Question about Dell V313w AllInOne InkJet Printer
Scan request failed - Dell V313w AllInOne InkJet Printer
2 Suggested Answers
SOURCE: requesting scan -
I've had the same problem occasionally when re-installing. There are a couple of ways to solve this.
1- Right click properties on "my computer" (or open "system" in control panel). Bring up the Hardware tab. Click on "device manager" button, then scroll down to see if there are any devices with a yellow exclamation point. if one is "scan" then the windows did not yet install it. (This can happen if windows installed the print drivers automatically before you actually installed your printer driver. Remember that even if the printer is turned off, it will still be recognized by Windows unless you disconnect the usb cord). Solution: delete the highlighted button. Then restart your computer. If you have already run the dell installation disks, windows should recognize and install the software. Be sure to have your disk inserted in the cd drive when you restart. Otherwise:
2- use your dell installtion disks to uninstall, then re-install. Hope it helps. :)
Posted on Feb 17, 2011
2003 saturn L300 p1780
DTC P1780 (3.0L (L81))
To improve shift feel, the transmission control module (TCM) may request that the engine control module (ECM) reduce engine torque during shift events. When such a request is received, the ECM responds by retarding the base ignition timing and notifying the TCM that the request has succeeded. If the ECM is unable to comply with the request, the ECM sends the TCM a message that the request has failed.
The torque reduction request is sent to the ECM through a communication network called the controller area network (CAN). Two circuits are used to communicate CAN data between the ECM and TCM. A fault in the CAN will not cause DTC P1780 to set by itself. If a CAN fault occurs, other DTCs will set before DTC P1780.
When the TCM receives a torque reduction failure message from the ECM, then DTC P1780 will set. DTC P1780 is a type C DTC. Take your pick of which you think this code is for , this or the TSB - technical service bulletin. What need to hook up scan tool an data PID'S - Do you know what PID'S are ? sensor data read on a scan tool .
Mar 04, 2016 | 2003 Saturn L-Series
Scan from pixma mp210 to pdf
I'd start right here:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp210#DriversAndSoftware
see if you can download the software you need, if that fails contact Canon and request a replacement CD, if that fails I'm sure that a minute or two with Google will find software to convert jpg to pdf,
Dec 15, 2013 | Canon Pixma MP210 All-In-One InkJet...
My scanner says "scan request failed" when I attempt to scan.
plz try by reinstalling the drivers, if the problem is not solved then scan the pc with updated anti viruse software
Aug 12, 2010 | Dell 926 All-In-One InkJet Printer
I can't scan with my printer
try to remove the driver software and after a restart re-install the driver on the pc and see what happens.
Dec 08, 2009 | Dell 926 All-In-One InkJet Printer
Dell photo 926 wont scan
Replace the USB Cable to a new one 3.0
Jun 10, 2009 | Dell 926 All-In-One InkJet Printer
Dell Photo AIO Printer 926 scanner
I want to scan pictures onto my computer to post them and when I push the scan button it says Requesting scan~ and then Scan request failed... Any ideas?
Mar 31, 2009 | Dell 962 Photo All-In-One InkJet Printer
Turn off confirmation page
log into the web administration page as administrator
choose fax/scan tab
report settings
Tx Report
choose turn on/off/if tx fail
I chose both single and multiple destinations
if tx fails
Tested scan to email and fax to bad addresses and page printed as confirmation of failure
No pages printed for successful Tx
Note - you can still manually request confirmation at printer menu
Fax/scan
fax menu
tx report
on
enter
start fax or scan to email
Nov 05, 2008 | Minolta bizhub 200 All-In-One Printer
SCANNING WITH LEZMARK X4450
I gave gotten it to retrieve the applications list by opening Lexmark Imaging Studio while it was searching, I AM however still unable to scan it connects to my comp I tell it to save as a file and it goes "Requesting Scan" then "Scan Request Failed"
Jul 13, 2008 | Lexmark X4550 InkJet Printer
Dell V313w AllInOne InkJet Printer Logo
35 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
