Question about Ecoquest Living Air Classic Air Purifier
Does not produce ozone, I have replaced the fuse, it has been cleaned and the amber light is not on.
  • 3 Answers
It's possible that the ozone generator inside has gone bad. The only way to really know is to remove it from the unit and then test it with a power supply w/correct voltage of coarse. You will smell the ozone immediately if it works upon testing. (clean fresh smell) If it does need replaced, it's an easy fix for anyone with electronics knowledge. You will need to match up the numbers to get the correct replacement. Many are available on Ebay. Always disconnect the power to the unit before taking it apart. Hope this helps, Dave
Posted on Apr 16, 2014
I have the Alpine Living Air machine - the green light does not come on just the amber one. I don't smell any ozone odor. Cleaned the plates but not sure if they have to be installed in any special...
How long have you owned machine? Plates need to be replaced periodically to be effective and to generate ozone. Depends on usage but at least every one-two years. They run about $15 a piece. I can get you some.
Jul 07, 2011 | Alpine Air XL-15 Air Purifier
Living Air XL (no smell)
TEST THE CONTINUITY OF THE BULB AND THE WIRING AND THE PARTS INSIDE.
DOES THE UNIT STILL WORKS NORMALLY ASIDE FROM THE BULB?
Sep 25, 2008 | Alpine Air XL-15 Air Purifier
Hi-I have the Living Air XL. It's out for repair because I cannot smell the distinct clean smell it normally puts out. The repair guy just called and said it's fixed and running, but the green light bulb...
He probably cleaned the unit and restored the plaques. Green light or no green light, it doesn't affect the production of ozone. If still in doubt, when you go to pick it up, have him operate fit or you before you leave the store. I've had one 7years and the green light hasn't worked for three years. I clean it regularly and it still produces ozone when needed. Regular, routine maintenance is the answer.
Mar 28, 2011 | Ecoquest Living Air Classic Air Purifier
My flair unit does not smell of ozone. Why ??
It properly needs the filter and interior cleaned. Especially, if it has run a long time without being cleaned. Or there is nothing in the household air at this time to trip the Ozone producing switch.
Feb 06, 2011 | Ecoquest Flair Air Purifier
My living air xl-15 prove it light does not come on anymore and it seems that the unit does not prodoce ozone. I tested the light in the normal postion set at 12:00 with the plate out but to no avail....
If you are sure that the plate is clean, in perfect condition, and inserted correctly, it would appear that the transformer is defective. This means that power is not going through the metal contact fingers into the plates.
The light probably has burned out. It is not essential to the working of the machine, so it isn't anything you need to be concerned about.
Vollara (formerly Alpine/EcoQuest) is no longer producing or servicing the XL-15. However, a newer version, called the Classic, is available. You can call Customer Service 800-989-2299 and they will tell you your options. Use #16618 if you need a referral number.
Jan 08, 2011 | Alpine Air XL-15 Air Purifier
I need an ionization wire for my ioninc breeze quadra air purifier where can I find one?
Any system using electric currents are deadly OZONE producers if your ozone producing machine is broken pleas don't fix it replace it look for any system with a filter not a electric current burning all the dust
Jun 28, 2010 | Sharper Image Ionic Breeze GP SI720 Air...
My Flair stopped working correctly,so I purchased new Ozone plates. It still doesn't provide that clean ozone smell. I took mine apart and cleaned it and noticed a small bulb inside that doesn't light up....
pull the unit out of the enclouser and check the bottom for a circuit board and on the board their is a glass fuse see if it is blown. Also on that same board their is a small round black fuse that is labled f21 it is a 400ma 250 volt fuse on my unit and is soildered in this fuse is just for the ozone
May 23, 2010 | Ecoquest Flair Air Purifier
Ozone not working
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
Mar 24, 2010 | Ecoquest Fresh Air Air Purifier
No Ozone
Mine has a switch lower right hand side that will stop the ozone.
Aug 31, 2008 | Ecoquest Living Air Classic Air Purifier
Fresh-air purifier does not geenerate ozone
The fan is bad it should blow the fuse, I believe that the mother board has a problem, or the Display board may have gone bad.
Nov 04, 2007 | Ecoquest Fresh Air Air Purifier
Ecoquest Living Air Classic Air Purifier Logo
296 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Kory Ronning
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
