Question about Kids Deluxe Fire Truck Pedal Car Red
Just bought KL- 811 Fire truck pedal car. The steering wheel shaft is rectangular but the washer and the head nut in the installation kit are both round. Where do I get the right parts?
I assembled the truck except the steering wheel. The column is rectangular but 12.5x23x2.5 washer and M12 Dome Head Nut are round and do not fit. Where would I get the right fit
  • Lynn Pettlon
    Lynn Pettlon Mar 03, 2014
    Mine didn't fit either, but the steering wheel had a rectangular hole that was a little too narrow to go onto the column, so we filed it wider. That worked. Other than that, I'm trying to contact Customer Service at 1-800-538-4138 to get a missing bell. Was there enough room for your child to climb into the truck between the seat/ladder assembly and the dash? Mine looks awfully tight.
  • Lynn Pettlon
    Update: I just phoned the corporate office at 1-714-256-9888 and they solved everything and are sending my missing part. Try that.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 87 Answers
The washer and nut would not need to be square provided the cylinder of the steering wheel was square
Posted on Nov 19, 2013
How do I remove drive axle on a 1992 geo prizm
cv axle service is covered in the FSM and at alldata.com
need books or ?
you can read the Geo book or the corolla book, same car.
the books and online have lots of photos,sorry, im not doing all that....
  1. Remove the wheel cover.
  2. Remove the cotter pin, hub nut cap, hub nut and washer.
  3. Loosen the wheel nuts.
  4. Elevate and safely support the car.
  5. Remove the front wheel.
  6. Remove the lower control arm to ball joint attaching nuts and bolts.
  7. Use a ball joint separator such as GM J-24319-01 or equivalent to remove the tie rod ball joint from the knuckle.
  8. Remove the bolts holding the brake caliper bracket to the steering knuckle. Use stiff wire to suspend the caliper out of the way; do not let the caliper hang by its hose. Remove the brake disc.
  9. Using a puller such as GM J-25287 or equivalent, push the axle from the hub.
The Prizm axle can be separated from the hub using a brass or plastic hammer. Nova requires the use of the puller.
  1. Use a slide hammer and appropriate end fitting (GM J-2619-01 and J 35762 or equivalents) to pull the driveshaft from the transaxle. Remove the shaft from the car.
To install:
  1. Install shaft into transaxle. If necessary, use a long brass drift and a hammer to drive the housing ribs onto the inner joint.
  2. Install the shaft into the wheel hub.
  3. Install the lower control arm to the lower ball joint. Tighten the nuts and bolts to 59 ft. lbs.
  4. Install the tie rod end to the steering knuckle and tighten the nut to 36 ft. lbs.
  5. Install the brake disc; install the brake caliper and tighten the bolts to 65 ft. lbs.
  6. Install the wheel.
  7. Install the hub nut and washer.
  8. Lower the vehicle to the ground.
  9. Tighten the wheel lugs to 76 ft. lbs. Tighten the hub nut to 137 ft. lbs.
  10. Install the nut, cap, cotter pin and washer. Install the wheel cover.
the next page covers service of the CV axles.
log in and read.
Oct 12, 2014 | 1992 Geo Prizm
Removal steering
LOOSEN the the bolts that clamp the fork legs to the tree. Remove the fork legs along with the front wheel by pulling down on them. Be careful that the brake hoses and the speedometer aren't damaged. Remove the center nut. Bend the lock washer tang so that the bearing retainer nut can be removed and remove the nut and washer from the center shaft. the tree should slide out from the bottom. Don't remove the bearings from the center shaft unless you are going to replace them. When re-installing the center shaft, tighten the bearing retainer nut just enough so the shaft doesn't shake but not so tight that there is a bind when turning the tree. this can be re-adjusted after all assembly is complete.
Good Luck
Apr 18, 2014 | 1997 Honda VT 750 C2 Shadow
Replace Front Wheel Hub Bearing 2002 Jeep Grand Cherokee 2 wheel drive
Removal
  1. Raise and support the vehicle.
  2. Remove the wheel and tire assembly.
  3. Remove the brake caliper, caliper anchor, rotor and ABS wheel speed sensor.
  4. Remove the cotter pin, nut retainer and axle hub nut.
  5. Remove the hub/bearing mounting bolts from the back of the steering knuckle. Remove hub/bearing from the steering knuckle and off the axle shaft.
Installation
  1. Install the hub/bearing to the knuckle.
  2. Install the hub/bearing-to-knuckle bolts and tighten to specification.
  3. Install the hub washer and nut. Tighten the hub nut to specification. Install the nut retainer and a new cotter pin.
  4. Install the brake rotor, caliper anchor, caliper and ABS wheel speed sensor.
  5. Install the wheel and tire assembly.
  6. Remove the support and lower the vehicle.
Apr 22, 2012 | 2002 Jeep Grand Cherokee
Key is stuck in the ignition,how do i remove the ignition and put in new one,or is there a way to get the key out.
Hi, removing the barrel requires removal of the steering wheel, lockplate, and turn signal switch. Once all of these are out, you will see the screw that holds the lock in. You will need a puller to remove the steering wheel and a lockplate compression tool to push the lockplate down while removing the lockplate clip. You may be able to borrow these tools from Autozone or another tool rental outlet. I have pasted the procedure below from autozone.com. Please let me know if you have more questions, and thanks for using FixYa.
  1. 1969 CHEVELLE DELUXE WHEEL AND STANDARD WHEEL ON ALL MODELS 1970 AND LATER
    See Figures 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12 and 13
    1. Disconnect the negative battery cable.
    2. Remove the trim retaining screws from behind the wheel.
    3. Lift the trim off, then disconnect the horn wire(s).
    4. For most 1975 and later models, remove the snapring.
    Fig. Fig. 2: Steering wheel installation-1969 deluxe and 1970-72 standard wheel
    1. Remove the steering wheel retaining nut.
    1. Matchmark the wheel-to-shaft relationship, then remove the wheel with a steering wheel puller such as tool No. J-2927.
    To install:
    1. Install the wheel on the shaft, aligning the marks made during removal.
    2. Install the steering wheel retaining nut, then tighten the nut to 30 ft. lbs. (41 Nm).
    3. If equipped, install the snapring.
    Fig. Fig. 4: Steering wheel installation-1980 and later vehicles
    Fig. Fig. 5: Most 1975 and later wheels are equipped with a snapring to assure the retaining nut remains in position
    1. Hold the trim just above position, then connect the horn wire(s)..
    2. Install the center trim and secure using the retaining screws.
    3. Connect the negative battery cable.
    Fig. Fig. 6: A ratchet or driver should be used to loosen the trim pad retaining screws
Fig. Fig. 7: Once they are loosened, remove the trim pad screws from the back of the steering wheel
Fig. Fig. 8: Pull the trim pad from the steering wheel in order to access the horn wire(s)
Fig. Fig. 9: Remove the retaining nut snapring
Fig. Fig. 10: Matchmark the relationship between the steering shaft and the wheel in order to assure proper wheel installation
Fig. Fig. 11: Loosen and remove the wheel retaining nut
Fig. Fig. 12: Use a steering wheel puller to loosen the wheel on the steering shaft
Fig. Fig. 13: Once the wheel has been loosened by the puller, the wheel may may be removed from the steering shaft
  1. Remove the trim cover from the column.
  2. Remove the steering column cover from the shaft by removing the three screws or by prying it out with a screwdriver (1976 and later models).
  3. Use a compressing tool, such as No. J-23653, to compress and hold the lockplate. With the plate compressed, pry out and discard the snapring from its shaft groove.
  4. Slide the cancelling cam, spring, and washer off the shaft.
  5. Remove turn signal lever.
  6. Push the four-way flasher knob in and unscrew it.
  7. Remove the three switch mounting screws.
  8. Pull switch connector out of the bracket, pull it off the shaft and allow it to hang by the wires.
  9. Remove the lock barrel retaining screw and remove the lock.
Apr 17, 2011 | 1983 Chevrolet El Camino
How to remove a heator core from a 2001 dodge caravan? do you have to take the dash out? or just the bottom pannel.
The 2001 Dodge caravan has 2 heater cores - front (the main one), and the rear. Removal of the
rear heater core is a whole different procedure than the front.
Front Heater Core - Removal and Installation
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Align the wheels in the straight-ahead position.
  3. Disconnect the negative battery cable.
    CAUTION Before working around the steering wheel or the instrument panel all 2 minutes to pass to allow the air bag module to discharge.
  4. Drain the cooling system into a clean container for reuse.
  5. Remove the steering column, by removing or disconnect the following:
    Lower left side steering column cover Parking brake release cable from the parking brake lever 10 steering column cover liner-to-instrument panel bolts and the cover liner
  6. Rotate the key to the LOCK position; then, rotate the steering wheel to the LOCKED position.
    Gear selector cable and its mounting bracket as an assembly from the upper steering column mounting bracket 2 instrument cluster trim bezel-to-instrument panel screws, retaining clips and bezel 2 steering column shroud-to-steering column screws and the shroud Steering column-to-intermediate steering shaft coupler
  7. Loosen but do not remove the 2 lower steering column mounting bracket nuts/washers.
    2 upper steering column mounting bracket nuts/washers Steering column assembly from the vehicle
  8. Remove or disconnect the following:
    Instrument panel-to-chassis harness interconnect and bracket Lower silencer boot, at the base of the steering shaft
  9. Working in the engine compartment, pinch off the heater hoses.
    Heater core cover. Position some towels under the heater core hoses. Heater core plate and the hoses
  10. Depress the heater core retaining clips.
  11. Lift the accelerator pedal and slide the heater core past it.
  12. Depress the brake pedal and remove the heater core from the heater/air conditioning housing assembly.
    Fig. View of the steering column assembly
    Fig. View of the interconnect and bracket
    Fig. View of the front heater core assembly
To install:
  1. Depress the brake pedal and install the heater core into the heater/air conditioning housing assembly.
  2. Lift the accelerator pedal and slide the heater core past it.
  3. Install or connect the following:
    Heater hoses (using new O-rings) and the heater core plate Heater core cover Heater hoses clamps, working in the engine compartment Lower silencer boot at the base of the steering shaft Instrument panel-to-chassis harness interconnect and bracket
  4. Install the steering column assembly by installing or connect the following:
    Steering column assembly, carefully into the vehicle. 2 upper and 2 lower steering column mounting bracket nuts/washers. Torque the nuts to 105 inch lbs. (12 Nm). Steering column-to-intermediate steering shaft coupler and tighten the pinch bolt to 21 ft. lbs. (28 Nm) 2 steering column shroud and the shroud-to-steering column screws Bezel, the retaining clips and the 2 instrument cluster trim bezel-to-instrument panel screws Gear selector cable and its mounting bracket as an assembly to the upper steering column mounting bracket 10 steering column cover liner and the cover liner-to-instrument panel bolts Parking brake release cable to the parking brake lever Lower left side steering column cover. Lower left side steering column cover
  5. Refill the cooling system.
  6. Connect the negative battery cable.
  7. Run the engine to normal operating temperatures; then, check the climate control operation and check for leaks.
Jan 02, 2011 | 2001 Dodge Caravan
Remove and replace Front Sway bar
Hello ggagne.
Here is the procedure.
  1. Raise and suitably support the vehicle.
  2. Remove the left tire and wheel assembly.
  3. Remove the pinch bolt from the lower intermediate steering shaft
  4. Loosen all insulator clamp attaching bolts.
  5. Place a jack stand under the center of the rear frame cross member.
  6. Remove the rear frame-to-body bolts.
  7. Lower the rear of the frame just enough to gain access to the stabilizer shaft.
  8. Remove the insulator clamp bolts and the clamps from the frame.
  9. Remove the insulators from the stabilizer bar.
  10. Remove the stabilizer bar links from the control arms.
  11. Pull the stabilizer shaft rearward.
Installation
  1. Insert the stabilizer shaft to the left side of the vehicle. Important: DO NOT tighten the stabilizer link nut at this time. The weight of the vehicle must be supported by the control arms such that you can obtain the vehicle design trim heights before tightening the link nut.
  2. Loosely install the stabilizer shaft link at the control arm.
  3. Install the insulators on to the stabilizer bar.
  4. Connect the insulator clamps to the frame.
    • Tighten the stabilizer shaft bracket bolts to 48 Nm (35 ft. lbs.) .
  5. Raise the frame into position while you guide the steering shaft onto the gear.
  6. Install the new frame-to-body attaching bolts.
  7. Remove the jack stand.
  8. Install the pinch bolt and tighten.
  9. Install the left tire and wheel assembly.
  10. Lower the vehicle.
  11. Support the weight of the vehicle by the control arms.
  12. Tighten the stabilizer link nut.
    • Tighten the stabilizer shaft link nut to 23 Nm (17 ft. lbs.)
There you are, I hope your job goes well.
Thank you for using FixYa.
KL
Nov 13, 2010 | 2002 Buick Century
How to adjust clutch pedal on 86 mustang lx
clutch is supposed to be self adjusting. Here are instructions for replacing the adjuster:
REMOVAL & INSTALLATION
See Figure 1
  1. Disconnect the battery cable from the negative terminal of the battery.
  2. Remove the steering wheel using a steering wheel puller, Tool T67L-3600-A or equivalent.
  3. Remove the lower dash panel section to the left of the steering column.
  4. Remove the shrouds from the steering column.
  5. Disconnect the brake lamp switch and the master cylinder pushrod from the brake pedal.
  6. Rotate the clutch quadrant forward and unhook the clutch cable from the quadrant. Allow the quadrant to slowly swing rearward.
  7. Remove the bolt holding the brake pedal support bracket lateral brace to the left side of the vehicle.
  8. Disconnect all electrical connectors from the steering column.
  9. Remove the 4 nuts that hold the steering column to the brake pedal support bracket and lower the steering column to the floor.
  10. Remove the 4 booster nuts that hold the brake pedal support bracket to the dash panel.
  11. Remove the bolt that holds the brake pedal support bracket to the underside of the instrument panel, and remove the brake pedal support bracket assembly from the vehicle.
  12. Remove the clutch pedal shaft nut and the clutch pedal, as outlined above.
  13. Slide the self-adjusting mechanism out of the brake pedal support bracket.
  14. Examine the self-adjusting mechanism shaft bushings on either side of the brake pedal support bracket, and replace if worn.
To install:
  1. Lubricate the self-adjusting mechanism shaft with motor oil and install the mechanism into the brake pedal support bracket.
  2. Position the quadrant towards the top of the vehicle. Align the flats on the shaft with the flats in the clutch pedal assembly, and install the retaining nuts. Tighten to 32-50 ft. lbs. (43-67 Nm).
  3. Position the brake pedal support bracket assembly beneath the instrument panel, aligning the four holes with the studs in the dash panel. Install the four nuts loosely.
  4. Install the bolt through the support bracket and into the instrument panel. Tighten to 13-25 ft. lbs. (18-34 Nm).
  5. Tighten the four booster nuts that hold the brake pedal support bracket to the dash panel to 13-25 ft. lbs. (18-34 Nm).
  6. Connect the brake lamp switch and the master cylinder pushrod to the brake pedal.
  7. Attach the clutch cable to the quadrant.
  8. Position the steering column onto the four studs in the support bracket and start the four nuts.
  9. Connect the steering column electrical connectors.
  10. Install the steering column shrouds.
  11. Install the brake pedal support lateral brace.
  12. Tighten the steering column attaching nuts to 20-37 ft. lbs. (27-50 Nm).
  13. Install the lower dash panel section.
  14. Install the steering wheel.
  15. Connect the battery cable to the negative terminal on the battery.
  16. Check the steering column for proper operation.
  17. Depress the clutch pedal several times to adjust the cable.
Sep 24, 2010 | Ford Mustang Cars & Trucks
How do i take the steering box off my 1996 oldsmobile lss 3.8
Power Steering Gear
  1. Raise and safely support the vehicle, allowing the front suspension to hang
    freely.
  2. Remove both front tire and wheel assemblies.
    CAUTION
    Failure to disconnect the intermediate shaft
    from the rack and pinion stub shaft can result in damage to the steering gear
    and/or intermediate shaft. This damage may cause a loss of steering control and
    possibly, personal injury.
    NOTE: The wheels of the vehicle must be straight ahead and the
    steering column in the LOCK position before disconnecting the steering column or
    intermediate shaft from the steering gear. Failure to do so will cause the SIR
    coil assembly to become uncentered, which will damage the coil.
  3. If equipped, move the intermediate shaft cover upward, then unfasten the
    intermediate shaft-to-stub shaft pinch bolt.
  4. Using a suitable puller, separate both tie rod ends from the steering
    knuckles.
  5. Position a suitable drain pan under the power steering fluid lines. Remove
    the power steering fluid line retainer, then disconnect the outlet and inlet
    hoses from the steering gear. Allow the fluid to drain, then plug the lines to
    avoid contaminating the system.
    Fig. 1: Power steering fluid line routing - non-supercharged
    engine shown
    Fig. 2: Power steering gear inlet hose orientation -
    non-supercharged engines
    Fig. 3: Power steering hose routing and orientation -
    supercharged engine shown
  6. Remove the steering gear assembly-to-chassis mounting bolts.
  7. Support the body with suitable jackstands to allow for the lowering of the
    frame.
  8. Loosen the front frame mounting bolts.
  9. Remove the rear frame bolts, then lower the rear of the frame about 3 inches
    (76mm).
    WARNING
    Do not lower the frame too far, or you could
    damage the engine components nearest the cowl.
  10. Remove the steering gear assembly by maneuvering it through the left wheel
    well opening.
    Fig. 4: Power steering gear mounting, with retainer tightening
    sequence and specifications
    To install:
  11. Install the rack and pinion assembly into the vehicle, maneuvering it
    through the left wheel well opening.
  12. Raise the rear of the frame, then install the frame bolts and tighten to 76
    ft. lbs. (103 Nm).
  13. Install the rack and pinion assembly-to-chassis bolts. Tighten the rack
    mounting bolts to 50 ft. lbs. (68 Nm).
  14. Remove the jackstands.
  15. Apply Loctite® thread locking kit 1052624, or equivalent thread locking
    compound to the steering gear mounting bolts.
  16. Install the steering gear mounting bolts, and washers, then tighten the
    retainers to 50 ft. lbs. (68 Nm) in the sequence shown in the accompanying
    figure.
  17. Unplug and attach the power steering gear outlet and inlet hoses, then
    tighten the fittings to 20 ft. lbs. (27 Nm).
  18. Install the power steering fluid line retainer.
  19. Connect the tie rod ends to the steering knuckles. Tighten the nuts to 35
    ft. lbs. (47 Nm). Install a new cotter pin. Tighten the nut up to an additional
    1?6 turn,
    or to 52 ft. lbs. (70 Nm) to align the cotter pin slot. Do not loosen the nut to
    install the cotter pin.
  20. Install the intermediate shaft-to-stub shaft pinch bolt and tighten to 35
    ft. lbs. (47 Nm). If equipped, move the intermediate shaft cover upward into
    position.
  21. Install both front tire and wheel assemblies, then carefully lower the
    vehicle.
  22. Refill the power steering pump reservoir, then bleed the power steering
    system and check for leaks.
  23. Take the vehicle to a reputable repair shop and have the front end alignment
    checked and adjusted as necessary.
Sep 23, 2010 | 1996 Oldsmobile LSS
How to change the power steering on 96 ford explorer
Section 11-02C: Steering Gear, Power Rack and Pinion, Explorer 1996 Explorer with Power Rack and Pinion Steering Workshop Manual REMOVAL AND INSTALLATION Steering Gear SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Pitman Arm Puller T64P-3590-F
Removal
  1. Start engine.
  1. Rotate steering wheel from lock-to-lock (entire gear travel). Record n umber of rotations.
  1. Divide the number of rotations by two. This gives the required number of turns to place system in the on-center position.
  1. NOTE: Verify the front wheels and steering wheel are in the straight-ahead position.
    From the lock position, rotate steering wheel the number of turns determined in Step 3. This places the gear in the on-center position.
    Steering Gear, Explorer
  1. NOTE: Do not rotate steering column when intermediate shaft is disconnected or DAMAGE TO CLOCKSPRING will result.
    Remove bolt retaining the lower steering column shaft to the steering gear input shaft.
  1. Disconnect the lower steering column shaft from the steering gear.
  1. Remove stabilizer bar attachment from frame for clearance to remove gear.
  1. Unscrew the quick connect fittings for the power steering pressure hose (3A719) and power steering return hoses (3A713) at the steering gear housing (3548).
    Power Steering Hose Connections
    Item Part Number Description 1 3A674 Power Steering Pump 2 3A719 Power Steering Pressure Hose 3 3F780 Power Steering Cooler and Hose Assembly 4 3504 Steering Gear 5 5005 Frame
  1. Plug ends of fluid lines removed and ports in gear to prevent damage and entry of dirt.
  1. Remove two (2) nuts from P/S cooler.
  1. Remove P/S cooler from vehicle.
  1. Remove and discard the cotter pin retaining the nut to tie rod end (3A130) and remove nut.
  1. Separate tie rod ends from front wheel spindle (3105) using Pitman Arm Puller T64P-3590-F.
  1. Remove the two nuts, bolts, and washer assemblies retaining steering gear (3504) to front crossmember (5019).
  1. Remove steering gear from vehicle. If required, remove steering gear mounting bracket housing insulators (3F640) and steering gear insulators (3C716) from steering gear housing.
    Item Part Number Description 1 N807881-S60 Bolt 2 385935-S36 Washer 3 3F640 Steering Gear Mounting Housing Insulator 4 3504 Steering Gear 5 N800255-S60 Nut 6 5019 Front Crossmember 7 3C716 Steering Gear Insulator
Installation
  1. If removed, install steering gear mounting insulators into the steering gear housing.
  1. Push the steering gear mounting insulator and steering gear insulator in until there is no space between the lip on the insulator and steering gear housing.
  1. Position steering gear on front crossmember. Install nuts, bolts and washers retaining steering gear to front crossmember. Tighten to 128-172 Nm (94-127 lb-ft).
  1. Position power steering cooler onto bolts and install nuts. Tighten nuts to 68-92 Nm (50-68 lb-ft).
  1. NOTE: The fittings design allows the power steering pressure hose and power steering return hose to swivel when properly tightened. Do not attempt to eliminate looseness by overtightening, since this can cause damage to fittings.
    Connect power steering pressure hose and power steering return hose to appropriate ports on steering gear housing. Tighten fittings to 27-34 Nm (20-25 lb-ft).
  1. NOTE: Make sure the tie rod ends (3A131) are seated in the tapered spindle holes to prevent rotation while tightening nut.
    With the steering gear, steering wheel (3600) and wheel (1007) in the on-center position, attach the tie rod end to front wheel spindle and tighten to 56-76 Nm (77-103 lb-ft).
  1. If necessary, advance tie rod nuts to the next slot. Install cotter pins.
  1. NOTE: Verify that no rotation from the on-center position has occurred.
    Position steering column lower intermediate shaft over steering gear input shaft. Outer input shaft dust shield must be in place. Replace pinch bolt and tighten to 41-56 Nm (30-42 lb-ft).
  1. Replace the front wheel and tire assemblies. Refer to Section 04-04 .
  1. Replace wheel covers.
  1. Lower vehicle.
  1. Refill power steering oil reservoir (3A697) with Premium Power Steering Fluid E6AZ-19582-AA or equivalent meeting Ford specification ESW-M2C33-F.
  1. Purge air from steering system. Refer to Section 11-00 . Verify absence of any unusual power steering noise.
  1. Check and adjust toe alignment specifications. Refer to Section 04-00 .
  1. Make sure steering gear operates correctly and is not leaking.
  1. Check and adjust fluid level in power steering oil reservoir.
Jul 10, 2009 | 1998 Mercury Villager
Heater core
18901fc.gifHere is an exploded view of the heating/air conditioning blower box. This contraption is located on the passengerside under the dash. I've changed heater cores on other cars but never worked on a caravan so not sure how difficult it'll be. You may need to remove a few cover panels to access this and the heater core #22 is located behind the distribution box #6 containing parts 7-18 and hopefully comes off as a unit. I wouldn't want to put it back together just looking at the pic. You may just need to remove the heater tube cover #4 to access the connections and slide out the core.....NAH couldn't be that simple!!! Hope this was of some help. Good luck.
Oct 18, 2008 | 2000 Dodge Caravan
Kids Deluxe Fire Truck Pedal Car Red Logo
76 people viewed this question
Top Dexton Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Dexton Vehicle Part and Accessory Expert? Answer questions, earn points and help others
