Question about Brother Mfc 250c Clr Inkjet P S C F Usb 6000x1200 32mb 22ppm MFC 250C Brother
PRINT UNABLE 70
Had a paper jam which is now being removed but keeps coming up with print unable 70 please help
    New Friend:
  • 8 Answers
You would need to remove jammed paper opening back cover.
Posted on Nov 18, 2013
Mix-it-up
  • 832 Answers
SOURCE: Unable to print
press menu then start mono (blue button) then fourtimes arrow up (tel-index). Machine will be in maintenance mode and lights will flash. What error code does the machine display?
(to leave the maintenance mode press 9 then 9)
Posted on Nov 26, 2007
Mix-it-up
  • 832 Answers
SOURCE: Print Unable 34
There might be some paper left in the machine. Check the very edges espacially the left side (seeing from the front).
Another reason could be that the encoder strip isn t in right position or is stained from ink.
Anyway try the first solution first.
If you stll have trouble try to open the printer:
http://www.fixya.com/support/t211210-brother_mfc845cw
and have a close look to the encoder strip + disc (and look out for some paper in the edges... ;-))
Posted on Mar 22, 2008
SOURCE: "Unable to Print 50" BROTHER MFC-440CN
congrats! You just bought yourself a brand new printer! I just phoned the company and apparently if you have a teeny tiny paper jam and a Unable to print 50 pops up ... you just bought yourself a new machine, that particular message means your machine was damaged thru the course of your paper jam. The average cost an hour to fix it is $85 so its better to just buy a new one.. What a piece of ****. :-(
Posted on Oct 07, 2008
the kowalski
  • 86 Answers
SOURCE: message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Posted on Jun 02, 2009
  • 73 Answers
SOURCE: Brother Printer is reading ''unable to print 70''
YOu would need to remove jammed paper opening back cover.
Posted on Sep 23, 2009
Epson Photo PX710W Unable to print on photo glossy paper. Always a paper jam message. Will print fine on ordinary paper. (Will print 6x4 size on upper tray). Help!! Geraint.
Im having the same problem, will print on normal paper but when I try to print onto Glossy paper it comes up with paper jam,or paper not loaded properly is anyone else hjaving this problem? Please help!!
Caroline.
Aug 25, 2010 | Epson Office Equipment & Supplies
Had a paper jam. Paper was removed. It will not print. It keeps coming up with "unable to print 50" How do I get it to clear that off the screen?
hey... most probably some the paper jam has caused some hardware disruption... u need to remove everything removable and again set it up...
Apr 04, 2010 | Brother MultiFunction Center MFC-440CN...
Paper jam. caused error print unable 30
"Machine Error 30" (or "Unable to Print") indicates either a simple problem such as a paper or part of a paper stuck inside the machine, which of course is solved by opening the machine as much as possible and remove the reason for the jam.
Even a ripped part of a paper will be able to cause the paper, so it's important to be careful when taking jammed paper out to not rip the paper (do this by carefully pulling the paper among the same way as it would go when printing, not the opposite direction).
However, if that doesn't work, the error is mechanical (but still most likely caused by the jam, either a sensor getting dirty and unable to do it's work, or actually getting broken), and there isn't much you can do. If the message comes back right after turning on the machine, you'll have to have service performed on the machine.
Jun 16, 2009 | Brother MFC 240C All-In-One InkJet Printer
Message unable to print 50
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
TROUBLE SHOOTING
I am having a problem as well. I can't use the Fax either. Very difficult to see th jammed paper. Followed all instructions, but unable to clear the jam.
Feb 18, 2009 | Brother Multi-Function Center MFC-3360c...
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
UNABLE TO PRINT AFTER PAPER JAM
see here how to fix it:
enlagre the browser window to see pics better
Apr 25, 2008 | Brother MFC-845CW InkJet Printer
Print Unable 50 Brother MFC5460 CN
So dont let me be a withness of murderer:
There is no paper sicking within the machine! The jam had lifted the encoder strip out of the ph. After you have fixed it simppy stick some very thin scotch tape onto the ph cover to avoid further liftings (that will happen quite often...)
same issue: (change the viwing size of your browser to enlage the pics)
Mar 17, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother Mfc 250c Clr Inkjet P S C F Usb 6000x1200 32mb 22ppm MFC 250C Brother Logo
458 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
