Question about Bella Nutripro Cold Press Juicer
The crushing auger does NOT pull straight up and out of the processing bowl.
The juicer works, makes juice, but the crushing auger does not pull straight up and out of the processing bowl for cleaning.
How do i get the screen filter out of juicer
I had the same problem with my Salton juicer, after making a delicious juice it was almost impossible to remove the auger like many of you, with patience and lots of elbow grease I manage to take apart. Here is my solution to this problem and it works very well for me, its simple, before juicing, disassemble your juicer and add a little oil with your finger on the silicon seal (inside and outside) see picture attached, assemble the juicer.
After juicing, remove the cover, don't try removing the auger, instead grab the basket and wobble it and it should get free, it works for me and it should work for you too. Happy juicing to all!
May 20, 2014 | Salton JM411 Juiceman II Elite Juicer
My juicer leaks under the spout. I can not figure out why. I have checked all the assembly and all the directions. It is only the second time I have used this. My machine is brand new. Any though
The spout, itself is hinged. It has two positions, an upper and a lower position. (Similar to a light switch). Make sure it is in it's lowest position when making juice, otherwise the liquid will collect in the inner bowl and leak out the sides of the juicer. Move the spout to the upper position to temporarily stop the flow of juice, such as when you change glasses or receptacles. Then, put the spout in the lower position to resume the flow of juice.
Dec 26, 2012 | Jack Lalanne Power Juicer 250 Watts
Want to see all parts, not sure my juicer has all its parts
Juice bowl goes on first, then basket, blade, clutch nut followed by cover which
rotates shut, and of course the food plunger.
Mar 10, 2011 | Acme 5001 Supreme Juicerator Juice...
How to make orange juice from fresh oranges
Peel 4 medium size oranges and place in the juicer.
Juicing Tip: When juicing oranges (or any kind of citrus fruit) it is a good idea to juice the white membranes at the center of the orange. The majority of the bio-flavonoids in citrus fruits are found in the white membranes. Scrape off some of the white membranes inside the peel and include them in the juice. We don't recommend juicing the whole peel, this will produce a very sour unpleasant juice.
Nov 29, 2010 | Jack Lalanne Power Juicer 250 Watts
I haven't used my Acme Supreme Juicerator in years. How do you assemble the juicer? The flat blade sits on the aluminum filter? How does it attach to the motor? Am I missing a part
Juice bowl first, then the basket followed by the
shredder blade which is all held down by the
white clutch nut. If you're missing the nut ctc.
Waring at 1 800 492 7464 for a new one.
Nov 04, 2010 | Acme 5001 Supreme Juicerator Juice...
I don't know how to clean my jack lalanne's power juicer
remove to arm that holds top slide it twards you then use tool to remove blade then remove juicing screen then the bowl (the one that says jacklallanes power juicer
Mar 02, 2010 | Jack Lalanne Power Juicer 250 Watts
Do not know how to remove basket
(1) Remove the food plunger and top cover; (2) unscrew the 3 screws from the blade/cutter plate and lift it off its base; (3) Unscrew the plastic base COUNTERWISE and lift it off of the center spindle; (4) Now you can remove the basket and juice bowl for cleaning.
To reassemble, reverse the process.
Dec 29, 2009 | Salton JM411 Juiceman II Elite Juicer
Juicer works fine until slight pulp build up in
Unfortunately, since these juicers do not eject the pulp, they will tend to go out
of balance. Juice nothing softer than apples and try to feed it as evenly and as
slowly as possible.
Nov 27, 2009 | Acme 6001 Juice Extractor
Bella Nutripro Cold Press Juicer Logo
50 people viewed this question
Top Bella Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Bella Juicer Expert? Answer questions, earn points and help others
