Orei dvd player BDP-M2 MODEL-picture scrolls up constantly on certain dvds how can i correct. Also when i put in a 3d dvd to play it doesnt play how can i correct this
Tololng saya...saya lupa kata sandi saya.saya inginkan secepat mungkin.....
Posted on Nov 18, 2013
snakehead
  • 1074 Answers
SOURCE: DVD player won't play certain movies
it could be the disc that is causing the problem try some other disc and see what it does.good luck.
Posted on Mar 23, 2007
SOURCE: recorded a DVD on computer but will not play on DVD player
dvd players play only certain kinds of discs and formats. Older ones played -R's, most newer ones play everything. You have to look in manual, or on box before you buy player. If it won't play -R,+R, -RW,and +RW's I pass it by. Find out if your player is limited to certain discs. Some will play VCD and some will not. Some will play DIVX and some will not etc. Stick to the discs and formats your particular player is compatible with.
Posted on May 30, 2008
SOURCE: recorded dvds wont play in other dvd players
You have to finalize the disc. if the disc goes to the end it will finalize the disc automatically. If there is some part of the disc not used you have to do it yourself. IN DVD MODE PRESS SETUP, THEN DISC EDIT, THEN FINALIZE. FINALLY PRESS YES. That should do it.
Posted on Sep 03, 2008
  • 254 Answers
SOURCE: DVD stuck in sony blueray player bdp s300
Step1There are a few ways to get your dvd/cd drive release itself. The first thing you should try is shut your equipment completely off for a couple of minutes allowing it to cool down. Once you turn it back on try to press the release button on your equipment. Step2If that does not work try to use a very thin flat tip screwdriver. Insert in on one of the sides of the dvd/cd drive and try to pull it out softly while pressing the eject button simultaneously. Do not force it out but give enough pressure while pressing the eject button. Step3More than likely inserting a screwdrive should release the dvd/cd drive. You can also try a butterknife as well just don't use to much force. Something else to check for is to make sure the power is acutally on for the device. If you are trying to open a drive that is not even on it will never open up for you.
Posted on Apr 03, 2009
  • 814 Answers
SOURCE: dvd player will not reconize a dvd when trying to play
Try cleaning the dvd compartment of all dust and debris with a can of compressed air. Check and make sure all the dust and debris is cleared of the laser transport and lens. Use cotton swabs and small amount of isopropyl alcohol to clean off the laser lens and tracks and gears of the transport . Use a cotton swab with a small amount of alcohol on the tip to clean the laser lens. Rub the swab gently across the lens, until it appear bright and shines. Use the other side of the swab to remove any excess moisture from the lens. Use cotton swabs to clean the rails and gear of transport. Applie small amounts of alcohol to the tips to loosen caked on dust or dirt. Use compressed air again to clear the dust and debris from transport area. After the through cleaning. Try the player again, using a dvd to see if the operation returns to normal. If not, try resetting the dvd player to factory setting. You can do this using the on screen menu to go into the settings. Use the remote control and press the settings button. Use the up and down arrows to highlight the preferences section and press enter. Once in the sub-menu use the up and down arrows to highlight the default function and press enter. This will have reset the dvd player to the factory settings. Now try using a dvd to test the player to see if it operates normally. If it does not play normally, you may have a proplem with the spindel, check it to make sure its is making good contact with motor, if it appears loose, applie a drop of super glue to snug up the grip. After it dries completely. Test the player again with a dvd. If the unit still fails to operate normally, you may be having problems with either the drive motor or the power supply circuits. For these problems you need to contact a service center. They will have all the service information to troubleshoot these problems properly. You can call Phillips customer support at this telephone number 1-888-744-5477. They will be able to tell you how to get the dvd player tested and serviced. I hope this information helps you with your problem.
Posted on Jun 01, 2009
Why won't it stream or play disk?
Call Kurtis: Why Your Samsung Blu-ray Player May Not Play ...
sacramento.cbslocal.com/.../call-kurtis-why-your-samsung-blu-ray...
KOVRSep 26, 2013 - Blu-ray players aren't the same as DVD players. ... disc compatibility issues arise and firmware updates for our Blu-ray players are ... My BD-C6500 is apparently one of those old blu rays that won't play blu rays. ... If you are viewing netflix streaming thru your samsung bluray then YES it definitely can. Its not ...
play mp4 files on a blu-ray player - MP4 - Streaming Video ...
www.tomsguide.com/answers/id.../play-mp4-files-blu-ray-player.html
Jan 9, 2014 - I see a lot of Bluray players will play mp4 files. ... If it won't do it via the USB port, will it do it if the mp4 files are on a DVD? ... player has a menu, items likeDisc Tray, Netflix (I use this menu choice to watch streaming Netflix), ...
Sony BDP-S590 3D Blu-ray Disc Player with Wi-Fi (Black)
www.amazon.com/...Blu-ray-Player.../B006U1YUZE
Amazon.com, Inc.Sony BDPS790 4K Upscaling 3D Wi-Fi Blu-ray Disc Player. 4.0 out of 5 stars 334 · Panasonic DMP-BDT220 Integrated Wi-Fi 3D Blu-ray DVD Player .... With the Sony BDP-S590, you can wirelessly stream music throughout the home to .... at internet.sony.tv as in the past some Sony products won't connect to certain services ...
Amazon.com: Sony BDP-S5100 3D Blu-ray Disc Player with ...
Jan 07, 2016 | Televison & Video
Why is it a sony BDP-S1200 not play DVD discs but can play blue ray discs?
Check that you are playing the correct region coded discs for your player. Blu-Ray discs tend to be universal but not DVDs. If you are playing Region2 disc when the player is set for region 1 (American) then they won't play and again Vice Versa.
Feb 19, 2015 | Sony Televison & Video
Pioneer bdp 440 won't play region A blu ray
It may be the encoder that is going faulty in the unit i had the same problem with my dvd player after using different regional discs in them.
Feb 21, 2013 | Pioneer BDP-440 Blu-ray 3D Code Free DVD...
I CANNOT PLAY REGION A DVDS ON MY 3D BLU/RAY PLAYER BDP- 7500 PHILIPS DVD BLU/RAY PLAYER COULD I PLEASE HAVE A SOFTWARE UPDATE OR SOME KIND OF CODE TO UNBLOCK THE PROBLEM OR DO I REQUIRE A MULTI REGION...
No disc in tray
Press Home
Scroll to settings
input code: 13893108520
The settings will pop up and you will see that the DVD region is now set to 0 (meaning region free).
I have checked the hack on a BDP8000 (region 2)and it sets the region to 0 (the 7th. digit from the left) alright, but it does not make the player region free as a message from the disc (MGM) comes and tell that the disc is not supposed to be played in this region. The region on the player can be changed to the region by changing the "x" in 138931x8520 to the actual region you want to play.
Try this out. The hack codec for blue ray are not yet published so it is not possible to make Blue Rays totally region free as of now.
Sep 27, 2011 | Philips Computers & Internet
I can not get my dvd to play disc's and they dont run when i open file, i keep getting info saying corrupt
are u trying to put 3 movies on 1 disc? and you might find that the certain dvd player you have doesnt play copies if thats the problem youd find that the cheaper dvd players under £25 have noprobs playing copy dvds
Jan 23, 2011 | Pioneer DVR-107D DVD±RW Burner
Have upgraded firmware to latest today....still
Try to find how to become you DVD multi region. It uses region recognition function and it is problem for you.
Jul 28, 2009 | Sony BDP-S301 Player
Acer aspire 2930 DVD player only opens some dvds
Try Media player classic under k-lite codec pack. Then open video files on the dvd. If it doesn't help try another codec player. If nothing helps could it be that dvd player is not capable of multilayer dvd reading.
Apr 10, 2009 | Acer Aspire 2930-4661 Notebook
No vertical hold
Do you have it hooked up to a VCR? If so, it's the Macrovision kicking in.
Oct 24, 2006 | Protron PD-800 DVD Player
Open Questions:
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
