Question about Fuji FinePix S5200 / S5600 Digital Camera
Finepix s5600 won't power on, have tried replacing batteries
Camera has sustained no damage or been dropped just stopped working.
SOURCE: focus error
hi i need help with my focus errar
Posted on Jan 18, 2008
SOURCE: s56oo fuju finepix camera focus error
Hit the lens (smack it on you're leg); that seems to be the solution..........
But try cleaning the lens and the AF assistent first!!
Posted on Dec 13, 2008
  • 5 Answers
SOURCE: focus error
You will have to disassemble the unit. 2 screws on 1 side and 1 on the other and 2 on the bottom, pop the back off, being careful of the 2 ribbon cables attached to the rear and unock these cables and remove. 3 screws holding the top circuit board (remove the eye piece first and unplug the 2 cables attached to it) carefully unplug all cables attached to this top board and unscrew and remove (there is one on the bottom of the board that you must flip to unlatch. After you remove that board there is the power board... BE CAREFUL!!! The flash capacitor (the black tube looking unit on the bottom of this board) stores chrge and you WILL feel it if you touch the terminals... it they touch metal you will see fireworks so be careful. unplug the single red and black wire plug and unscrew the 3 screws here You do not have to remove the white plug with the 4 or 5 wires because you can just flip the board over out of the uni.. BE CAREFUL!!. unscrew the 2 silver screws securing the metal plate underneath and remove this plate. now remove the single screw left and pull out the lens assem. Here check 2 places... 1 is he zoom screw (it is behind the long silver panel) and also the focus screw (behind the shorter metal panel. Do one at a time. remove the screws from one of them and carefully lift off the motor plate. for he zoom line to metal ring on the screw into the groove of the lens (Shaped like a V) carefully screw the screws back in bu d ni tighten to tight, leave a LITTLE slack. (1/8 turn from tight). Now for the focus screw, remove the cover and align the ring to encase the top of the V The ring is shaped like < the lens is a > so just allow the rinng on the screw to "pinch" the top of the lens groove. secure like you did the other plate (dont forget to back out 1/8 of a turn) reassemble the opposite of disassembly and you are done... it look hard but it is actually pretty easy... any uestions email me at worldin1@gmail.com
Posted on Feb 21, 2009
  • 244 Answers
SOURCE: Focus error on Fuji Finepix S5600
See my solution or email for help
Posted on Mar 10, 2009
MNfisherman
  • 11896 Answers
SOURCE: Internal battery of S5600 flat?
There is probably not much you can do but I guess you could try getting a newer battery.
Posted on Mar 31, 2009
Driver/software needed for fuji S5600 for windows 7
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 20, 2012 | Fuji FinePix S5200 / S5600 Digital Camera
Finepix s5600 10x optical zoom,i can not download pictures to nthe pc
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Oct 14, 2010 | Fuji FinePix S5200 / S5600 Digital Camera
The camera FujiSD8000 i have won't turn on. Used fresh batteries, has not gotten wet, but i was recently involved in a car accident and the camera was in the car with me when it happend. The camera looks...
Check the memory card or battery door for the tab that activates the cut out switch. It ,or the switch, may have sustained damage. I'm not 100% on this model but if it's like the S5700/ S5800 models then the memory card door has a tab for the cut out switch to prevent card removal whist powered up.
Apr 08, 2010 | Fuji FinePix S8000fd Digital Camera
Fuli finepix 5600 losing power very quickly, even with new and re-charged batteries. Can this be aproblem with the camera?
Try cleaning the battery terminals (with a dry soft cloth). Other than that it maybe component failure or moisture damage but this would depend on the enviroment to which it has been subjected to over a long period of time.
Jan 24, 2010 | Fuji FinePix S5200 / S5600 Digital Camera
I am looking for a replacement operators manuel for a Fuji Finepix S5200
Try looking under S5600 on the fujifilm uk website. The manual is identical because it is the same camera. The S5200 is the S5600 in the usa
Dec 30, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Finepix S5600 screen flashes
It sound as though you may have liquid damage in your camera causing electrical shorts or bad electrical contacts. Camera will have to be opened.
Jul 02, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Mar 31, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
S56oo fuju finepix camera focus error
Jan 23, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
CAMERA WILL NOT TURN ON
Try new good quality batteries.
i experienced this issue last night. Even after replacing the batteries i had the same problem though the batteries were from a very cheap pack & i'd had them a while. The camera worked fine once i'd recharged my normal batteries. I'm no expert but I expect switching the camera on must use much more power then review mode causing the camera to switch off before it has time to tell you your batteries are low.
Hope this solves your problem!
Sep 03, 2007 | Fuji FinePix S5200 / S5600 Digital Camera
Fuji FinePix S5200 / S5600 Digital Camera Logo
53 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
