOURCE: I have a rechargeable 18V B&D nail gun I
Take the long nail strip out and replace them with the shorter length nails.
Posted on Jul 01, 2009
smartr10U
  • 1305 Answers
SOURCE: my nail gun when i locate the battery to the gun
Make sure none of the battery contacts in the nail gun aren't bent, broken or missing. Try to rebend them out to make better contact.
Also make sure your battery charger is actually charging the batts as well.
let me know how it goes..
K
Posted on Oct 06, 2009
  • 47 Answers
SOURCE: My nail gun makes a small noice but will not
I know a lot of Dewalt nailers will not shoot properly once the battery is starting to get a little worn/has a lot of charging cycles on it. Their picky about having fresh batterys. How old is the nailer/batterys?
Posted on Jan 26, 2010
kirkx
  • 2019 Answers
SOURCE: I have a 12 volt
Since the jam light blinks, have you considered that it might be jammed?
Try removing all the nails, checking the action, and they reinserting?
Other than suggesting taking it in under warranty or taking it apart to check switches and sensors, I can't think of what I could suggest.
Posted on Feb 26, 2011
I pull the trigger and you get a air sound but no firing of nails . You get air release from top of gun
Could be just a lack of lubrication in the headvalve /orings or the safety foot is not pushing in the trigger pin all the way. Easy to check. Remove the head and pull out the head-valve. Apply plenty of white grease or silicone paste to the orings and the surface where the orings make contact. Install the head and test. If the gun fires then you are done. If the gun does not fire, make sure that the safety foot is depressing the trigger valve all the way in when attempting to nail. Simple test is to remove the trigger exposing the firing pin. With nails removed and air connected, with quick motion depress the firing pin all the way in. If the gun fires make adjustments to safety foot. If the gun still does not fire (with headvalve lubed) replace the firing valve core part # ca0108. Good luck
Mar 05, 2015 | Senco & Frame Pro 601 Framing Nailer
Nail gun has stopped firing nails
make sure that the nails are loaded in straight and packed down tight
Mar 26, 2013 | Arrow Fastener 2" Red Electric Brad Nail...
Arrow fastener 2 in. brad nail gun has stopped shooting nails
make sure nails are loaded into the gun straight and correctly
My bostitch N88RH is not firing nails
May occur when headvalve or driver is stuck (will usually make a pop or click when tigger is depressed), or tigger valve has failed or safety not actually touching trigger firing pin. Easy test, remove nails, remove trigger by pushing out 3mm roll pin or bolt to expose the firing pin. Pull back nail feeder and place the nose against piece of wood ~ depress trigger with very quick motion with finger. If it fires, reinstall trigger and adjust safety foot so that the firing pin is pushed all the way in. If does not fire, replace trigger valve (usually tva6) or remove trigger valve and replace the 3 orings on the inner plunger. If you hear a pop or click when you do test above, remove head and lube the headvalve orings with white grease or silicone paste.
Nov 17, 2011 | Stanley Bostitch N88rh Framing Nailer...
NR90AE Nails jammed how to remove
New user will jam the gun/ nails because gun was most likely not bump fired. Placing the gun then depressing trigger will usually cause double fire in the hands of new user. New user should practice on scrap lumber bump firing at many angles till they get the idea; or give them a training period with a nailer that has a single shot trigger (they may develop bad habits with single shot however).
Nov 14, 2011 | Hitachi NR90AE Full Round Head Framing...
Pull the trigger, no nail, only continuos air until I release tyhe trigger. not jammed, gun is clean, very new. acted that way right out of the box then it worked and then not and so on, worked...
Safety foot and lever inside of trigger are not pushing the trigger pin all the way in. To verifty that the gun will fire, remove the nails to allow for dry fire. Remove the trigger to reveal the trigger valve. Hold the gun against old coiled rubber hose or soft wood. Very quickly depress the trigger pin all the way in. If the gun fires, adjust safety foot and trigger so that the trigger pin is fully depressed when your bump fire. If the gun will not fire after adjustment, remove the head and lube headvalve/orings with silicone paste lube.
Sep 03, 2011 | Stanley Bostitch Mcn150 Strapshot Metal...
I have a Max cn70 nail gun. When trying to fire the gun, air seeps from the trigger assembly and will not fire. Help!
Hello, sounds like a nail is jammed in the chamber. Happens frequently. What you do first is disconnect the gun and empty any nails. Then, with a screwdriver or a big nail hit the ram driver back down . Reconnect and test by depressing safety latch and pulling trigger. Repeat. Hope this helps. -ROB
Feb 10, 2011 | Air Tools & Compressors
Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
Feb 18, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Black & Decker 16GA Finish Nailer Kit Logo
118 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
