Question about Sunbeam SCM1896 Humidifier Filter Wick 12-Pack
How to clean/access fan blades on sunbeam SCM1896
Humidifier light goes on. Fan does not work after cleaning it.
Humidifier Fan Not Working - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/...Fix...Humidifier/...---/Humidifier-fa...
Most Frequent Causes for Humidifier fan not working. For the most ... If the fan blade does not spin freely, replace the blower motor. If the fan blade spins freely, ...
How to Fix a Humidifier ' HomeTips
www.hometips.com/repair-fix/humidifier-doesnt-work.html
Aug 14, 2014 - Repair humidifier problems yourself with this expert, step-by-step ...6Lubricate the fan motor bearings with a couple of drops of light oil if the ...
Troubleshoot and Repair a furnace mounted Humidifier
www.instructables.com/.../Troubleshoot-and-Repair-a-furna...
InstructablesThis instructable will explain how to diagnose and, hopefully, repair a broken ... to flow through the water panel of the humidifier and the humidifier fan turns on. .... drain line was dry, GFI was not tripped, and the fan sounded like it was going so I ... Arduino · Intel IoT · Indoor Gardening · Lighting · Sewing · Parties · Star Wars.
Dec 29, 2015 | Holmes Sunbeam SCM3501 Cool Mist Console...
Clean the fan blades
Don't use a hose, it will rust the motor and bearings.
if the blades are metal, and the unit is detached from the furnace. Try carburator cleaner or brake cleaner - out doors away from flames. Also, rotate so no solvents get to the bearings and wash away he lubricants. The solvent evaporates quickly but it will take a minute so don't be too impatient to get to the next blade.
If they are just dusty, and you don't want to dismount the unit, try some canned air - office stores carry this for cleaning keyboards and such. To get a really good stream, turn the can upside down and spray. The liquid propellant will come out and makes a really good cleaner. It will be cold cold cold as it evaporates and some ice will form if the humidity is high enough.
Effectiveness will depend on what is causing the dust to stick to the blades - oil film, soot from wood/coil/fuel oil and cigarette smoke are difficult.
Mar 10, 2014 | Essick Air MA1201 Moist Air Whole House...
How to clean fan blades on sunbeam humidifier model 1118
I picked up a Sunbeam Humidifier model 1118 for $7 (which was $7 too much) second hand. It wasn't until I got home that I noticed it was filthy-dirty inside...(dirtier than shown in the photos) the reservoir, the bottom tray, AND the fan chamber all needed major cleaning.
A quick Google search told me that the grill is "not removable", and the unit is "not user serviceable". Companies do this/say this for two reasons:
a) They want you to throw it away and buy a new one, landfills and plastic filling our oceans be darned
b) They want to protect themselves from lawsuits, should someone injure themselves servicing their product (or in this instance, cutting their fingers off on the fan blade).
Imagine if all of that design know-how was put into making the product serviceable, cleanable, and long-lasting, rather than ensuring it can't be opened or repaired by the average joe.
Me, I've opened and repaired enough gadgets to think differently.
You CAN remove the grille.
Carefully insert a series of flat-head screwdrivers between the grill and the body a few inches apart, wedging the grill edge away from the body.
There are slits in the body (see photos) that will allow you to get under the grill edge and pry it right out when enough of it has been detached from the anchoring groove.
But be gentle while you're doing it.
The Grille is plastic and flexible; it will bend, but if you use too much force you will damage either the grill or the body.
The photos also show how the grill is anchored to the body - via a groove in the grille edge.
You can put the grille back after cleaning the blades and fan chamber much the same way; pressing down, and if required: prying the side of the grill inwards with a flat head screwdriver.
Mine snapped right back into place with a bit of downward pressure.
e766f363-7859-4f48-aa12-957dce77dc74.jpgclean-fan-blades-sunbeam-humidifier-gt2v12ze2wx14lgcssczfxw0-1-2.jpgclean-fan-blades-sunbeam-humidifier-gt2v12ze2wx14lgcssczfxw0-1-3.jpgclean-fan-blades-sunbeam-humidifier-gt2v12ze2wx14lgcssczfxw0-1-4.jpgclean-fan-blades-sunbeam-humidifier-gt2v12ze2wx14lgcssczfxw0-1-5.jpg
Jan 22, 2012 | Sunbeam Humidifiers
Humidifier runs but no cool mist comes out.
1 amp fuse on circuit board blown... replace
Feb 12, 2011 | Sunbeam 701 Humidifier
I'd like to clean my sunbeam warm mist humidifier
if you mean by stone build up, you need a de scaler such as clr from any hardware store. let it soak on the crusty parts overnight the rinse well with water. toothbrush helps too.
Nov 25, 2009 | Sunbeam Health at Home Warm Mist...
I can't remove the grill above the fan so I can clean the blades
I have a Holmes cool-mist One-Touch Humidifier, and you can't reach the blades to clean them, and you can't take the console apart. I finally decided to use two spray bottles and clean and them rinse the Humidifer while holding the console upside down and over a sink. The one bottle you could fill with any mild cleaner plus a lot of water to dilute the cleaner. Maybe dishwashing liquid (not the dishwasher stuff), or a little bit of ammonia, or rubbing alcohol, or vinegar. Spray that on the blades while the machine is upside down, and a lot of sooty dirt drips out. Then rinse with another spray bottle full of plain water. Leave the console upside down on a towel to drip-dry. This is also how you can clean silk flowers that collect dust.
Mar 07, 2009 | Holmes Products Cool Mist HM3500...
How to clean up?
the best way to clean the fan blades is to take like a paint brush or some type of brush and clean it that way. there isn't a way to take that apart. if you try to it can be difficult to put back together. if you have any other questions please let me know
Dec 29, 2008 | Bionaire Humidifier BCM657U Humidifier
Sunbeam ultrasonic humidifier runs but produces no mist
It sounds very much like the transducer has failed. This is likely a crystal transducer and since they produce the agitation that should cause a mist, they are running continuously; not a good thing for something that is trying to shake iteslf apart all the time. These require input from a circuit that produces the fairly high level of power needed to drive the crystal so it could also be the source of the problem.
This isn't something an owner is able to diagnose unless they have some technical training.
Nov 08, 2008 | Sunbeam Ultrasonic 81696 Humidifier
Sunbeam SCM1896 Humidifier Filter Wick 12-Pack Logo
69 people viewed this question
Top Sunbeam Humidifiers Experts
Paul Sikkema
Paul Sikkema
 steve
steve
Are you a Sunbeam Humidifier Expert? Answer questions, earn points and help others
