Question about Building Materials
The garage door openers, motion sensor and their is no info. on the smart panel. What should I do?
  • 1,869 Answers
Align the door sensors so that they "see" each other
Posted on Nov 18, 2013
  • 3197 Answers
SOURCE: I DONT REMMEMBER HOW TO SET UP MY GARAGE DOOR OPENERS SENSORS ?
The sensors should be approximately 6 inches above the floor and must be pointed at one another to work. Each sensor has a solid white wire and a white wire with a black tracer. The white wires connect to terminal 2 and the wires with the black tracer go to terminal 3. The wires from the wall control connect to terminals 1 and 2. Solid white to 2 and white with red tracer to terminal 1.
Posted on Aug 04, 2009
  • 3197 Answers
SOURCE: I have a Sears garage door opener. The motion
The light will stay on as long as you are in the garage and it detects body heat. If you leave the garage the light should turn off.
Posted on Aug 22, 2009
  • 244 Answers
SOURCE: garage door will not shut with remotes.
Align sensors or replace,
Posted on Dec 29, 2009
  • 3197 Answers
SOURCE: Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: Can I bypass the sensors on my garage door opener?...
You cannot bypass the sensors but you can try reversing their position so that the sun isn't hitting the receiving unit. You can also move them back from the door or use something like the tube inside a roll of toilet tissue to shade the lens.
Posted on May 20, 2010
  • 3197 Answers
SOURCE: How do I turn off the motion sensor on my
There is a switch on the side of the wall control.
Posted on Oct 29, 2010
My garage door lurches while it is opening
If the alignment is true and rollers move with ease, you should not have any jerking motion. Unlock the door catch from the pulley line of the motor. The door should be FREE to lift by hand. With the door Free of the motor/line-pulley, lift by hand. Do so a number of times and see if it binds or is free to move up and down easily. If it binds, the alignment is off and needs adjustment. If it moves quite well, then the problem can be the door sensors. These are the two face to face sensing devices at the bottom of the metal guides on both sides. These sensors need to be horizontal and fixed to allow Line Of Site to operate correctly. Check both Alignments, Rails and Sensors.
Feb 03, 2015 | Genie Garage Door Opener 2562-TC 1/2 HP AC...
Remote controls, motion sensors don't work and their is no info. on the control panel.
If you want to realize remote control or parental control on PC,I recommend you to try professional third party software which has functions of site block and time control,etc.I have used parental control program of anykeylogger(www.anykeylogger.com),it works well,you can also find other fine programs on the Internet.
Nov 18, 2013 | Sears Craftsman LiftMaster Chamberlain...
The garage door will open with a single press of the button but will not close the same way. It will start to close - then reverse - unless I hold the botton down for the entire closing motion.
Check the door sensors. They must be pointed at one another and the small light on each one must be lit and not flickering. Tweak them if necessary. If you cannot get both lights to come on you have either bad sensors or the wiring to them.
Nov 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
How can I disconnect the motion detector on the Chamberlain 3/4 HPS Whisper Drive Plus Belt Drive Garage Door Opener with EverCharge
There is a button on the side of the wall-mounted remote. It has a pic of light bulb next to it. Press it once - the motion sensor is on and the lights will be on once it senses the motion; press it again and the motion sensor will be off.
Jul 19, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
I keep discovering the light is turned on when I enter my garage in the AM. How do I stop this?
If you have the door opener with the motion sensor you can try disabling that function. There is a switch to do so on the side of your wall control.
Jan 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
Aug 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Chamberlian Whisper Drive 1/2 Hp opener has an issue. My motion sensor back light blinks and the factory supplied remote does not work now. Help.
You wall control is in lock mode sounds like press and hold the lock button for 3 to 4 seconds that should take care of that problem.
Alleejr your problem is not the same and ill need little more info. Where is the red light on your wall control? If its on the way up its not your sensors at all. Is your spring broke?
Jul 21, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Building Materials Logo
95 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
