Question about RoadPro Road Pro 12 Volt Dc Portable Battery Jump Starter & Air Compressor 12V Dc Portable Battery Jump Starter & 260 Psi Air Compressor
MY pEAK 450 BATTERT CHARGER WONT RECHARGE WHY
  • RoadPro Master
  • 10,291 Answers
The internal battery may be too old to be useful any more.
Posted on Jan 29, 2014
What specifications do i use to get a replacement charger for a Peak Charging Adapter . . . . . . . . 120 volt AC (700mA, 12 volt DC Output
Just as your information says ask for a 12 volt 700 ma charger..but seeing that yours is a 450 amp jumper..any 12 volt that fits your ac input will do the job...one more thing if you do not have a charger..just connect it to your battery and run the engine for 20 min or so it will recharge the car battery and you jumper..also you can get a lighter wire with two lighter plugs and charge it through you lighter..good luck
Oct 22, 2014 | 450 Amp Jump-Starter with USB and 12 Volt...
I need to know how to recharge my 450 amp jump starter
There is a charging port on the front of the unit next to the LED work light.
The wall charger it came with, is a 12VDC 500ma.
Positive center coaxial connector.
Radio shack usually can match the unit if you bring it in to them.
My charger was pouch Velcro-ed to the unit.
Kings Model KU3B-120-0500D
Jan 27, 2014 | PEAK PKC0BJ 450 Amp Jump-Starter USB Power...
I need a 110/120 volt ac/dc adapter power cord for recharging from standard wall socket. For a Peak 450 jump starter
After searching the internet for a ph number for Peak power I finally found the web.
http://www.peakauto.com/contact/site.
phone 800-323-5400
If the part department doesn't have the answer ask to be switched to tech support.
They were able to provide me with the part numbers I need for new wall supply cord and an DC adapter for the car.
My jump starter is no longer made...
Nov 15, 2013 | Peak Performance Peak PKC0BL 450 Amp Jump...
Need charger for Peak Power System 450 Plus
This unit should plug directly into an outlet-all you should need is an AC cord-cheers-Denny
Oct 03, 2013 | JUMP START SYSTEM
Ac Power Adapter
It sounds like you have a two wire outlet and a three wire cord on the charger. I would suggest either getting the outlet properly changed with a proper ground or use another outlet.
http://allpowersupply.com/Productlib/manual-PKC0AZ.pdf
May 22, 2013 | Tools & Hardware - Others
Charging a peak power portable power system 450 plus
Do I have to recharge it regularly before the battery goes down to uncharged. I'm talking abt peak 450 plus
Jan 07, 2013 | JUMP START SYSTEM
NS-DCC5HB09 High Definition Flash Media Camcorder: mine wont turn on and i dont have a charger!!! Hel...
You should be able to recharge this unit by connecting to your PC and charging through your USB connection.
If your battery is faulty or unable to recharge, here's a replacement battery that's available:
http://bestbuy.partsearch.com/GetModel.aspx?MfgName=Best+Buy+Company+Incorporated&BrandName=Insignia&ModelNumber=NSDCC5HB09&Page=1&SortBy=brandname&SortDirection=asc
Just about any AC to USB charger will work to recharge this unit, so if you have an iPod with the iPod wall charger, use the correct USB cable with the wall charger and you will be able to recharge the battery in the camcorder.
Hope this helps!
May 11, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
Lost battert recharger
The only place I know of where you can get a charger for that vehicle is little tikes directly. Call 1-800-748-2204
Thanks!!
Mar 02, 2009 | National Little Tikes Junior Quad
Cannot recharge camera
I didn't really solve the "problem". I plugged the charger into a different electrical outlet and PRESTO, the camera began to charge. The outlet I had been using, malfunctioned and had to be replaced.
Easy solution this time.
Nov 21, 2008 | Fuji FinePix 4500 Digital Camera
RoadPro Road Pro 12 Volt Dc Portable Battery Jump Starter & Air Compressor 12V Dc Portable Battery Jump Starter & 260 Psi Air Compressor Logo
274 people viewed this question
Top RoadPro Air Tools & Compressors Experts
Lawrence Oravetz
ray gallant
 Bob Oppenheimer
Bob Oppenheimer
Level 1 Expert
Are you a RoadPro Air Tool and Compressor Expert? Answer questions, earn points and help others
