Question about Eliminator MotoMaster Mobile Power Inverter 700w
Powerpack won't charge - Eliminator MotoMaster Mobile Power Inverter 700w
I have lost the ac adapter for my Xantrex Powerpack 200 Plus. Where can I get one for a reasonable price?
You need a 12 Volt AC/ 1 AMP (1000ma) charger. You can use one with a lower ma rating but it will take longer to charge. The factory unit will take 35 hours to fully recharge a totally discharged battery. If you use your car's cigarette lighter it will take 3 hours if you're charging and driving. Good Luck!
Aug 24, 2011 | Xantrex Technology XPower Powerpack 200...
How long should i charge my jump box
I'm not familiar with this model, but other boxes I've used have all had some kind of power level indicator to show their charge level. I'm sure yours does too. Charge it at least until the indicator shows it's full. You can leave the unit charging for as long as you want, actually. The charging circuitry drops to a low trickle when the unit is fully charged, and won't damage anything by overcharging. (We have one where I work. As soon as we're done jumping something it goes back on charge, and it's over three years old now.)
Aug 11, 2011 | Xantrex Technology XPower Powerpack 200...
Wont charge
My powerpack will not charge at all. I have used the cars charger as well as the typical wall plug in. I have left it plugged in for a week and only get an alarm sound and no power is coming out. Any suggestions would be greatly appreciated.
Feb 28, 2011 | Xantrex Technology Xpower Powerpack 400...
How long does it take for a fully discharged 12 volt battery to be charged by a powerpack 300
depending on the amprage output it could be from 6 to 12 hours to charge a regular car battery.
Jun 14, 2010 | Xantrex Technology Xantrex Xpower...
I bought a new Powerpack 300 and never had a use for it. It was plugged in for a year and when I decided to test it everything worked until I plugged in any AC appliance.. It just doesn't seem to have the...
Your battery is likely damaged from being plugged in for a year. The battery is a sealed lead acid battery inside, probably a 12 or 17AH job. Proper way to store a lead acid battery is to keep in cool dry location, and top off charge each month or two by charging according to manufacturer guidelines.
If you can figure out how to get into the case, you can replace the battery.
Aug 05, 2009 | Xantrex Technology Xantrex Xpower...
Don't know voltage setting for charging this unit.
You can use any adaptor that supply 12V or more. If you have at least 800ma of current, and 12V or higher it will do the job. Higher voltage rating will charged it much quicker but you have to watch it.
Jun 18, 2009 | Xantrex Technology Xantrex Xpower...
Xantrex PowerPack 300 will not hold a charge
Machine no longer takes a charge. Light remains yellow, if you plug anything in there's not enough power. Any suggestions? Purchased XPower Powerpack 300 Plus from QVC appx. 6 - 8 years ago.
Mar 28, 2009 | Xantrex Technology Xantrex Xpower...
Eliminator MotoMaster Mobile Power Inverter 700w Logo
73 people viewed this question
Top Eliminator Electronics - Others Experts
ottworld5982
Pierre Curtis
Level 1 Expert
L Pfaff
L Pfaff
Are you an Eliminator Electronics - Other Expert? Answer questions, earn points and help others
