Question about Simer A5000 Ace In The Hole Battery Back Up Sump Pump System
Pump wont start impeller gets corrosion a5000
Got o2 ford 2.3 it died now wont start and got water in oil pan
head gasket
corrosion behind water pump impeller allowing water into the timing cover into the sump
Sep 10, 2017 | Ford Cars & Trucks
WHY THE PUMP WONT TURN ON,
It is possible that the pump itself has failed.
May 08, 2014 | Simer A5000 Ace In The Hole Battery Back...
Remove impeller from Waterway 502n22c
To remove the impeller you first take the front face plate off to expose the impeller. Then isolate the shaft from the motor with a pair of needle nose vise grips and using a pair of channel lock pliers grip the end of the impeller and rotate counter clockwise to un thread it from the shaft. If the shaft seal has been leaking there may be to much corrosion to turn the impeller in which case it needs to be broken off.
May 13, 2013 | Waterway 5HP Executive 56 Frame Spa Pump...
01 lincoln ls starts over heating but i turn my heater on and it returns to normal temp
Have the coolant level checked. The overflow for the Radator which is usally a white container marked coolant check that to see if there is any coolant in there. There should be some with a cold or hot check level. DO NOT REMOVE RADATOR CAP IF HOT ENGINE...
Sep 06, 2012 | 2001 Lincoln LS
DWD5411W
Yes possibly the pump or the impeller is clogged or your bearings are eaten by the water and corrosion
Jan 01, 2012 | Beko Dishwashers
I can't get the impeller off. It doesn't have a screw and I can lock the shaft and try to turn it counter clockwise, but it will not budge.
there is most likely corrosion in the threads between the impeller and the motor shaft. You will need an impeller wrench to get enough torque to spin it loose., you may have to replace the impeller if it is excessively corroded as it may be cracked as well.
Nov 06, 2010 | Jandy POOL PUMP IMPELLER ASSY PLUS HP...
I can't remove the impeller on a 4hp Speck pump...I've worked on several 3/4 to 3 hp pool pumps but this one is a first...also, how is the seal plate attached? maybe I'll figure that out if I'm able to...
If the shaft seal has been leaking for some time the stem on the impeller has likely spit due to corrosion on the motor shaft. This makes it near impossible to un screw the impeller. You can try and isolate the armature of the motor and use a channel lock on the impeller. The only other way to get it off is by breaking it. Use a flat head screwdriver and a hammer and break apart the area around the center of the impeller until you can pry off the everything but the stem. You'll have to remove the ceramic part of the seal and pick out as much of the stem as you can. Then you can get the wetend off the motor and remove the metal cup seal.
Oct 16, 2010 | Waterway Executive Spa Pump 4hp Impeller...
I have a Flotec shallow well pump. The motor is buzzing but it will not turn.
could be bad bearings,obstruction in impeller,low voltage,failing capacitor.
Dec 20, 2009 | Flotec Corrosion Resistant Shallow Well...
Finding Flotec impeller for a flotec pump modle FP4012
WW Graingers. Call them with model and serial #s. If you do not have an account with WW, These guys have what ever you need:
http://www.pumpagents.com/partpages/FlotecPumps/FP4012.html
Nov 20, 2008 | Flotec Corrosion Resistant Shallow Well...
Simer A5000 Ace In The Hole Battery Back Up Sump Pump System Logo
35 people viewed this question
Top Simer Plumbing Experts
Renee Knafel-Bullock
Tom Chichester
Bill Boyd
Are you a Simer Plumbing Expert? Answer questions, earn points and help others
