Question about Asko Washing Machines
Motor hums but not turn - Asko Washing Machines
    Champion:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 242 Answers
Could be the motor brushes, check for black powder on motor. could be a siezed motor, try turn it manually by hand.
Posted on Nov 18, 2013
  • 2 more comments
  • Jon Trader
    Jon Trader Nov 29, 2013
    I have been informed by the parts supplier that it is a brushless motor, AND the motor is working for washing, but not for spinning..
  • Jon Trader
    The motor turns freely and the pump is not blocxked and is working correctly.
  • Jon Trader
    Sorry, previous comment should read - The motor turns freely and the pump is not blocked and is working correctly.
  • Jon Trader
    I personally suspect either an electronic control board fault (I am going to try a replacement), a wiring connection fault to the motor, or an electrical fault in the motor (I am going to try a replacement of those too), ALSO the problem is intermittent.
Dishrag caught un disposal, pulled it out, blades turn, it just hums, it hums even when switch is turned on off!!
If cutter disk turns freely and motor hums, then motor winding has gone bad.
The humming sound means motor is overheating and will stop humming.
I wrote ez garbage disposal replacement steps from days when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on disposal or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Dryer motor hums but does not turn when start button is pushed
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 24, 2011 | Maytag MDG6000 Dryer
Model # 72852 Burning smell Drum does not turn but a humming noise When door is closed it hums without the start button being pushed.
Jan 18, 2011 | Kenmore Dryers
GE electric dryer not working
It sounds like your motor is failing.You went to turn it on and it hummed... The motor got hot and triggered the safety shut off. When it cools you may be able to get it to hum again. But you will need to replace the motor.
Let me know if I can help you further.
Apr 15, 2010 | GE DWSR405EBWW Electric Dryer
Whirlpool LER 6620 heats, but does not tumble.
if the dryer heats the motor should be good. if it hums its either runing or the hum is a stall noise . if belt is in tact then if motor were going so would the drum . so i think the motor isn't going just humming and the heat sw in the motor is stuck closed with lint and you need to replace the motor .. take the belt off and turn motor if it turns free . the blow it out good and reinstall belt and try again ..mm
Dec 03, 2009 | Dryers
Hums when turned on-won't turn over
belt may have broke. if you are hearing a humming sound . thats the motor .whitch is good, sounds like the belt broke or slipped off.
Sep 12, 2009 | Kenmore 73952 Gas Dryer
Liftmaster - motor hums, doesn't turn. Removed
My neighbor guy, who knows a lot about stuff, told me to get a new one.
Good solution.
Jul 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Dryer motor just hums
Sounds like the belt has been stretched and is not letting the motor turn the drum. If the motor is not turning at all then your motor is burnt out and needs ot be replaced
May 22, 2009 | Dryers
The pump lost vaccum, now the motor shut off and pump only hums.
Prime the pump. If it still just hums, try to turn the impeller. If the impeller is not jammed, and the motor hums or it doesn't start at all, the motor may be bad. Check for correct voltage of the incoming power wires inside the motor connection housing. Sometimes turning the circuit breaker off, then back on will fix it.
Jan 15, 2009 | Garden
Washing Machines Logo
23 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
