Question about Whirlpool Refrigerators
Bottom freezer water leak on whirlpool gold model G16SARXXF01
Our whirlpool gold model G16SARXXF01 is dripping on the floor from the bottom left corner of the freezer which is on the bottom. What can we check ??
aborcass
  • 2651 Answers
SOURCE: defroster leaks
you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Feb 25, 2008
SOURCE: WATER LEAK IN FREEZER POOLING AT BOTTOM & FREEZING THEN MELTING
The problem was indeed a clogged frost water drain. I had to pull the frig out from the wall (found an incredible amount of dust accummulation in the alcove), then remove the vertical metal and horizontal cardboard covers to expose the drain catchpan. The 1/2" rubber drain hose end was only about 1/8" above the pan pointing directly into it perpendicularly. This was not enough clearance. There was a plug (formed by dust and water) in the end of the hose that came out easily when I 'roto-rooted' it with a screwdriver. The water flowed easily after that, but I went ahead and trimmed about 3/8" off the end of the hose and pushed it back into its slot. Then I cleaned as much as I could. The prevention is to keep the area behind the frig cleaned!
Bob
Posted on Nov 08, 2008
  • 1462 Answers
SOURCE: Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Posted on Nov 26, 2008
  • 198 Answers
SOURCE: Water Dispensor leak on Whirlpool Refridgerator
The solenoid valve needs replacing, located at the back of the refrigerator. If you have well water you will need to install a filter on the supply line.
Posted on Jan 05, 2009
SOURCE: freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
Posted on Aug 09, 2009
Water leaking and freezing in bottom of freezer and leaking on the floor it is a whirlpool gold series model #GI6SARXXF04
sounds like your defrost drain is clogged up. it can be cleaned by taking off the metal or plastic panel and cleaning out the defrost drain hole. a steamer works best.
Dec 20, 2016 | Whirlpool Refrigerators
Whirlpool refrigerator with top freezer
If there is an ice maker in the freezer, look to see if the water is coming from there. If it is then replace the solenoid valve where the water comes into the back of the refrigerator.
Mar 05, 2014 | Whirlpool Freezers
Water is leaking from the bottom corner of the freezer
Is it an excessive leak ie pools of water on the floor? If it is not a major leak it might be normal condesation being drained.
Aug 28, 2012 | Cars & Trucks
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
We have a whirlpool gold bottom freezer refrig. that has been leaking moderate pools of water on each side of the refrig. It also has ice that forms on the floor of the freezer behind the baskets. We took...
Do you have a thin layer of ice in bottom of freezer? If so, its a clogged drain - drain located "behind" back wall in "freezer" side (bottom).
If not, may be a broken or leaky water line or water valve - best serviced by an appliance repair technician... GL
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - Refrigerator repair Houston, Katy, Spring and Woodlands, TX!
Aug 29, 2011 | Whirlpool GI7FVCXWB (27 cu ft) Bottom...
WATER RUNNING OUT FROM UNDER REFRIGERATOR
If the floor of the freezer is full of ice, your defrost water drain tube is clogged. Remove the ice in the freezer bottom, find the top of the drain tube inside the freezer near the top of the ramped up area, about the size of your index finger and blast hot water through it with a turkey baster. About 4 cups of good hot water but not boiling
Dec 20, 2008 | Whirlpool 19.8 cu. ft. Side-by-Side...
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Refrigerators Logo
85 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
