Motorola Mobility H202 Cordless Phone Logo
Christi Doyle Posted on Nov 18, 2013
Out of range motorola h202 model phone
Base phone is in range but the second one says out of range
computur virus removal and other tech support
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Apr 14, 2014
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
3274
Points
7
Contact Motorola 1.800.653.5350
Handset has message Out of Range even though it is fully charged on on the handset.
The handsets are reading out of range because they have lost connection with the base. This happens mostly during peak power demands or power outages, but can also happen when the phone is unplugged for any amount of time. This can also cause, at times, the answering machine to stop picking up calls. To remedy this issue, reset the phone system. Please follow the instructions below:
To reset the phone:
1. Disconnect the power adapter, phone line, and remove all batteries from the base and all handsets. Leave it disconnected for 30 seconds to reset the base.
2. Place the batteries in the handsets first and then plug in the power adapter and phone line. Do not place the batteries back in the base yet.
3. Put the handset in the charge cradle.
4. It may take up to 1 minute for the "Out of Range" to clear from the display.
5. Once the "Out of Range" is cleared from the handset place the back up batteries back into the base.
1helpful
Help with MD781 phone problem
on the phone that says, 'out of range' you need to select MENU then scroll down to the option that says REGISTER and select that. Then go to your BASE UNIT and push and hold the PAGE button until the 'bad' phone synch's up again. .... I called into motorola support and they stepped me through this.
I’m happy to assist further over the phone at https://www.6ya.com/expert/chris_6ddd78f70d3cfe52
Motorola MD761 5.8 GHz phone
Change the channel on the base or the phones. That should fix the problem.
Extended Handset
The phones have to have the same carrier frequency as the base set. The "out of range" display is because the frequencies are not matching. Check with the manufacturer (via website) and ask if your second handset can be programmed to a different base.
2helpful
4answers
Out of range
I have a Radio Shack 2.4ghz cordless phone system and sometimes the handsets will show "Out of range".
My Solution that works for me.
Unplug the power cord and telephone line to the base for about 30 seconds. This seems to reset the base. Then plug everything back and you should be ok.
ET Sherman
Base does not register with second Handset.
to register the extra handset it has to be exactly the same to be compatible with the base
if it is a slightly different model or older unit it probably will not register
9helpful
2answers
Motorola MD451 phone "Out of Range?"
Go To Menu, and Then Press Register, On The Base Than Place The Page Button On The Base.
Top Motorola Mobility Lands Phones Experts
Ngoro
john h
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
