Question about Philips Magnavox 15MF400T 15 in. LCD Television
Magnavox 15mf 400to 37: no color or sound is my so called mother board fried?
3 Suggested Answers
  • 31 Answers
SOURCE: Remote no longer works.
Universal remote codes for Phillips:
0025, 0027, 0031, 0153
For Magnavox:
0027
If your RCA converter remote functions as a universal remote one of those codes should work. If not, you should be able to find a basic universal remote for around $10 at any drug store or grocery store. If you have a more complex home theater system and are interested in advanced functionality, Logitech makes an excellent line of universal remotes that range from around $80 to hundreds of dollars.
Posted on Mar 15, 2011
gopakumarg43
  • 74617 Answers
SOURCE: 42MF437B/37 magnavox tv no power making buzzing sound
It sounds that there is some shorted component/s one either main power regulator board, or at the main digital board. Your TV need a through checkup.
Posted on Sep 11, 2012
Magnavox #32md357b/37 it has a inverted picture like a x-Ray picture tried to color on it and it won't adjust to natural color
Sounds like T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Feb 20, 2016 | Magnavox Televison & Video
32MD251D/37 will not power on
Zack Corpier
Workup for repair
02/22/2013
Diagnosis for Magnavox 32MD251D/37
Symptoms:
Will not power on
Once on, if turned off power might not return
Does not respond to power cycling
Possible Culprits:
Overloaded fuse
Damaged/fried power board
Damaged/fried inverter board
Damage to wiring or related
Overloaded capacitors on power board - I identified this based on a visual inspection and a multi meter test
https://lh6.googleusercontent.com/-Mcf67G5l3l8/USgitModWZI/AAAAAAAACRo/PwjueC45Hjo/w333-h319-o-k/caps.png
Problems Identified:
Capacitor 2079 appears overloaded - 1200uf 35v
Capacitor 2080 appears overloaded - 1200uf 35v
Explanation:
The capacitors referenced regulate the voltage controlling the power. These caps have a limited lifetime in hours which is usually around 3000. The device was left on for an extended period of time overloading these essential components.
Resolution:
1. I will order a set of replacement capacitors
2. Discharge board prior to work
3. Remove and replace damaged capacitors
Required Parts (total cost $30):
(2) Vented axial 1200uF 35v Capacitors - $8
Variable wattage soldering iron (minimum 35w) - $22
Feb 10, 2013 | Magnavox 32MD251D/37 Tabletop Pedestal...
Sep 11, 2012 | Philips Magnavox 42MF521D/37 Television
Remote no longer works. We need remote codes needed for a RCA DTA800B1 converter remote or suggestions for a universl remote that will work with 15Mf-400T/37 Magnavox
For Magnavox:
0027
Mar 15, 2011 | Philips Magnavox 15MF400T 15 in. LCD...
Magnavox 37MF331D sound and picture fine, no color. What happened?
The problem is in ssb. [scale board] I call it the signal board. But briefly part, location 1H00 [color crystal] PN#823827736071 needs replaced. And caps locations 2H08 and 2H09,PN#223886975478 need replaced. Hope this will help you...these are surface mount repairs that require skills!!!!
Jan 07, 2010 | Toymax Magnavox 37MF331D 37 in. LCD TV
HANSpree LCD TV 37''JT02 Series Product No.(serial N0.)JT02-37E 2-006G Type-T 738 (MH17841Q) Assembled in Czeck (May 2007) Need a new mother board as the present one is faulty. Please advice availability...
Please call the given number and get support of parts availability and cost.
888 808 6789 (1-714-727-2727 outside of the US), Mon - Fri: 6am - 6pm PST / PDT.
Thanks for using fixya.
Nov 11, 2009 | Akai LCT3201TD 32 in. LCD Television
No sound, no picture` MAGNAVOX 51MP6500D/37
SSB board it is over next to tuner stands up behind it . Call Mats for Part 1-800-628-1118
Sep 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 15MF400T 15 in. LCD Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
