My Haier AC (KFR 25GW/Z1) makes a loud "click" or "crack" sound every few minutes while running. Can you please provide a solution?
  • 90 Answers
There is a little engine where is broken a sprocket from plastic
Posted on Jan 13, 2014
3 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
Posted on May 16, 2008
pctech1
  • 1940 Answers
SOURCE: I purchased my ac in
Unplug the unit. You will need to gain access to the blower motor inside the unit. Try and turn this motor by hand. If it is frozen, lubricate it. If it is not frozen, you either have a burned out motor, or you have an electrical failure.
Most motor failures are due to lubrication problems. It could be lack of lubrication for whatever reason. It could be contamination of the bearing system. If you don't grease a motor, sooner or later it's going to fail. If you lose grease in the bearing during cleaning, a failure is imminent. High motor and bearing temperatures also will tend to dry up the grease over time.
If you are not familiar with working on A/C units, motors, etc., I would recommend having a service professional repair the unit, or you can purchase a replacement.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Jun 14, 2011
What could be the fault with the Supreme- Galanz model KFR-25GW/A4 when switched on goes into standby
check that the temperature setting is not at or above ambient temperature as the machine will go into standby until the thermostat is activated by a higher temperature that what it is set at.. So if the setting is 35degrees and the room temperature is 25degrees it sensors that it need not turn on and will go to standby until the 35 degrees becomes less than the 25 degrees.
Apr 25, 2014 | Oldsmobile Cutlass Supreme Cars & Trucks
My father has a Dynex LCD TV, Model DX-37L130A11 Rev A, sticker says 10H07-Rev A. Manufactured August 2010, Lot #: 205204 XHT 100453. A few days ago he said the audio started emitting a loud, cracking...
It sounds like you've done quite a bit of troubleshooting, which I applaud you for doing. Have you tried power cycling the TV? Simply turn off the TV, unplug it (and any components connected to it), then plug it back in and turn it on after a minute. See if this corrects the issue. If it doesn't, then I would recommend calling our Product Support team to schedule repairs at:
U.S., Canada, & Puerto Rico - 1-800-305-2204
Mexico - 1-888-882-7326
daily from 7 am - 12 am CT.
Sep 04, 2013 | Dynex Televison & Video
Haier commercial cool portable ac unit makes super high pitch noise on all settings & returning it for repair is not an option what troubleshooting steps can I take? Ac blows cool & fan runs at...
It may be the bearings in the motor are dry or out. You coulod pull the motor and fan assembly out and check its operation while it is out of the heater case. Look for anything inside the heater cavity where the motor sits for any problem hindering motor operation.
Jul 01, 2012 | Cars & Trucks
When I turn the air conditioner off or on it makes a noise sounding like it is coming from the fan. It sounds like the fan might be loose but I'm not sure. What is the problem and what should I do?
Hello, you would need to take the top cover off the AC and check the fan, usually the hub of the fan breaks and becomes loose or sometimes just the clamp comes loose and the fan hits the housing. If the fan is cracked then you would need to replace just the fan on the unit. Here is a link or parts to your ac http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/ESA3109.aspx.
Jun 13, 2011 | Haier ESA3109 WallWindow Air Conditioner
Clicking sound and not cooling
compressor grounded. replace relay or compressor
Jan 02, 2010 | Haier HVFM20ABB Wine Cooler
Buzzing and clicking sound every few minutes
Compressor start relay - white plastic part - sitting right on the compressor, disconnect it shake it - u'll here it if it's damaged. :)
Oct 01, 2009 | Jenn-Air JCD2389G Side by Side...
Frige gets hot and makes clicking noises.
Sounds like the compressor is not working very well the clicking is the compressor starter trying to start the compressor. May be low on freon or bad compressor. You can probaly buy one cheaper than fixing this one
Dec 26, 2017 | Haier Refrigerators
MAKING A LOUD CLICKING SOUNDS
Hi, I am not familiar with this model but the noise sounds like a relay clicking at the compressor. Is the sound coming from the outside in the back?
Please let me know if I can assist you further.
Thanks
Vic
May 24, 2009 | Haier 9.1 cu. ft. / 258 liter Upright...
Haier Model No. HSA04WNC WW/BPG fridgefreezer loud rumbling noise
Rumbling sound is not good. Check to see if it is making the noise with the door open. If so - it probably is a fan blade scraping. If it keeps making the noise - it is likely the compressor - either a faulty relay or capacitor. Or maybe the compressor is faulty. You'll need to be handy with a multimeter to check these out though.
May 30, 2017 | Haier HSA04WNC Compact Refrigerator
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
