Question about Garden
TRACTOR WILL NOT STAY RUNNING
100 SERIES
  • 51 Answers
Give it a tune-up, spark plug, oil change, fuel filter, air filters... Drain gas completely from gas tank and carburetor... Fill with fresh fuel. White smoke from muffler means there is water in the system... Fuel "goes bad" as soon as 1 month.
Posted on Nov 18, 2013
NEED PDF Owner/Operator Manual?
You can find one here. It is for the 100 series :
http://www.homedepot.com/catalog/pdfimages/fd/fd904936-46bd-471e-9536-7c3ca3698e81.pdf
Apr 01, 2016 | John Deere D110 42 in. 19.5 HP...
John Deere L130 riding lawn tractor will not start what do I do?
I'm assuming the motor will crank over, but not start. Remove the air intake cover & filter off the carburetor air intake. Do you smell gas? Is gas dripping out of the carburetor? If not, spray a couple shots of starting fluid or carburetor cleaner into the carburetor air intake throat. Close the choke & crank the engine. If it starts, & stalls, repeat the process. If it won't stay running, your carburetor float jet is gummed up & needs to be cleaned. Check & clean the spark plug. Does the spark plug fire when the engine is cranked? If no, then you have an ignition problem.
Mar 05, 2016 | John Deere L100 Series
I need a belt diagram of John Deere L120 mower deck
Belt path for JD 100 series, 42" cutting deck, 2 blades.
Sep 14, 2014 | John Deere L100 Series
When I push and hold the start button the tractor starts and stays running, if I release the start button it shuts off, if I remove the wire to the solenoid relay it stays running
It sounds like a "Load Resistor" problem, not sure if you have this type of starting system. The load resistor is in the wiring that goes to your coil after the engine has started. It is bypassed when starting to offset the loss of voltage when the starter is engaged and turning over the engine, then after the engine has started the "Load Resistor" is again in series with the points dropping the voltage slightly and providing longer point life. If this resistor burns out then you would be able to start the tractor but as soon as you released the starter foot switch the points/distributor would no longer have voltage. The Load Resistor is a large gray, brown or white colored rectangle ( 3" long and about 1/2wide aprx.) mounted on the back side of your dash panel....
Sep 01, 2014 | Ford 8N Tractor
JOHN DEERE LAWN TRACTOR 145 SERIES, RUNS OK
When you start to have this problem loosen the fuel cap and see if that makes any differance,there is a small vent hole in the cap that can get plugged.When it gets plugged your fuel tank will develop a vaccum and cause you engine to starve for fuel.Im not sure on this model but the older 100 series had a problem with the fuel line being pinched between the frame and the tank.
Feb 22, 2010 | Sport & Outdoor - Others
Cub cadet has no power changed battery still no
Blown fuse. There is a fuse somewhere thats blown. It will be about a 15 amp in a fuse holder either back by the battery or behind the dash. U didnt specifiy the 100 number If thats a starter-gen it could be a reg- relay issue.
Oct 22, 2009 | Cub Cadet Street Sign- tractor lawn riding...
John Deere tractor
Ok Simple Rule
V BELTS go in V pulleys
Flat pulleys get the back of the belt. You must take the deck off the tractor to do this properly. Look inside the hood I have seen belt diagrams there or on top of the deck.
When all else fails Go to the JD Dealer they will gladly help.
Sep 29, 2009 | Garden
How to put on belt 100 series jd 48 cut belt.cant figure out how it goes on
Check out this link to some videos of changing the belts on a lawn tractor. Hope this helped and best wishes.
http://www.youtube.com/results?search_query=replace+belt+on+lawn+tractor&search_type=&aq=f
Aug 17, 2009 | Garden
The engine will not stay running (Ariens 34' Zoom)
a lawn mower is not much different than a car, you still need 3 things to make it run: fuel, electricity, and a spark. you say it doesnt stay running, Before trying to make any repairs, ensure that you are using the correct fuel, also make sure the fuel lines are not leaking or crimped. if the lines seem fine, check the fuel filter and/ or fuel pump. though the mower is new, they can still have faulty componets.
Jul 24, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
