Question about Kenmore Side by Side Refrigerator
Kenmore coldspot 96 light is on but does not cool no sound from compressor model 9555722 1996
  • 1,869 Answers
Replace the klickson under the compressor case electrical cover
Posted on Nov 18, 2013
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
SOURCE: side-by-side kenmore coldspot is warm
I would unplug ref. clean the condenser coil, install a 3n1 start relay on the compressor.
Posted on Nov 05, 2008
  • 8 Answers
SOURCE: Warm refrig and freezer
You probably need some refrigerant added. There probably is a leak in the system that caused the lack of refrigerant. Get the leak fixed and add refrigerant before you blow your compressor too. Or get a new fridge.
  • 172 Answers
SOURCE: kenmore coldspot not making ice, and not cooling in the bottom
Your refrigerator is frosted up. Remove the inside panel of your freezer. Defrost the ice out of the coils and check the heater and bi-metal. If both are good then your defrost timer is bad. If one is bad replace and you have it fixed. Good luck.
Michael Anderson
(865)945-3808
Posted on Dec 02, 2008
  • 62 Answers
SOURCE: Freezer is fine. Fridgerator portion does not cool .
The most likely cause is a bad evaperator fan motor. It is mounted in the freezer section. It blows the air up to the ref section. Open the freezer door and listen to see if you hear any fan noise.
Posted on Dec 06, 2008
Kenmore refrigerator/freezer not cold! I have a Kenmore Coldspot model 57572791 refrigerator/freezer that suddenly stopped cooling/freezing. I took off the back & think it is the compressor @ the...
It is not likely, but since you had the lights on the same circuit it is possible that the breaker for that circuit may be tripped. Have you checked the breaker?
Jan 21, 2013 | Kenmore Refrigerators
Kenmore coldspot lights on will not cool/freeze
the ptc overload relay on the compressors bad unplug it off the compressor and buy an exact replacement
May 29, 2011 | Kenmore Side by Side Refrigerator
Kenmore hum click sound
Bad overload relay or bad compressor. You can change your overload relay to test, usually fairly cheap, (55.00 from Sears) however if it is your compressor, it is out of it's five year warrantee and is not worth repair. 900 to 1100.00 to repair in my area.
Jan 18, 2010 | Refrigerators
Stopped cooling.
It is possible the cold control has gone bad. Or the defrost timer is stuck in defrost, or even the compressor has gone bad.
Dec 28, 2009 | Kenmore Refrigerators
Kenmore Coldspot Model 106 9557651 stopped cooling and freezing. Mfg date is 09/95.
please make sure that the electricity supply to the unit is in order. after that check wether the thermostat is in working order and if the compressor is running. If everything is in order tou have a gas leak and the unit must be charged with gas.
Aug 07, 2009 | Refrigerators
Kenmore coldspot model #106.53594300 will not cool
Check the condenser. Cheap remedy. Have it replaced.
Jul 12, 2009 | Kenmore 50522 / 50524 Side by Side...
Kenmore coldspot 106.54563300 is not cooling. First the freezer stopped cooling then the fridge stopped. The fan is still working. Pulled fridge out, compressor was very hot. Is this a relay problem? If...
Not good news, it sounds like a compressor problem. Vacuum clean everthing you can safely get to in order to make it eaiser for the repair guy, (hopefully to save money). How old is the fridge?
Jun 21, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Coldspot Side by Side Model 51559101
I also have the same refrigerator model 106.56566400 and periodically when the power goes off in the house the refrigerator & freezer will stop cooling. Try pushing the on/off button located inside the refrigerator to the left of the digital temperature controls. Hold the button down, this turns the unit off, then press it again to turn it back on. This basically resets the refrigerator, and most of the time works to get the refrigerator cooling again. Try this first before calling a repair man.
Nov 22, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore Side by Side Refrigerator Logo
60 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
