Question about Ovens
Kemore electric oven popper and flash no heat or clock
  • 1,869 Answers
Replace your oven heating elements then reset your house circuit breakers
Posted on Nov 18, 2013
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: oven not heating but the fan is working and clock flashing auto
You need to rest the timer. to get it off auto,otherwise the oven will not work.
Refer to your instructions.
Posted on Dec 07, 2008
SOURCE: Clock flashing OOO continously
I have same problem - the timer just blinks at me "0.00". I have tried every combination of buttons, can anyone help ?
Peter A
Posted on Nov 14, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Whirlpool Oven will not heat
Hello there:Usually,
when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. bullet.jpg If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. bullet.jpg Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. bullet.jpg Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. bullet.jpg If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Posted on Jul 25, 2010
Oven is not working its 5 years frigdare electronic elements are ok
Try setting clock before presuming board is faulty, ovens shouldn't work if clock is flashing or timer is counting down or bell symbol flashing. Consult your instructions
warmest regards
Richard The Repairman
Mar 29, 2014 | Frigidaire FEB30S5D Electric Single Oven
My Neff U1421 bottom oven has failed.
Probably the ring element. If the clock is flashing zeros or 8's the bottom oven will not operate but the top will. Make sure the clock is set (doesn't have to be the correct time, just not flashing) If the fan and light then work but no heat, defo the element part no 499003
Mar 21, 2013 | Neff U1421 Double circotherm Electric Oven
Clock constantly flashes `A` and cannot get top or bottom oven to come on. Have tried resetting the clock but the buttons do not appear to be functioning. The mains power `has` been off due to having a...
It looks like the clock has failed. Try leaving the power off for at least 10 mins, turn it back on at the main switch and then try it. If it still doesn't work Espares can get you a new one. Incidentally, if there is power to the oven, the grill will work even if the clock is not set.
Jun 28, 2011 | Stoves 720EF Electric Double Oven
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
Clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Apr 28, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Frigidaire free standing range
Please post the model number for he stove in question. Its harder to advise without it.
regards
Nov 21, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven not heating but the fan is working and clock flashing auto
Oct 20, 2008 | Neff B1421 Electric Single Oven
Gaggenau EB 270/271 Electric Clock
To set the clock:
1. Press the clock key 3 items until the hr/min icon flash.
2. Press the + or - key until it come to your desired time.
3. Press the confirmation (check) key.
You have your time.
If not, call the service support.
Aug 21, 2008 | Gaggenau EB 270/271 Electric Single Oven
Zanussi oven wont work. clock flashing 'auto'
you need to set clock before oven will work. do you still have instruction book as it will tell you there how to do it
Jun 18, 2008 | Zanussi ZBQ665 Electric Single Oven
Ovens Logo
46 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
