Question about Proform Crosswalk 397 Treadmill
It won't light up and the reset won't make it work like there's no electricity going to it.
Putting the key on does nothing its plugged in and the receptacles work but no power and the reset doesn't help
  • 2,005 Answers
Replace the fuse in the power section where the power cord goes into the machine
Posted on Nov 18, 2013
No electrical power, replaced battery still nothing
Hi, Mike you might want to check your main circuit fuse and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have nice a day.
What Do Check When My Motorcycle Won Start Honda Shadow Forums Shadow...
Steps to Take When Your Motorcycle Won Start Dennis Kirk Powersports Blog
What to do When Your Motorcycle Won Start
troubleshoot motorcycle not starting
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 13, 2016 | Motorcycles
Software sgf f250
It's probably a minor problem take it to the dealer it may be a computer malfunction the new cars got more technology than ever probably don't got actual key on it to start up. It could be a starter or spark plug or check the oil and fluids properly put check your manual to get the right fluids in it.
Jul 14, 2013 | Cars & Trucks
2003 Ford Focus Engine won't turn over
Try crossing the starter wires, it should turn over. Is key ok, maybe its not coded? Also check connectors on starter . Try disconnecting battery for 30 mins, might reset electrics.
Apr 05, 2013 | Cars & Trucks
I tried to start my car this morning. There was no electricity at all and i mean at all, The power locks won't even work nothing. The car won't start, it's perfectly silent when you turn
You would need to use a meter or test light to find out what exactly is dead. It could be a short in the fuse box, or a bad connection in the harness, or at the battery or starter.
You may need a repair book or shop manual to get the wiring diagrams.
If nothing on the truck works, you would start at the battery cables and work back to the key switch.
Mar 03, 2013 | 2001 Mazda Tribute
2009 street glide won't crank
Hi Carl, you may need an alarm reset, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections check negative cable at both ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to on.
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
7. Security alarm not disarming
For a prime suspect please visit website below and good Luck.
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Sep 12, 2012 | 2009 Harley Davidson FLHX Street Glide
2002 kia spectra automatic - sometimes won't start when key is turned, all electrical systems go on but nothing to the starter. After several tries it miraculously starts but sometimes can set for a...
check your battery sometimes it will have enough for lights put not kick in starter then check alternator take to auto zone when running the will test free
Oct 17, 2011 | 2002 Kia Spectra
The unit worked fine when i last used it in the fall. I plugged it back in today and all the buttons lit up for about 1.5 seconds and then all the buttons went dark again. So I pushed the "on"...
I have had a problem like this in the past you can try taking the electric access panel usually on the side of the equipment. then look inside you will see a wiring harness inside and it literally takes nothing to bump it loose. This happens when people move these units they are pretty fragile and can be tempermental. Make sure the unit is unplugged while you adjust the wiring harness. If that deosnt work your display board is probably bad. Hope that helps
May 10, 2011 | Haier ESA3125 Wall/Window Air Conditioner
Reset button ?
Sometimes there is a reset button and sometimes you have to reset it through a menu. Of course, if it won't turn on, then you can't get to the menus.
May I ask, what is you Toshiba camcorder's model #?
Jul 31, 2010 | Toshiba Video Cameras
2001 Explorer; anti theft light steady; no power to car
take the positive side of the battery off for about 3 seconds and then put it back on to see if this will reset the security code
Apr 26, 2009 | 1994 Ford Explorer Limited
Proform Crosswalk 397 Treadmill Logo
163 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
