Question about Icom Ic-7000 & Ldg At-7000
Ic 7000 will not go into tune with ah4 tuner, tuner works fine with my ic 718
How do I fix the FM tuner to pick up FM signals?
I think you might have fault in the FM tuner section. Most of these are done by a single IC, replacing that will cure the fault I suspect.
Jun 10, 2017 | Audio Players & Recorders
No response when switched on
There is an internal fuses in most of the radio's for the low power circuitry. Open the case and have a look. In the 706, it is on the PA board and is a 3AG style fuse. Do not replace this fuse with a higher rating than it already is. A higher current rating will damage the radio beyond economical repair if there is a problem. If the fuse is OK, then take it in for service. There is very little, if anything, that most hams can do at this point as the electronic components are too small to work on without the proper tools.
Jan 25, 2014 | Icom Ic-7000, 706, 703, 718, 78 Amp Relay...
AUTO TUNING WONT RUN
Check and replace its main system control memory IC. If this IC is faulty, auto tuning will not work, or, the TV will store any received channels. If the TV do not tune into channels too, the AGC voltage to its tuner, and tuner itself should be checked.
May 27, 2013 | TCL L32D20
My technika tv will tune in ok but turn it on the next day it needs tuning in again
Two components in the main circuit to your TV should be suspected. The first one is its Tuner itself. if tuning frequency of the tuner drift with change in atmospheric temperature, or if the Main system memory IC do not store the tuned frequency well, this type of fault will happen. Anyway, the work is a skilled one, and a user who have no knowledge about electronics cannot make this fault right. It will be best for you to contact any experienced service technician.
Oct 18, 2012 | Televison & Video
Jjkj;jl
jjkj;jl mean by image fault /screen fault ?
solution :
Step 1 : At fast fine setting for your Antenna.
Step 2 : Fine tuning your TV tuner Or Channel chilector
Step 3 : At last check Video I.C.
Jul 16, 2011 | Televison & Video
Hi, I have a Harman Kardon AVR 300 that I picked up at a local sale. When I power it on, it switches fine to each input except the AM/FM tuner (the preset, tuning, & tuner mode buttons don't seem to...
Hello Sir, Hi, you may try the following
  1. try cleaning the switches
  2. if this does no solve the problem, its the selector circuit. this may be digital, so you need to search the IC that selects the FM mode both with tuning. this is fair complicated.
  3. buy a cheap separate FM tuner, run it on auxiliary input.
Mar 22, 2011 | Harman Kardon AVR 300 Receiver
Thomson DTH 7000 DVD hard disc recorder
there is no digital tuner built into this unit as I own one
Jun 06, 2009 | Televison & Video
TV not tuning
This guy is raking in the change on you. The tuner is for over the air signals, now you have a 3 prong connector RED,WHT,BLACK make there connected you can find the AUX,VID-IN by scrolling throught the channels on your TV hope this helps.
Apr 22, 2009 | Televison & Video
Icom 756PRO2
What kind of antenna tuner do you use? (automatic or manual)
Personally I use the LDG AT-7000 and a G5RV. I have absolutely no problems on any frequency.
May 23, 2008 | Radio Communications
Icom Ic-7000 & Ldg At-7000 Logo
Top Icom Radio Communications Experts
peter0911
Steve
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
