Nd displaying on screen - Washing Machines
  • 37 Answers
ND--No Drain
check water pump is not blocked
find the water pump and clean it out.
water pump could be faulting
might need replaceing
Posted on Nov 18, 2013
What does nd mean on display screen
ND means not draining. I suggest checking drain hose for blockage and call customer support.
Jan 04, 2016 | Samsung Onyx Smart Control Front Load...
Androlock creat problame. can't ue my phn.
Could we have the question in English with grammar and complete words please.
Jul 07, 2017 | Cell Phones
Code nd comes up on the display pad.
The ND code means NO DRAIN. Usually when it doesn't drian, either something is stuck in the drain pump filter screen or teh pump its self.
Aug 11, 2011 | Amana Washing Machines
No display on lcd screen
check for lcd invertor if its ok its problem of vga chip
2 ways to solve
1) go to nearby service center which they just replace the motherboard
2) more risky bt work dissamble the whole laptop nd all accries from the motherboard including the cpu ram wifi card nd also black sheet from the main board then place the board in microvave where the vga chip is on the top nd microvave for 6 min at temp of 350 -390 f
now try the run the board
Jun 29, 2010 | IBM ThinkPad T42 Notebook
Nd in the display
nd stands for no drain check for a restriction in your drain line and in your pump assembly
May 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune Washer showed "nd" on the display screen, and now the door will not unlock. What can I do?
ND is NO drain
The water level fails to drop below the Low Water level reset within 15 minutes, before a spin begins.
Sep 22, 2009 | Maytag Neptune MAH6700A Front Load Washer
My computer screen is coming up with lines in it,blue, can you tell me what is wrong or how to fix?
check your graphix card ............. remove it if it is not onboard .............wipe the mouth with a white A4 sheet.......... fix it back nd check if all the pins on the display cable are present nd in good shape...**straight nd not cruked**
call Dj Choker +2330207426333 for more info..........))))))))))***************(((((((((((((((....................
May 04, 2009 | Sonic RecordNow! Deluxe 7.3
White screen on display of phone
hi if u open the covers of the fone u shud av a flex cable going from the screen to the pad . if u just make sure they are not bluged out nd jus push them back in a little bit them u shud be oki i used to have that problem on my d500 nd thats the only way i used to solve it
many thanks
ako
Apr 26, 2009 | Samsung SGH-E900 Cellular Phone
Problem conecting hp laptop to sony bravia 52" hdmi tv
u need 2 change ur pixels 2 1024 by 768 in display settings then click the screen with 2 on and extended ur display to it ,then open windows mobility center and click connect display this will open a screen with 3 options chose the bottom 1 use external display only or sum think like that this should work once u have ur display showing on ur tv then click connect display again and chose the top option and u should get ur display on both screen let me know if this solves ur prob it worked 4 me regards davy ps if u plug in and loose control of ur lap top i think uv already selected use external display only try changing ur pixel 2 1024 by 768 and try again if not u need 2 plug into different tv nd change this if u have any more probs with this let me know this prob had my head dun in 4 days tryed the tech guys nd they said my tv port was broke liers(there a wast ov time)
Jan 19, 2009 | LG 42LC2D 42 in. LCD HDTV
Washing Machines Logo
Top Washing Machines Experts
