Question about GE 106585 Upright Vacuum
Where can i buy a filter near me in metairie, la
  • 1,869 Answers
Http://www.amazon.com/s?ie=UTF8&page=1&rh=n%3A1055398%2Ck%3AGE%20Vacuum%20parts
Posted on Nov 18, 2013
Filter near brushes keeps popping out
I am sorry to hear you are having difficulty with your filter. Based on the details you provided we would appreciate the opportunity to trouble shoot with you. We may be able to resolve the problem over the phone. It is also possible part replacement may be necessary. At your earliest convenience please call us directly at 0800 298 0298 (UK). We are available from 7:00 a.m. to 10:00 p.m. 7 days a week. We look forward to speaking with you.
Best wishes,
Jessica
Aug 14, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Vacuum has lost suction and is making a hissing noise
I had the same problem with my Kompressor.Initially I had cleaned all three removable filters.There is two in the canister that can be washed with dish soap. The HEPA filter is located in a compartment on the lower front side of the vacuum.This HEPA filter should not be washed.I found that tapping it inside a trash can dislodged alot of dust from it. After cleaning all the filters and canister I was having the same hissing noise coming from a small hole near the bottom of the vacuum. Next I removed a hose fitting on the lower back of the vacuum and that is where I found a very large amount of debris clogging up the hose. I used a metal coat
Nov 11, 2011 | LG Kompressor Upright Vertical Cyclone...
Dyson dc 25 bottom filter keeps blowing out
Mine did the same thing - unfortunately, that means it's dirty. When they recommend a good cleaning of the filters every 3 mths - they mean it. The filters may not look dirty, but if you skip cleaning them (like I did) - those tiny little particles build up & then clog the filter. The bottom filter is not cheap - you can pick it up online for about $55, considering the alternative (running the Dyson w/o the bottom filter - and yes it will run without it) which may result in damaging that very expensive motor - go buy a new filter. It's cheaper than buying a new Dyson or replacing a burned up motor.
Jul 02, 2011 | Dyson DC25 All Floors Bagless Upright...
No sucktion.
clean the filter ( blow it out with a air compressor if you have one ),, also, after cleaning the filter - check the whole hose for blockage,, especially near the bottom near the floor sweeper.
c...
Dec 31, 2010 | Euro-Pro NV31 Infinity Vacuum
Was turning on then off then back on now can not get to start at all even if i jump the low voltage line
Ensure filter is clean. Check switch near filter.
Try reset switch.
It could very likely be the circuit board/power module in the machine near the motor. It could also be a worn out motor. It's best to take to the nearest Aerus Electrolux store and let a service tech check it out.
For the store nearest you, follow instructions on below site.
http://www.aerushome.com/storelocator/
Nov 13, 2010 | Electrolux Central Vacuum
Filter cleaning
The fact is that the "bagless bandwagon" is powered by some excellent marketing that conceals what is often poor technology. In your case, the filter blocks because it's doing the job that a bag would do in a bagged machine (catching the dust), and then the machine overheats because the flow of cooling air to the motor is restricted. The only solution (for this machine) is to keep buying new filters - the only permanent solution is to buy a different vacuum cleaner. And my advice is to buy one with a bag!
Nov 03, 2009 | Dirt Devil M0105 Bagless Vacuum
Back filter and its door blows off as soon as I turn it on.
thats good has good suction i guess there should be a cover on that back filter if you can't find you can tape it down leave air coming out
Jan 31, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Vacuum pick up stopped
I noticed a flap covering the filter and this hindered the air flow. I made sure it wasn't covered and, Wa-La, it works perfectly again.
Thanks anyway.
Dec 22, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Where do you put the filter
This is a motor filter.  It is usually located near the top or bottom of the front of the unit behind a little door.
Nov 28, 2008 | Hoover Vacuums
I have a 7.2V Dust Buster Black and Decker cordless vaccuum and we have lost the little filter inside it. Where can I buy it?
I have a 7.2V Dust Buster Black and Decker cordless vacuum and we have lost the little filter inside it.
Where can I buy it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Please include the brand name and model #
A lot of your local vacuum cleaner dealers carry the Black and Decker filters depending on the model #’s and I will post a few phone #’s listed below so you can order a filter. But 1st always check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://blackanddecker.com/
Contact Us -- Customer Service and Produce Support
1-800-544-6986 (M-F from 8am until 5pm, Eastern Time)
Black & Decker
101 Schilling Road
Hunt Valley, MD 21031 USA
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
GE 106585 Upright Vacuum Logo
Top GE Vacuums Experts
Gerry Harvey
Gerry Harvey
ray gallant
Are you a GE Vacuum Expert? Answer questions, earn points and help others
