Question about Sharp Heating & Cooling
Fan stop and then turns back up again
This is regarding my Sharp air con (Model: AH XP13NRV) inverter type with plasma ionizer 1.5 hp. After turning my air con about half an hour in cool mode and maximum blower speed, the blower will suddenly stopped and turns back up again. The indicator lights are still on and not blinking. No warning sound was heard. We did not turn on any sleep mode or any auto turn-off mechanism. Occasionally, the louver will flip itself to close position. This is very weird.
  • 1,906 Answers
Replace the run capacitor
Posted on Nov 18, 2013
    New Friend:
Maybe its the cord shorting out
Therinnaiguy
  • 1420 Answers
SOURCE: no cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Posted on Sep 04, 2007
ranger25
  • 72 Answers
SOURCE: Air con
Could be the thermostat or the low voltage line to the outside. Usually a dog chews through it or the weedeater hits it and breaks connection. Turn on cool, go outside and see if it gets 24 volts to the two wires going to contactor (have to take off cover to get to it) DO NOT TOUCH THE CONTACTOR IT HAS 240 V AT ALL TIMES, unless disconnect is thrown, so turn it off. If you aren't getting anything, then it's either the low voltage wire broken somewhere or the thermostat malfunctioning. Make sure you turn off the inside unit before messing with thermostat or you will pop the transformer. If it pulls the contactor in, and you still aren't getting anything, then check for voltage on the load side of contactor (opposite from the inlet or lead side). If you are and you hear a hum from the compressor and the condensing fan motor is running, then it's your compressor. You'll have to remove the top cover to do the next step. Check to see if it when to ground by using a meter set on resistance and with the connector to the compressor removed, put one lead on one of the copper pipes going up to it and touch the other lead against any or all of the pinouts on the compressor. If you get a reading, it went to ground and you will need a new compressor or whole new condensing unit, depending on the age of the one you have now.
Posted on Jan 27, 2008
  • 50 Answers
SOURCE: Fan Stops blowing air
Isthis a window unit? It sounds like it. There could be a problem with your fan switch or the fan motor itself? Multi-speed motors can lose one speed at a time. It really sounds like the fan motor is bad. If the compressor starts in the cool mode, and the fan doesn't, the fan motor could be locked up. See, if you can spin the motor by hand? If you can, then something is bad within the motor. Now, if the motor has a capacitor, check for a loose or burned wire. Good luck.
Posted on May 18, 2008
  • 182 Answers
SOURCE: Blower starts ans stops
May be a short in the wiring or a bad control board.
Posted on Jul 08, 2008
daddyo742001
  • 70 Answers
SOURCE: continous blinking of the green light
Try shuting off breaker for a few minutes and try again. Wash out outside coil.
Posted on Jun 29, 2009
Flickering Sharp Aquos tv
it really depends on were the flicker is, if its the backlight or the screen, flicker can mean them both, t-con board only controls the screen out put on lcds, but on plasmas it works with the back light inverters. if the screen is white and not flickering while looking at the back of the screen on an lcd then it could be the t-con board failing it could also be a bad connection to the board from the wires. the plug were the main board connects to the t-con board if you have the back off and wiggle the cable and see if it stops the flicker.
Aug 08, 2017 | Sharp Televison & Video
Inverter manuals
Model No Required below Model No AH-X18MEV Self diagnosis mode given
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
• If the power cord is unplugged or the circuit breaker is turned off, the self-diagnosis memory is lost.
AUX
Operation lamp(red)
Timer lamp(orange)
Super jet lamp(green)
Oct 12, 2013 | Sharp Heating & Cooling
I have a 5 HP Coleman air compressor. I was using it to provide air to my plasma cutter which requires 60 psi to operate. Basically, air compressor's motor keeps running, but it's stopped creating air...
You did not list model number, however if you have oilless type check the cylinder/piston by manually turning crank until piston is at top and examine cylinder for wear or scratches. If worn replace cylinder kit for full pressure. If ok check reed valves /valve plate for wear or broken reeds. If oil bath type, problem is usually air leak or reed valves / valve plate. As a general rule, you can keep track of wear by noting how many minutes it takes to fill the tank to cut-out. As the compressor wears it will take increasingly longer to fill. When new, and depending on tank size/ hp, most compessors fill within 2 ~ 5 min. Good luck
Sep 24, 2010 | Coleman Air Tools & Compressors
I buy a new power inverter ERP 2300 12v/220Volts
What does the inverter over 600 Watt.
By what type of battery is the inverter supplied? How many Ah? What is its state?
In order to achieve 1000 Watt for 1 hour you need a fully charged 12 V / 100 Ah lead-acid battery.
If your battery is less then 100 Ah and is not very well charged or old (bad) you may not have over 600 W, but not bacause of the inverter, but the battery.
If your inverter stops due to low input voltage (you can see it in the digital display during operation).
If you want to check the real output power of the inverter you should connect it to a big (more than 200 Ah) well charged battery.
Jul 22, 2010 | PowerBright Power Bright ERP2300-12...
I have a ford falcon ef sedan and whenever i use the air con the car starts to overheat (ive never let it get past the o in normal on the gauge) and i lose massive amounts of water. if i turn the air con...
What type radiator fan do you have? Fixed cconstant , viscous variable speed or electric?
Does it run cooler at highway speeds above 35 mph?
What is the pressure range on the radiator cap?
Is the coolant mixed at approx. 60/40?
Is the condensor and radiator clean and able to pass enough air?
Is the fan shroud on?
Genuine concerns, let me know, good luck
Jan 23, 2010 | 1983 Ford Fairmont
Lasko ionizer 48" fan
Hi suedevito,
In case an electrical appliance does not do anything anymore, I always first check the fuse(s). There can be a fuse in the electrical plug (in case of UK-type of plug for example) and possibly also somewhere within the fan's housing. In case you do not know how to measure a fuse, just simply replace all the fuses in one go with a new fuse of the same (!) rating. I hope this will solve your problem.
Nov 08, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
SHARP AIR CON DOESNT STAY ON AND IS'T COLD
BUY A 100$ AC UNIT FROM WALL MART I DID P.S CHECK YOU FREON ITS HOT DUE TO COMPRESSION NO PROBLEM =]
Jul 04, 2009 | Sharp AF-S120FX Air Conditioner
Air Con cuts in and out and so does cooling fan
I have a 2008.5 Mazda 3 GS Sport and when you turn the air flow selector to windows or windows/floor, the air condition will turn on automatically. (Can't turn it off.)
Nov 12, 2008 | 2008 Mazda Mazda3 Hatchback
Error code on air conditioner e1
Search for this problem on web or contact Sharp Technical Support for the following procedure:
1. Unplug unit.
2. Hold down power button while plugging in unit. It will do a short self-test and then beep. leaving unit off.
3. Release power button and unplug.
4. Plug in again and turn on normally. This should last for about 720 hours, at which point the E1 error will come back and you need to follow the procedure again. (You might as well clean the air filter at this point just in case it really needed it...)
Jun 09, 2008 | Heating & Cooling
Heating & Cooling Logo
112 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
