Question about Garden
Has very weak spark - Garden
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
But it has spark so this isn't your problem
Posted on Dec 30, 2013
Weak fire on pocket bike
Hi, I do a lot with these bikes, I think if you are getting a weak spark there is a couple things to check. First, do you understand how it builds the power to create the spark? The magnet in the flywheel has to be very close to the magnito or coil, if the gap is too much it will cause a weak spark, if the magnet is weak, weak spark, if the coil is shorting internally, weak spark. If the plug wire is damaged, weak spark. I hope this helps you.
Jan 25, 2015 | Quad 47 cc / 49 cc Pocket Mini Bike...
Why a weak spark 1987 dodge 5.9 v8
this can be caused by a weak battery check battery and charging system to verify a good working system. it could also be a weak coil not being able to supply enough output voltage for the ignition system. you don`t say if its weak coming out of the coil or at the plugs. if spark is weak at the plugs it could be a bad cap/rotor, ignition wires. it could also be an ignition module problem or pick-up coil in the distributor.
Aug 25, 2014 | Cars & Trucks
Weak spark
This is just a shot in the dark but have you checked your ground wire from the battery to the engine/frame.A bad ground wire could be rotten on the inside and you would never know it.This would give you a bad path for current completion and therefore a weak spark.Just a thought Good luck
Apr 29, 2014 | 1993 Toyota Tercel
Weak spark
pull flywheel and replace sheer key on flywheel to get spark on time
Feb 23, 2014 | Garden
Weak spark wont start
Sounds like stator pick up or stator its self is rusty causing a weak spark, (Just sand off) , or the coil is bad or spark plug wire is corroded
Dec 24, 2013 | MBK Motorcycles
Weak spark at plug
Check to see haw strong the spark is coming out the dist cap. If it is weak there, possible bad cap/rotor/coil/ module. Make sure the wire from the coil to the cap is good.
Jan 01, 2013 | 1995-1997 Chevy 1500 Truck Ignition...
1981 suzuki gs750l low spark but all spark get one big blue spark then small weak spark
Yep, that is alright as the weak spark is a wasted spark. It should goes on each ignition cable a STRONG then WEAK sparks. It is just fine in your ignition.
If you find this advise helpful then rate it please. thanks
Dec 09, 2010 | 1981 Suzuki GS 750 L
1986 gas club car weak spark replaced coil still same
How do you know that the spark is weak?
Replace spark plug.
Check spark plug wire for leaks.
Replace fuel.
Clean points and reset.
If there is a battery check that it is at 12.5 during starting.
Sep 09, 2009 | 3d Rose Londons Times Funny Cow Cartoons -...
Crf100 has a weak spark
its the coil or magneto one of these two will cuase a weak spark they are simple to replace though
Dec 30, 2008 | Honda CRF 100 F Motorcycles
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
