Question about Champion AC35 MiniBrute Magnetic 1-3/8" Drill Press
WHERE DO I BUY PARTS FOR CHAMPIOM MINIBRUTE AC 35
THE MAGNET IS SHORTED AND I WOULD LIKE TO REPLACE IT
    Genius:
  • 1,114 Answers
I couldn't find parts for your drill, but if you call or e-mail the manufacturer hopefully they can help you.
Department Inquiries
Customer Services
Phone: WHERE DO I BUY PARTS FOR CHAMPIOM MINIBRUTE AC 35 - call_skype_logo.png516-536-8200
Email: info@championcuttingtool.com
Posted on Mar 29, 2014
A/c clutch fuse blows on 06 hummer
The AC clutch contains a field coil that creates a magnet pull on the drive plate, that field coil is shorted, replace it. You need a special puller to remove the AC pulley to access the coil.
Jun 16, 2012 | 2006 Hummer H3
Split system turns off after 35 minutes. Vanes close but operation green light blinks four times. By pressing on/off switch on remote - green light stops blinking. Press on/off switch again, system starts...
Out door compressor getting over heated. Check freon pressure. May be short of gas. If fan motor less rpm, replace capacitor. If condenser dust blocked,m clean it.
Jan 19, 2011 | Heating & Cooling
2002 CAMRY AIRCONDITIONER WONT RUN ( COMPRESSOR) LOOKING FOR RELAYS.
-ello, and welcome to FixYa.
The first thing you need to do is replace the probably bad AC Magnet Clutch relay with an updated relay.
The part number on the side of the bad relay is 90987-02022
Buy a replacement relay from a Toyota dealer, part number 90987-02028
This should get you fixed up, there is a Technical Service bulletin issued that address this concern.
The relay is in the main fuse/relay panel under the hood.
Thanks for choosing FixYa for advice.
Apr 13, 2010 | 2002 Toyota Camry
I have a 2003 Dodge Stratus 2.4L DOHC Engine. The
it went from a hard cam sensor failure to an intermittent theres no magnet just a raised portion on cam.i think you got a loose terminal in the connector or a wire shorting or partly open from the sensor to the pcm
Mar 25, 2010 | 2003 Dodge Stratus
My honda 92 engine stops running when i engage the AC
is your AC pump turning? if not that couild kill an engine...theere is also a switch-usually on the pump- that controls engine speed when ac is on and pump kicks in, this might be faulty...problem usually confined two these two scenarios......hope this helps
Feb 26, 2010 | 1992 Honda Accord
I am looking for a carbon brush housing replacement part for an AcDelco 1/2 inch Electric impact wrench Model # AC-PT012 can you help?
You can buy at Nappa auto parts stores. Please rate as this is a short answer and if you don't rate it it hurts me.
Feb 19, 2009 | ACDelco AC-PT012 7 Amp 1/2-Inch Impact...
Powermate PM0496500.02 No voltage output
Here is a simple test to check field and other wiring. With engine off apply 12v ac 1 amp to 110v outlet plug on generator. This will energize the field windings and should cause the armature to produce dc voltage at the brushes and produce a nice magnet. If there is a short in the field or broken wire or shorted capacitor there will be no dc reading at the brushes. . This test is the opposite of what actually occurs when the engine is running. That is the armature produces a magnet fed thru the windings, regulator and brushes. If dc voltage is present at the burshes, remove 12v ac and start engine to check for output. enjoy
Oct 23, 2008 | Coleman Powermate Premium Plus 6250W...
The magnet for the speed sensor in my kitchanaid blender
what I can do for you is you should refer to your manufacturer/ store owner of your device for safer procedures.ok?
Jan 22, 2008 | Braun MR 290 MultiQuick Handheld Blender
Champion AC35 MiniBrute Magnetic 1-3/8" Drill Press Logo
871 people viewed this question
Top Champion Drills Experts
Are you a Champion Drill Expert? Answer questions, earn points and help others
