Question about Kenmore 60172 Electric Commercial Dryer
Coils Stay On When Dryer Is Not Running
Came home today from being gone all weekend and found my laundry closet at about 100+ degrees. Dryer was not running, but found that coils stay on (bright orange) when timer knob is turned to an on cycle (timed or automatic, but no turning drum). I turn the knob to an off position and the coils turn off. Any idea what part to replace to keep the coils off when they are supposed to be off?
  • Anthony
    Anthony Nov 18, 2013
    Not sure why, but I put the model as a Frigidaire Dryer GLER331AS2. Not sure where the Kenmore part came from...
    Top Expert:
  • Kenmore Master
  • 36,296 Answers
This is definitely a safety issue and should be referred to Sears. There may be a corrective repair that can and should be made.
Posted on Nov 18, 2013
4 Suggested Answers
muttandjeff
  • 359 Answers
SOURCE: kenmore 70 series dryer control/timer knob doesn't turn when running
THE TIMER HAS A SMALL DRIVE MOTOR THAT TURNS THE TIMER AT DIFFERENT SPEEDS FOR DIFFERENT CYCLES AND VARIES FROM BRAND TO BRAND BUT EITHER WAY YOU MUST REPLACE THE TIMER , EXPENSIVE FIX IF THE DRYER IS WORTH IT THAT SHOULD TAKE CARE OF THE PROBLEM
Posted on Dec 23, 2008
localwonder
  • 6784 Answers
SOURCE: My Kenmore drier won't stop now! Perhaps timer isn't working?
Hi there. this is a timer issue. it counts down but, the actual shut off dial embedded in the timer mechanism is damaged for some reason. replacing the timer assembly will correct this issue. there are two parts to a timer. One, it times and last, it initiates the shutoff. the second action is not working properly. to be sure, check the relay before you purchase the new timer.
I have also provided you with a complete manual set that you can access and print out if you would like.
Click here for your manual
Click here for your instructions Guide.
Posted on Mar 06, 2009
aasc
  • 1606 Answers
SOURCE: GE Dryer timer doesn't work
Replace the timer . If model number given , could give the part number .
Posted on Aug 09, 2009
Free owners manual kenmore laundry center 417.99190800
This is what I found this may help you.
(http://www.searspartsdirect.com/model-number/41799190800/0582/0152000.html)
Aug 11, 2017 | Kenmore Dryers
WHERE IS THE CIRCUIT BREAKER FOR THE MICROWAVE AND THE WALL OUTLETS
Good morning Richard.
The location of the circuit breaker will depend on the house, or building that you're in. Generally, they will be all together, often in a stairwell or a garage/basement wall that won't be obstructed. If the electrician followed code, the breakers should have labels on the inside of the breaker panel door, telling you which breaker or breakers service the kitchen. Often, if the microwave is an installed type, it'll have it's own 15 or 20 amp breaker.
Good Luck!
Nov 19, 2015 | Microwave Ovens
Gas dryer wont stay lit
I'm assuming it "starts" to heat but then cuts off. Usually after the first minute of running you can open dryer door and feel heat but after awhile it doesn't heat.
1st, most common problem on a gas dryer not heating is "airflow" . They will "short-cycle" if there isn't near perfect airflow. Turn dryer on and go to outside exhaust vent. It should blow about as hard as you can blow into your hand. If any doubt disconnect dryer vent line from wall and let blow into your laundry room for one cycle and see if it is now working correctly. If it does work correctly when vent line is disconnected at wall you KNOW there is blockage somewhere in your vent line.
2nd, most common problem are gas coils. Easy to replace. 99% of all gas coils are the same so here is the part# (WE04X10020) (write it down.
Below is link where you can purchase appliance parts. Thanks for reading!
Appliance Parts
Feb 07, 2015 | Dryers
It takes the dryer too long time to dry the laundry even on 80 degrees.
I took my dryer apart and found the vent shoot and exhaust needed cleaning. Also the exhaust vent pipe going out side should be cleande.
Dec 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Hello my dryer doesnt work properly it runs
The valve resistance is 1995 ohms and the ignitor is 185.
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When the dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG dryer manual
Dec 13, 2010 | LG D2526 Gas Dryer
Dryer will not shut off in any 'auto' mode. Time display ticks down, then jumps up again and keeps running. Dryer does works properly when 'timed dry' is selected. Checked and cleaned exhaust vent. ...
How long is the vent from the dryer to the outside? Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dry-ability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Jul 14, 2010 | Samsung DV337 Electric Dryer
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
Apr 01, 2010 | LG DLG5932W Gas Dryer
Dryer not taking out moisture
your venting from the dryer probably also submerged in the "flood", try taking that apart and make sure its not clogged, sounds as if the dryer is not able to release the heat that its producing
Jul 25, 2008 | Dryers
Kenmore 60172 Electric Commercial Dryer Logo
57 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
